存储卷
📄️ ALTER STORAGE VOLUME
ALTER STORAGE VOLUME modifies credential properties, comments, or status of a storage volume.
📄️ CREATE STORAGE VOLUME
CREATE STORAGE VOLUME creates a storage volume for a remote storage system.
📄️ DESC STORAGE VOLUME
DESC STORAGE VOLUME shows detailed information about a storage volume.
📄️ DROP STORAGE VOLUME
DROP STORAGE VOLUME removes a storage volume from the cluster.
📄️ SET DEFAULT STORAGE VOLUME
SET DEFAULT STORAGE VOLUME designates a storage volume as the default for the cluster.
📄️ SHOW STORAGE VOLUMES
SHOW STORAGE VOLUMES lists all storage volumes in your StarRocks cluster.
