Gather statistics for CBO
What is CBOβ
Types of statistical informationβ
Basic statisticsβ
row_count: total number of rows in a table
data_size: data size of a column
ndv: column cardinality, which is the number of distinct values in a column
null_count: the amount of data with NULL values in a column
min: minimum value in a column
max: maximum value in a column
Full statistics are stored in the column_statistics of the _statistics_ database. You can view this table to query table statistics. Following is an example of querying statistics data from this table.
table_id: 10174
partition_id: 10170
column_name: is_minor
db_id: 10169
partition_name: p06
row_count: 2
data_size: 2
ndv: NULL
null_count: 0
max: 1
min: 0
Histogramβ
Currently, StarRocks supports only manual collection of histograms. Histograms are stored in the histogram_statistics table of the _statistics_ database. Following is an example of querying statistics data from this table:
table_id: 10174
column_name: added
db_id: 10169
buckets: NULL
mcv: [["23","1"],["5","1"]]
Collection types and methodsβ
StarRocks supports full and sampled collection, both can be performed automatically and manually. By default, StarRocks automatically collects full statistics of a table. It checks for any data updates every 5 minutes. If data change is detected, data collection will be automatically triggered. If you do not want to use automatic full collection, you can customize a collection task.
| Collection type | Collection method | Description | Advantage and disadvantage |
| Full collection | Automatic/manual | Scans the full table to gather statistics.Statistics are collected partition. If a partition has no data change, data will not be collected from this partition, reducing resource consumption.Full statistics are stored in the _statistics_.column_statistics table. | Advantage: The statistics are accurate, which helps the CBO make accurate estimation.Disadvantage: It consumes system resources and is slow. From 2.5 onwards, StarRocks allows you to specify an automatic collection period, which reduces resource consumption. |
| Sampled collection | Automatic/manual | Evenly extracts N rows of data from each partition of a table.Statistics are collected by table. Basic statistics of each column are stored as one record. Cardinality information (ndv) of a column is estimated based on the sampled data, which is not accurate. Sampled statistics are stored in the _statistics_.table_statistic_v1 table. | Advantage: It consumes less system resources and is fast.Disadvantage: The statistics are not complete, which may affect the accuracy of cost estimation. |
Collect statisticsβ
Automatic collectionβ
For basic statistics, StarRocks automatically collects full statistics of a table by default, without requiring manual operations. For tables on which no statistics have been collected, StarRocks automatically collects statistics within the scheduling period. For tables on which statistics have been collected, StarRocks updates the total number of rows and modified rows in the tables, and persists this information regularly for judging whether to trigger automatic collection.
From 2.4.5 onwards, StarRocks allows you to specify a collection period for automatic full collection, which prevents cluster performance jitter caused by automatic full collection. This period is specified by FE parameters statistic_auto_analyze_start_time and statistic_auto_analyze_end_time.
Table data has changed since previous statistics collection.
The collection time falls within the range of the configured collection period. (The default collection period is all day.)
The update time of the previous collecting job is earlier than the latest update time of partitions.
The health of table statistics is below the specified threshold (
statistic_auto_collect_ratio).
If the number of partitions with data updated is less than 10, the formula is
1 - (Number of updated rows since previous collection/Total number of rows). If the number of partitions with data updated is greater than or equal to 10, the formula is1 - MIN(Number of updated rows since previous collection/Total number of rows, Number of updated partitions since previous collection/Total number of partitions).
For tables with small data volume, **statistics are collected in real time with no restrictions, even though the table data is frequently updated. The
statistic_auto_collect_small_table_sizeparameter can be used to determine whether a table is a small table or a large table. You can also usestatistic_auto_collect_small_table_intervalto configure collection intervals for small tables. -
For tables with large data volume, the following restrictions apply:
The default collection interval is not less than 12 hours, which can be configured using
statistic_auto_collect_large_table_interval. -
When the collection interval is met and the statistics health is lower than the threshold for automatic sampled collection (
statistic_auto_collect_sample_threshold), sampled collection is triggered. -
When the collection interval is met and the statistics health is higher than the threshold for automatic sampled collection (
statistic_auto_collect_sample_threshold) and lower than the automatic collection threshold (statistic_auto_collect_ratio), full collection is triggered. -
When the size of partitions to collect data (
statistic_max_full_collect_data_size) is greater than 100 GB, sampled collection is triggered. -
Only statistics of partitions whose update time is later than the time of the previous collection task are collected. Statistics of partitions with no data change are not collected.
| FE configuration item | Type | Default value | Description |
| enable_statistic_collect | BOOLEAN | TRUE | Whether to collect statistics. This switch is turned on by default. |
| enable_collect_full_statistic | BOOLEAN | TRUE | Whether to enable automatic full collection. This switch is turned on by default. |
| statistic_collect_interval_sec | LONG | 300 | The interval for checking data updates during automatic collection. Unit: seconds. |
| statistic_auto_analyze_start_time | STRING | 00:00:00 | The start time of automatic collection. Value range: 00:00:00 - 23:59:59. |
| statistic_auto_analyze_end_time | STRING | 23:59:59 | The end time of automatic collection. Value range: 00:00:00 - 23:59:59. |
| statistic_auto_collect_small_table_size | LONG | 5368709120 | The threshold for determining whether a table is a small table for automatic full collection. A table whose size is greater than this value is considered a large table, whereas a table whose size is less than or equal to this value is considered a small table. Unit: Byte. Default value: 5368709120 (5 GB). |
| statistic_auto_collect_small_table_interval | LONG | 0 | The interval for automatically collecting full statistics of small tables. Unit: seconds. |
| statistic_auto_collect_large_table_interval | LONG | 43200 | The interval for automatically collecting full statistics of large tables. Unit: seconds. Default value: 43200 (12 hours). |
| statistic_auto_collect_ratio | FLOAT | 0.8 | The threshold for determining whether the statistics for automatic collection are healthy. If statistics health is below this threshold, automatic collection is triggered. |
| statistic_auto_collect_sample_threshold | DOUBLE | 0.3 | The statistics health threshold for triggering automatic sampled collection. If the health value of statistics is lower than this threshold, automatic sampled collection is triggered. |
| statistic_max_full_collect_data_size | LONG | 107374182400 | The data size of the partitions for automatic collection to collect data. Unit: Byte. Default value: 107374182400 (100 GB). If the data size exceeds this value, full collection is discarded and sampled collection is performed instead. |
| statistic_full_collect_buffer | LONG | 20971520 | The maximum buffer size taken by automatic collection tasks. Unit: Byte. Default value: 20971520 (20 MB). |
| statistic_collect_max_row_count_per_query | INT | 5000000000 | The maximum number of rows to query for a single analyze task. An analyze task will be split into multiple queries if this value is exceeded. |
| statistic_collect_too_many_version_sleep | LONG | 600000 | The sleep time of automatic collection tasks if the table on which the collection task runs has too many data versions. Unit: ms. Default value: 600000 (10 minutes). |
Manual collectionβ
Manually collect basic statisticsβ
[WITH SYNC | ASYNC MODE]
Parameter description:
Collection type
- FULL: indicates full collection.
- SAMPLE: indicates sampled collection.
- If no collection type is specified, full collection is used by default.
col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected. -
[WITH SYNC | ASYNC MODE]: whether to run the manual collection task in synchronous or asynchronous mode. Synchronous collection is used by default if you do not specify this parameter.
PROPERTIES: custom parameters. IfPROPERTIESis not specified, the default settings in thefe.conffile are used. The properties that are actually used can be viewed via thePropertiescolumn in the output of SHOW ANALYZE STATUS.
| PROPERTIES | Type | Default value | Description |
| statistic_sample_collect_rows | INT | 200000 | The minimum number of rows to collect for sampled collection.If the parameter value exceeds the actual number of rows in your table, full collection is performed. |
Manual full collection
ANALYZE TABLE tbl_name;
ANALYZE FULL TABLE tbl_name;
Manual sampled collection
Manually collect histogramsβ
[WITH N BUCKETS]
col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected. This parameter is required for histograms. -
[WITH SYNC | ASYNC MODE]: whether to run the manual collection task in synchronous or asynchronous mode. Synchronous collection is used by default if you not specify this parameter.
WITH N BUCKETS:Nis the number of buckets for histogram collection. If not specified, the default value infe.confis used. -
PROPERTIESis not specified, the default settings infe.confare used.
| statistic_sample_collect_rows | INT | 200000 | The minimum number of rows to collect. If the parameter value exceeds the actual number of rows in your table, full collection is performed. |
| histogram_buckets_size | LONG | 64 | The default bucket number for a histogram. |
| histogram_mcv_size | INT | 100 | The number of most common values (MCV) for a histogram. |
| histogram_sample_ratio | FLOAT | 0.1 | The sampling ratio for a histogram. |
| histogram_max_sample_row_count | LONG | 10000000 | The maximum number of rows to collect for a histogram. |
The properties that are actually used can be viewed via the Properties column in the output of SHOW ANALYZE STATUS.
PROPERTIES(
"histogram_mcv_size" = "32",
Custom collectionβ
Customize an automatic collection taskβ
You can use the CREATE ANALYZE statement to customize an automatic collection task. You must have the INSERT and SELECT privileges on the coreesponding table to perform the ANALYZE TABLE operation.
Collection type
- If no collection type is specified, sample collection is used by default.
PROPERTIES: custom parameters. IfPROPERTIESis not specified, the default settings infe.confare used.
| statistic_auto_collect_ratio | FLOAT | 0.8 | The threshold for determining whether the statistics for automatic collection are healthy. If the statistics health is below this threshold, automatic collection is triggered. |
| statistics_max_full_collect_data_size | INT | 100 | The size of the largest partition for automatic collection to collect data. Unit: GB.If a partition exceeds this value, full collection is discarded and sampled collection is performed instead. |
| statistic_sample_collect_rows | INT | 200000 | The minimum number of rows to collect.If the parameter value exceeds the actual number of rows in your table, full collection is performed. |
| statistic_exclude_pattern | String | null | The name of the database or table that needs to be excluded in the job. You can specify the database and table that do not collect statistics in the job. Note that this is a regular expression pattern, and the match content is database.table. |
| statistic_auto_collect_interval | LONG | 0 | The interval for automatic collection. Unit: seconds. By default, StarRocks chooses statistic_auto_collect_small_table_interval or statistic_auto_collect_large_table_interval as the collection interval based on the table size. If you specified the statistic_auto_collect_interval property when you create an analyze job, this setting takes precedence over statistic_auto_collect_small_table_interval and statistic_auto_collect_large_table_interval. |
CREATE ANALYZE ALL;
Automatic sampled collection
View custom collection tasksβ
| Column | Description |
| Id | The ID of the collection task. |
| Database | The database name. |
| Table | The table name. |
| Columns | The column names. |
| Type | The type of statistics, including FULL and SAMPLE. |
| Schedule | The type of scheduling. The type is SCHEDULE for an automatic task. |
| Properties | Custom parameters. |
| Status | The task status, including PENDING, RUNNING, SUCCESS, and FAILED. |
| LastWorkTime | The time of the last collection. |
| Reason | The reason why the task failed. NULL is returned if task execution was successful. |
SHOW ANALYZE JOB
Delete a custom collection taskβ
DROP ANALYZE <ID>
DROP ANALYZE 266030;
View status of collection tasksβ
You can use LIKE or WHERE to filter the information to return.
| List name | Description |
| Type | The type of statistics, including FULL, SAMPLE, and HISTOGRAM. |
| Schedule | The type of scheduling. ONCE means manual and SCHEDULE means automatic. |
| Status | The status of the task. |
| StartTime | The time when the task starts executing. |
| EndTime | The time when the task execution ends. |
| Reason | The reason why the task failed. NULL is returned if the execution was successful. |
View statisticsβ
View metadata of basic statisticsβ
SHOW STATS META [WHERE predicate]
| Type | The type of statistics. FULL means full collection and SAMPLE means sampled collection. |
| UpdateTime | The latest statistics update time for the current table. |
| Healthy | The health of statistical information. |
View metadata of histogramsβ
| Column | The columns. |
| Type | Type of statistics. The value is HISTOGRAM for histograms. |
Delete statisticsβ
Delete basic statisticsβ
DROP STATS tbl_name
Delete histogramsβ
Cancel a collection taskβ
KILL ANALYZE <ID>
Other FE configuration itemsβ
| statistic_manager_sleep_time_sec | LONG | 60 | The interval at which metadata is scheduled. Unit: seconds. The system performs the following operations based on this interval:Create tables for storing statistics.Delete statistics that have been deleted.Delete expired statistics. |
| statistic_analyze_status_keep_second | LONG | 259200 | The duration to retain the history of collection tasks. Unit: seconds. Default value: 259200 (3 days). |
Session variableβ
statistic_collect_parallel: Used to adjust the parallelism of statistics collection tasks that can run on BEs. Default value: 1. You can increase this value to speed up collection tasks.
Collect statistics of Hive/Iceberg/Hudi tablesβ
Since v3.2.0, StarRocks supports collecting statistics of Hive, Iceberg, and Hudi tables. The syntax is similar to collecting StarRocks internal tables. However, only manual full collection, manual histogram collection (since v3.2.7), and automatic full collection are supported. Sampled collection is not supported. Since v3.3.0, StarRocks supports collecting statistics of sub-fields in STRUCT.
The collected statistics are stored in the external_column_statistics table of the _statistics_ in the default_catalog. They are not stored in Hive Metastore and cannot be shared by other search engines. You can query data from the default_catalog._statistics_.external_column_statistics table to verify whether statistics are collected for a Hive/Iceberg/Hudi table.
Following is an example of querying statistics data from external_column_statistics.
partition_name:
column_name: k1
catalog_name: hive_catalog
db_name: tn_test
table_name: ex_hive_tbl
row_count: 3
data_size: 12
ndv: NULL
null_count: 0
max: 3
min: 2
Limitsβ
The following limits apply when you collect statistics for Hive, Iceberg, Hudi tables:
- You can collect statistics of only Hive, Iceberg, and Hudi tables.
- Only manual full collection, manual histogram collection (since v3.2.7), and automatic full collection are supported. Sampled collection is not supported.
- For the system to automatically collect full statistics, you must create an Analyze job, which is different from collecting statistics of StarRocks internal tables where the system does this in the background by default.
- For automatic collection tasks, you can only collect statistics of a specific table. You cannot collect statistics of all tables in a database or statistics of all databases in an external catalog.
- For automatic collection tasks, StarRocks can detect whether data in Hive and Iceberg tables are updated and if so, collect statistics of only partitions whose data is updated. StarRocks cannot perceive whether data in Hudi tables are updated and can only perform periodic full collection.
The following examples happen in a database under the Hive external catalog. If you want to collect statistics of a Hive table from the default_catalog, reference the table in the [catalog_name.][database_name.]<table_name> format.
Manual collectionβ
Create a manual collection taskβ
Syntax:
-- Manual full collection
-- Manual histogram collection (since v3.3.0)
[WITH N BUCKETS]
Following is an example of manual full collection:
View the task statusβ
Syntax:
Example:
View metadata of statisticsβ
Syntax:
Example:
Syntax:
KILL ANALYZE <ID>
The interval for checking data updates during automatic collection. Unit: seconds. Default: 5 minutes.
statistic_auto_collect_small_table_rows (v3.2 and later)
Threshold to determine whether a table in an external data source (Hive, Iceberg, Hudi) is a small table during automatic collection. Default: 10000000.
The interval for collecting statistics of small tables. Unit: seconds. Default: 0.
The interval for collecting statistics of large tables. Unit: seconds. Default: 43200 (12 hours).
Automatic collection threads checks data updates at the interval specified by statistic_collect_interval_sec. If the number of rows in a table is less than statistic_auto_collect_small_table_rows, it collects statistics of such tables based on statistic_auto_collect_small_table_interval.
If the number of rows in a table exceeds statistic_auto_collect_small_table_rows, it collects statistics of such tables based on statistic_auto_collect_large_table_interval. It updates statistics of large tables only when Last table update time + Collection interval > Current time. This prevents frequent analyze tasks for large tables.
Create an automatic collection taskβ
Syntax:
You can specify the property statistic_auto_collect_interval to set the collection interval exclusively for the automatic collection task. The FE configuration items statistic_auto_collect_small_table_interval and statistic_auto_collect_large_table_interval will not take effect on this task.
Example:
View the status of an automatic collection taskβ
Same as manual collection.
View automatic collection tasksβ
Syntax:
Example:
Empty set (0.00 sec)
Delete statisticsβ
DROP STATS tbl_name
Referencesβ
To query FE configuration items, run ADMIN SHOW CONFIG.
To modify FE configuration items, run ADMIN SET CONFIG.
