ユーザーアカウント管理
📄️ ALTER USER
ALTER USER modifies user information including password, authentication method, and default roles.
📄️ CREATE ROLE
CREATE ROLE creates a new role for assigning permissions and controlling user access.
📄️ CREATE USER
CREATE USER creates a new StarRocks user with optional authentication and properties.
📄️ DROP ROLE
DROP ROLE removes a role from StarRocks.
📄️ DROP USER
DROP USER removes a specified user identity from StarRocks.
📄️ EXECUTE AS
Use IMPERSONATE privilege with EXECUTE AS to switch the execution context to another user.
📄️ GRANT
Grants roles or privileges on specific objects to users, roles, or external groups.
📄️ REVOKE
REVOKE removes specific privileges or roles from a user or role.
📄️ SET DEFAULT ROLE
SET DEFAULT ROLE sets roles that activate by default when a user connects.
📄️ SET PASSWORD
SET PASSWORD changes the login password for users.
📄️ SET ROLE
SET ROLE activates roles with their associated privileges for the current session.
📄️ SHOW AUTHENTICATION
SHOW AUTHENTICATION displays authentication information of users in the cluster.
📄️ SHOW GRANTS
SHOW GRANTS displays all privileges and roles granted to a user or role.
📄️ SHOW PROPERTY
SHOW PROPERTY displays user properties like maximum connections, default catalog, and database.
📄️ SHOW ROLES
システム内のすべてのロールを表示します。
📄️ SHOW USERS
システム内のすべてのユーザーを表示します。
