用户账户管理
📄️ ALTER USER
ALTER USER modifies user information, including password, authentication method, default roles, and user properties (supported from v3.3.3 onwards).
📄️ CREATE ROLE
CREATE ROLE creates a role.
📄️ 创建用户
CREATE USER creates a StarRocks user.
📄️ DROP ROLE
DROP ROLE drops a role.
📄️ DROP USER
DROP USER drops a specified user identity.
📄️ EXECUTE AS
Use the IMPERSONATE privilege with EXECUTE AS statements to switch the execution context of the current session to the impersonated user.
📄️ GRANT
Grants roles or privileges on specific objects to a user, a role, or an external group.
📄️ REVOKE
Use REVOKE to remove specific privileges or roles from a user or a role.
📄️ SET DEFAULT ROLE
SET DEFAULT ROLE sets the roles that are activated by default when the user connects to the server.
📄️ SET PASSWORD
SET PASSWORD changes the login password for users.
📄️ SET ROLE
SET ROLE activates roles, along with all of its associated privileges and nested roles, for the current session.
📄️ SHOW AUTHENTICATION
SHOW AUTHENTICATION displays the authentication information of the current user or all users in the current cluster.
📄️ SHOW GRANTS
SHOW GRANTS displays all the privileges that have been granted to a user or role.
📄️ SHOW PROPERTY
SHOW PROPERTY displays properties of a user, including the maximum number of connections, the default catalog, and the default database.
📄️ SHOW ROLES
SHOW ROLES displays all roles in the system.
📄️ SHOW USERS
SHOW USERS displays all users in the system.
