Version: Latest-4.1
array_difference
Calculates the difference between every two neighboring elements of an array by subtracting each element from its following element and returns an array that consists of the differences.
array_difference(input)
input: the array for which you want to calculate the differences between every two neighboring elements.
Returns an array with the same length as input. The return element type is determined by the input element type as follows:
Input element typeReturn element type
BOOLEAN, TINYINT, SMALLINT, INT, or BIGINTBIGINT
LARGEINTLARGEINT
FLOAT or DOUBLEDOUBLE
DECIMAL(P, S), where P <= 38DECIMAL(min(P + 1, 38), S)
ARRAY<DECIMAL256> (P > 38) is not supported.
Example 1:
mysql> SELECT array_difference([342, 32423, 213, 23432]);
| array_difference([342,32423,213,23432]) |
| [0,32081,-32210,23219] |
Example 2:
mysql> SELECT array_difference([342, 32423, 213, null, 23432]);
| array_difference([342,32423,213,NULL,23432]) |
| [0,32081,-32210,null,null] |
Example 3:
mysql> SELECT array_difference([1.2, 2.3, 3.2, 4324242.55]);
| array_difference([1.2,2.3,3.2,4324242.55]) |
| [0,1.1,0.9,4324239.35] |
Example 4:
mysql> SELECT array_difference([false, true, false]);
| array_difference([FALSE, TRUE, FALSE]) |
| [0,1,-1] |
