array_sort
Sorts the elements of an array in ascending order.
array_sort(array)
array: the array whose elements you want to sort. Only the ARRAY data type is supported.
Returns an array.
Usage notes​
  • This function sorts the elements of an array only in ascending order.
  • NULL values are placed at the beginning of the array that is returned.
  • If you want to sort the elements of an array in descending order, use the reverse function.
  • The elements of the returned array have the same data type as the elements of the input array.
The following table is used as an example:
mysql> select * from test;
| c1 | c2 |
| 1 | [4,3,null,1] |
| 2 | NULL |
| 3 | [null] |
| 4 | [8,5,1,4] |
Sort the values of column c2 in ascending order.
mysql> select c1, array_sort(c2) from test;
| c1 | array_sort(`c2`) |
| 1 | [null,1,3,4] |
| 2 | NULL |
| 3 | [null] |
| 4 | [1,4,5,8] |
StarRocks Assistant
