バージョン: 4.0
stream_loads
stream_loads provides information about stream load jobs.
The following fields are provided in stream_loads:
FieldDescription
LABELLabel of the stream load job.
IDID of the stream load job.
LOAD_IDLoad ID of the stream load job.
TXN_IDTransaction ID of the stream load job.
DB_NAMEName of the database to which the stream load job belongs.
TABLE_NAMEName of the table to which the data is loaded.
STATEState of the stream load job.
ERROR_MSGError message if the stream load job failed.
TRACKING_URLURL for tracking the stream load job.
CHANNEL_NUMNumber of channels used in the stream load job.
PREPARED_CHANNEL_NUMNumber of prepared channels in the stream load job.
NUM_ROWS_NORMALNumber of normal rows loaded.
NUM_ROWS_AB_NORMALNumber of abnormal rows loaded.
NUM_ROWS_UNSELECTEDNumber of unselected rows.
NUM_LOAD_BYTESNumber of bytes loaded.
TIMEOUT_SECONDTimeout in seconds for the stream load job.
CREATE_TIME_MSCreation time of the stream load job (in milliseconds).
BEFORE_LOAD_TIME_MSTime before loading started (in milliseconds).
START_LOADING_TIME_MSTime when loading started (in milliseconds).
START_PREPARING_TIME_MSTime when preparing started (in milliseconds).
FINISH_PREPARING_TIME_MSTime when preparing finished (in milliseconds).
END_TIME_MSEnd time of the stream load job (in milliseconds).
CHANNEL_STATEState of the channels.
TYPEType of the stream load job.
TRACKING_SQLSQL statement for tracking the stream load job.
