System variables
If you want to make a setting change for the current session and also make that setting change apply to all future sessions, you can make the change twice, once without the
GLOBAL
modifier and once with it. For example:SET query_mem_limit = 137438953472; -- Apply to the current session.
Variable hierarchy and types
StarRocks supports three types (levels) of variables: global variables, session variables, and SET_VAR
hints. Their hierarchical relationship is as follows:
- Global variables take effect on global level, and can be overridden by session variables and
SET_VAR
hints. - Session variables take effect only on the current session, and can be overridden by
SET_VAR
hints. SET_VAR
hints take effect only on the current query statement.
View variables
You can view all or some variables by using SHOW VARIABLES [LIKE 'xxx']
. Example:
SHOW VARIABLES;
Set variables
Set variables globally or for a single session
A variable set by SET <var_name> = xxx;
only takes effect for the current session. Example:
SET forward_to_master = true;
A variable set by SET GLOBAL <var_name> = xxx;
takes effect globally. Example:
The following variables only take effect globally. They cannot take effect for a single session, which means you must use SET GLOBAL <var_name> = xxx;
for these variables. If you try to set such a variable for a single session (SET <var_name> = xxx;
), an error is returned.
- activate_all_roles_on_login
- character_set_database
- default_rowset_type
- enable_query_queue_select
- enable_query_queue_load
- init_connect
- lower_case_table_names
- license
- language
- query_cache_size
- system_time_zone
- version_comment
- version
Set variables in a single query statement
In some scenarios, you may need to set variables specifically for certain queries. By using the SET_VAR
hint, you can set session variables that will take effect only within a single statement.
StarRocks supports using SET_VAR
in the following statements;
- SELECT
- INSERT (from v3.1.12 and v3.2.0 onwards)
- UPDATE (from v3.1.12 and v3.2.0 onwards)
- DELETE (from v3.1.12 and v3.2.0 onwards)
SET_VAR
can only be placed after the above keywords and enclosed in /*+...*/
Example:
UPDATE /*+ SET_VAR(query_timeout=100) */ tbl SET c1 = 2 WHERE c1 = 1;
FROM my_table PARTITION p1
WHERE k1 = 3;
INSERT /*+ SET_VAR(query_timeout = 10000000) */
INTO insert_wiki_edit
SELECT * FROM FILES(
"format" = "parquet",
"aws.s3.region" = "us-west-2"
SELECT /*+ SET_VAR
query_timeout=10000000,
batch_size=4096,
*/ * FROM TABLE;
Descriptions of variables
The variables are described in alphabetical order. Variables with the global
label can only take effect globally. Other variables can take effect either globally or for a single session.
- Description: Whether to enable all roles (including default roles and granted roles) for a StarRocks user when the user connects to the StarRocks cluster.
- If enabled (
true
), all roles of the user are activated at user login. This takes precedence over the roles set by SET DEFAULT ROLE. - If disabled (
false
), the roles set by SET DEFAULT ROLE are activated.
- If enabled (
- Default: false
- Introduced in: v3.0
auto_increment_increment
autocommit
chunk_size
- Description: Used to specify the number of rows of a single packet transmitted by each node during query execution. The default is 4096, i.e., every 4096 rows of data generated by the source node is packaged and sent to the destination node. A larger number of rows will improve the query throughput in large data volume scenarios, but may increase the query latency in small data volume scenarios. Also, it may increase the memory overhead of the query. We recommend to set
batch_size
between 1024 to 4096. - Default: 4096
big_query_profile_threshold
Description: Used to set the threshold for big queries. When the session variable
enable_profile
is set tofalse
and the amount of time taken by a query exceeds the threshold specified by the variablebig_query_profile_threshold
, a profile is generated for that query.Note: In versions v3.1.5 to v3.1.7, as well as v3.2.0 to v3.2.2, we introduced the
big_query_profile_second_threshold
for setting the threshold for big queries. In versions v3.1.8, v3.2.3, and subsequent releases, this parameter has been replaced bybig_query_profile_threshold
to offer more flexible configuration options. -
Default: 0
Unit: Second
Data type: String
Introduced in: v3.1
catalog
- Description: Used to specify the catalog to which the session belongs.
- Default: default_catalog
- Data type: String
- Introduced in: v3.2.4
- Description: Controls how the CBO converts data from the DECIMAL type to the STRING type. If this variable is set to
true
, the logic built in v2.5.x and later versions prevails and the system implements strict conversion (namely, the system truncates the generated string and fills 0s based on the scale length). If this variable is set tofalse
, the logic built in versions earlier than v2.5.x prevails and the system processes all valid digits to generate a string. - Default: true
- Introduced in: v2.5.14
- Description: Whether to enable low cardinality optimization. After this feature is enabled, the performance of querying STRING columns improves by about three times.
- Default: true
cbo_eq_base_type
- Description: Specifies the data type used for data comparison between DECIMAL data and STRING data. The default value is
VARCHAR
, and DECIMAL is also a valid value. This variable takes effect only for=
and!=
comparison. - Data type: String
cbo_materialized_view_rewrite_related_mvs_limit
- Description: Specifies the maximum number of candidate materialized views allowed during query planning.
- Default: 64
- Data type: Int
- Introduced in: v3.1.9, v3.2.5
- Description: Whether to enable query rewrite based on synchronous materialized views.
- Default: true
- Introduced in: v3.1.11, v3.2.5
query_including_mv_names
- Description: Specifies the name of the asynchronous materialized views to include in query execution. You can use this variable to limit the number of candidate materialized views and improve the query rewrite performance in the optimizer. This item takes effect prior to
query_excluding_mv_names
. - Default: empty
- Data type: String
query_excluding_mv_names(
- Description: Specifies the name of the asynchronous materialized views to exclude from query execution. You can use this variable to limit the number of candidate materialized views and reduce the time of query rewrite in the optimizer.
takes effect prior to this item. - Default: empty
- Data type: String
- Description: Specifies the maximum time that one materialized view rewrite rule can consume. When the threshold is reached, this rule will not be used for query rewrite.
- Default: 1000
- Unit: ms
- Description: Whether to enable text-based materialized view rewrite. When this item is set to true, the optimizer will compare the query with the existing materialized views. A query will be rewritten if the abstract syntax tree of the materialized view's definition matches that of the query or its sub-query.
- Default: true
- Introduced in: v3.2.5, v3.3.0
- Description: Specifies the maximum number of times that the system checks whether a query's sub-query matches the materialized views' definition.
- Default: 4
enable_view_based_mv_rewrite
- Description: Whether to enable query rewrite for logical view-based materialized views. If this item is set to
true
, the logical view is used as a unified node to rewrite the queries against itself for better performance. If this item is set tofalse
, the system transcribes the queries against logical views into queries against physical tables or materialized views and then rewrites them. - Default: false
- Introduced in: v3.1.9, v3.2.5, v3.3.0
- Description: Whether to enable materialized view union rewrite. If this item is set to
true
, the system seeks to compensate the predicates using UNION ALL when the predicates in the materialized view cannot satisfy the query's predicates. - Default: true
- Introduced in: v2.5.20, v3.1.9, v3.2.7, v3.3.0
- Description: Whether to enable materialized view plan cache, which can optimize the automatic rewrite performance of materialized views. Setting it to
true
indicates enabling it. - Default: true
- Introduced in: v2.5.13, v3.0.7, v3.1.4, v3.2.0, v3.3.0
follower_query_forward_mode
Description: Specifies to which FE nodes the query statements are routed.
Valid values:
default
: Routes the query statement to the Leader FE or Follower FEs, depending on the Follower's replay progress. If the Follower FE nodes have not completed replay progress, queries will be routed to the Leader FE node. If the replay progress is complete, queries will be preferentially routed to the Follower FE node.leader
: Routes the query statement to the Leader FE.follower
: Routes the query statement to Follower FE.
Default: default
Data type: String
- Data type: StringThe character set supported by StarRocks. Only UTF8 (
utf8
) is supported. - Default: utf8
- Data type: String
- Description: The maximum number of concurrent I/O tasks that can be issued by a scan operator during external table queries. The value is an integer. Currently, StarRocks can adaptively adjust the number of concurrent I/O tasks when querying external tables. This feature is controlled by the variable
enable_connector_adaptive_io_tasks
, which is enabled by default. - Default: 16
- Data type: Int
- Description: Specifies the compression algorithm used for writing data into Hive tables or Iceberg tables, or exporting data with Files().
- Valid values:
uncompressed
,snappy
,lz4
,zstd
, andgzip
. - Default: uncompressed
- Data type: String
- Introduced in: v3.2.3
count_distinct_column_buckets
- Description: The number of buckets for the COUNT DISTINCT column in a group-by-count-distinct query. This variable takes effect only when
enable_distinct_column_bucketization
is set totrue
. - Default: 1024
default_rowset_type (global)
Used to set the default storage format used by the storage engine of the computing node. The currently supported storage formats are alpha
and beta
default_table_compression
Description: The default compression algorithm for table storage. Supported compression algorithms are
snappy, lz4, zlib, zstd
.Note that if you specified the
compression
property in a CREATE TABLE statement, the compression algorithm specified bycompression
takes effect. -
Default: lz4_frame
Introduced in: v3.0
disable_colocate_join
- Description: Used to control whether the Colocation Join is enabled. The default value is
false
, meaning the feature is enabled. When this feature is disabled, query planning will not attempt to execute Colocation Join. - Default: false
Used to enable the streaming pre-aggregations. The default value is false
, meaning it is enabled.
div_precision_increment
- Description: Whether to populate the data cache in asynchronous mode. By default, the system uses the synchronous mode to populate data cache, that is, populating the cache while querying data.
- Default: false
- Introduced in: v3.2.7
- Description: Whether to adaptively adjust the number of concurrent I/O tasks when querying external tables. Default value is
true
. If this feature is not enabled, you can manually set the number of concurrent I/O tasks using the variableconnector_io_tasks_per_scan_operator
. - Default: true
Description: Whether to enable bucketization for the COUNT DISTINCT colum in a group-by-count-distinct query. Use the
select a, count(distinct b) from t group by a;
query as an example. If the GROUP BY columa
is a low-cardinality column and the COUNT DISTINCT columnb
is a high-cardinality column which has severe data skew, performance bottleneck will occur. In this situation, you can split data in the COUNT DISTINCT column into multiple buckets to balance data and prevent data skew. You must use this variable with the variablecount_distinct_column_buckets
.You can also enable bucketization for the COUNT DISTINCT column by adding the
skew
hint to your query, for example,select a,count(distinct [skew] b) from t group by a;
Default: false, which means this feature is disabled.
Introduced in: v2.5
- Description: Whether to enable resource group-level query queue.
- Default: false, which means this feature is disabled.
- Introduced in: v3.1.4
enable_iceberg_metadata_cache
- Description: Whether to cache pointers and partition names for Iceberg tables. From v3.2.1 to v3.2.3, this parameter is set to
true
by default, regardless of what metastore service is used. In v3.2.4 and later, if the Iceberg cluster uses AWS Glue as metastore, this parameter still defaults totrue
. However, if the Iceberg cluster uses other metastore service such as Hive metastore, this parameter defaults tofalse
. - Introduced in: v3.2.1
enable_insert_strict
Used to enable the strict mode when loading data using the INSERT statement. The default value is true
, indicating the strict mode is enabled by default. For more information, see Strict mode.
- Description: Whether to allow StarRocks to rewrite queries in INSERT INTO SELECT statements.
- Default: false, which means Query Rewrite in such scenarios is disabled by default.
- Introduced in: v2.5.18, v3.0.9, v3.1.7, v3.2.2
- Description: Controls whether to enable rule-based materialized view query rewrite. This variable is mainly used in single-table query rewrite. * Default: true
- Data type: Boolean
enable_short_circuit
- Description: Whether to enable short circuiting for queries. Default:
false
. If it is set totrue
, when the query meets the criteria (to evaluate whether the query is a point query): the conditional columns in the WHERE clause include all primary key columns, and the operators in the WHERE clause are=
orIN
, the query takes the short circuit. - Default: false
enable_spill
- Description: Whether to enable intermediate result spilling. Default:
false
, StarRocks spills the intermediate results to disk to reduce the memory usage when processing aggregate, sort, or join operators in queries. - Default: false
enable_strict_order_by
- Description: Used to check whether the column name referenced in ORDER BY is ambiguous. When this variable is set to the default value
TRUE
, an error is reported for such a query pattern: Duplicate alias is used in different expressions of the query and this alias is also a sorting field in ORDER BY, for example,select distinct t1.* from tbl1 t1 order by t1.k1;
. The logic is the same as that in v2.3 and earlier. When this variable is set toFALSE
, a loose deduplication mechanism is used, which processes such queries as valid SQL queries. - Default: true
- Introduced in: v2.5.18 and v3.1.7
enable_profile
Description: Specifies whether to send the profile of a query for analysis. The default value is
false
, which means no profile is required.By default, a profile is sent to the FE only when a query error occurs in the BE. Profile sending causes network overhead and therefore affects high concurrency.
If you need to analyze the profile of a query, you can set this variable to
true
. After the query is completed, the profile can be viewed on the web page of the currently connected FE (address:fe_host:fe_http_port/query
). This page displays the profiles of the latest 100 queries withenable_profile
turned on. -
Default: false
- Description: Boolean value to enable query queues for loading tasks.
- Default: false
- Description: Whether to enable query queues for SELECT queries.
- Default: false
- Description: Whether to enable query queues for statistics queries.
- Default: false
enable_query_tablet_affinity
Description: Boolean value to control whether to direct multiple queries against the same tablet to a fixed replica.
However, if there are some hotspot tablets, this feature may degrade the query performance because it directs the queries to the same BE, making it unable to fully use the resources of multiple BEs in high-concurrency scenarios.
Default: false, which means the system selects a replica for each query.
Introduced in: v2.5.6, v3.0.8, v3.1.4, and v3.2.0.
- Description: Whether to enable Parallel Scan for Cloud-native tables in a shared-data cluster.
- Default: false
- Introduced in: v3.3.0
tablet_internal_parallel_mode
- Description: Internal Parallel Scan strategy of tablets. Valid Values:
auto
: When the number of Tablets to be scanned on BE or CN nodes is less than the Degree of Parallelism (DOP), the system automatically determines whether Parallel Scan is needed based on the estimated size of the Tablets.force_split
: Forces the splitting of Tablets and performs Parallel Scan.
- Default: auto
- Data type: String
- Introduced in: v2.5.0
enable_scan_datacache
- Description: Specifies whether to enable the Data Cache feature. After this feature is enabled, StarRocks caches hot data read from external storage systems into blocks, which accelerates queries and analysis. For more information, see Data Cache. In versions prior to 3.2, this variable was named as
enable_scan_block_cache
. - Default: false
enable_populate_datacache
- Description: Specifies whether to cache data blocks read from external storage systems in StarRocks. If you do not want to cache data blocks read from external storage systems, set this variable to
false
. Default value: true. This variable is supported from 2.5. In versions prior to 3.2, this variable was named asenable_scan_block_cache
. - Default: true
- Description: Whether to enable adaptive parallel scanning of tablets. After this feature is enabled, multiple threads can be used to scan one tablet by segment, increasing the scan concurrency.
- Default: true
- Introduced in: v2.3
enable_query_cache
- Description: Specifies whether to enable the Query Cache feature. Valid values: true and false.
true
specifies to enable this feature, andfalse
specifies to disable this feature. When this feature is enabled, it works only for queries that meet the conditions specified in the application scenarios of Query Cache. - Default: false
enable_adaptive_sink_dop
- Description: Specifies whether to enable adaptive parallelism for data loading. After this feature is enabled, the system automatically sets load parallelism for INSERT INTO and Broker Load jobs, which is equivalent to the mechanism of
pipeline_dop
. For a newly deployed v2.5 StarRocks cluster, the value istrue
by default. For a v2.5 cluster upgraded from v2.4, the value isfalse
. - Default: false
enable_pipeline_engine
- Description: Specifies whether to enable the pipeline execution engine.
true
indicates enabled andfalse
indicates the opposite. Default value:true
. - Default: true
enable_sort_aggregate
- Description: Specifies whether to enable sorted streaming.
true
indicates sorted streaming is enabled to sort data in data streams. - Default: false
enable_global_runtime_filter
Default value: true
, which means global RF is enabled. If this feature is disabled, global RF does not take effect. Local RF can still work.
Whether to enable multi-column global runtime filter. Default value: false
, which means multi-column global RF is disabled.
- If this feature is disabled, only Local RF works.
- If this feature is enabled, multi-column Global RF takes effect and carries
multi-column
in the partition by clause.
- Description: Whether to allow for sinking data to external tables of Hive.
- Default: false
event_scheduler
enable_strict_type
- Description: Whether to allow implicit conversions for all compound predicates and for all expressions in the WHERE clause.
- Default: false
force_streaming_aggregate
forward_to_leader
Used to specify whether some commands will be forwarded to the leader FE for execution. Alias: forward_to_master
, meaning not forwarding to the leader FE. There are multiple FEs in a StarRocks cluster, one of which is the leader FE. Normally, users can connect to any FE for full-featured operations. However, some information is only available on the leader FE.
SHOW FRONTENDS: Forwarding to the leader FE allows users to view the last heartbeat message.
SHOW BACKENDS: Forwarding to the leader FE allows users to view the boot time, last heartbeat information, and disk capacity information.
SHOW BROKER: Forwarding to the leader FE allows users to view the boot time and last heartbeat information.
SHOW TABLET
ADMIN SHOW REPLICA STATUS: Forwarding to the leader FE allows users to view the tablet information stored in the metadata of the leader FE. Normally, the tablet information should be the same in the metadata of different FEs. If an error occurs, you can use this method to compare the metadata of the current FE and the leader FE.
Show PROC: Forwarding to the leader FE allows users to view the PROC information stored in the metadata. This is mainly used for metadata comparison.
group_concat_max_len
- Description: The maximum length of string returned by the group_concat function.
- Default: 1024
- Min value: 4
- Unit: Characters
- Data type: Long
- Description: Used to control whether the data of the left table can be filtered by using the filter condition against the right table in the Join query. If so, it can reduce the amount of data that needs to be processed during the query.
Default:
true
indicates the operation is allowed and the system decides whether the left table can be filtered.false
indicates the operation is disabled. The default value istrue
init_connect (global)
interactive_timeout
- Description: The number of concurrent I/O tasks that can be issued by a scan operator. Increase this value if you want to access remote storage systems such as HDFS or S3 but the latency is high. However, a larger value causes more memory consumption.
- Default: 4
- Data type: Int
language (global)
license (global)
- Description: Displays the license of StarRocks.
- Default: Apache License 2.0
load_mem_limit
Specifies the memory limit for the import operation. The default value is 0, meaning that this variable is not used and query_mem_limit
is used instead.
This variable is only used for the INSERT
operation which involves both query and import. If the user does not set this variable, the memory limit for both query and import will be set as exec_mem_limit
. Otherwise, the memory limit for query will be set as exec_mem_limit
and the memory limit for import will be as load_mem_limit
Other import methods such as BROKER LOAD
, STREAM LOAD
still use exec_mem_limit
for memory limit.
log_rejected_record_num (v3.1 and later)
Specifies the maximum number of unqualified data rows that can be logged. Valid values: 0
, -1
, and any non-zero positive integer. Default value: 0
- The value
0
specifies that data rows that are filtered out will not be logged. - The value
-1
specifies that all data rows that are filtered out will be logged. - A non-zero positive integer such as
n
specifies that up ton
data rows that are filtered out can be logged on each BE.
materialized_view_rewrite_mode (v3.2 and later)
disable
: Disable automatic query rewrite of asynchronous materialized views.default
(Default value): Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, it directly scans the data in the base table.default_or_error
: Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, an error is returned.force
: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, it directly scans the data in the base table.force_or_error
: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, an error is returned.
max_allowed_packet
- Description: Used for compatibility with the JDBC connection pool C3P0. This variable specifies the maximum size of packets that can be transmitted between the client and server.
- Default: 33554432 (32 MB). You can raise this value if the client reports "PacketTooBigException".
- Unit: Byte
- Data type: Int
- Description: The maximum number of predicates that can be pushed down for a column.
- Default: -1, indicating that the value in the
be.conf
file is used. If this variable is set to a value greater than 0, the value inbe.conf
is ignored. - Data type: Int
max_scan_key_num
- Description: The maximum number of scan key segmented by each query.
be.conf
is ignored.
nested_mv_rewrite_max_level
- Description: The maximum levels of nested materialized views that can be used for query rewrite.
- Value range: [1, +∞). The value of
1
indicates that only materialized views created on base tables can be used for query rewrite. - Default: 3
- Data type: Int
net_buffer_length
net_read_timeout
net_write_timeout
new_planner_optimize_timeout
- Description: The timeout duration of the query optimizer. When the optimizer times out, an error is returned and the query is stopped, which affects the query performance. You can set this variable to a larger value based on your query or contact StarRocks technical support for troubleshooting. A timeout often occurs when a query has too many joins.
- Default: 3000
- Unit: ms
partial_update_mode
Description: Used to control the mode of partial updates. Valid values:
auto
(default): The system automatically determines the mode of partial updates by analyzing the UPDATE statement and the columns involved.column
: The column mode is used for the partial updates, which is particularly suitable for the partial updates which involve a small number of columns and a large number of rows.
Default: auto
Introduced in: v3.1
performance_schema (global)
prefer_compute_node
- Description: Specifies whether the FEs distribute query execution plans to CN nodes. Valid values:
true
: indicates that the FEs distribute query execution plans to CN nodes.false
: indicates that the FEs do not distribute query execution plans to CN nodes.
- Default: false
- Introduced in: v2.4
pipeline_dop
Description: The parallelism of a pipeline instance, which is used to adjust the query concurrency. Default value: 0, indicating the system automatically adjusts the parallelism of each pipeline instance. You can also set this variable to a value greater than 0. Generally, set the value to half the number of physical CPU cores.
From v3.0 onwards, StarRocks adaptively adjusts this variable based on query parallelism.
Default: 0
Data type: Int
pipeline_profile_level
Description: Controls the level of the query profile. A query profile often has five layers: Fragment, FragmentInstance, Pipeline, PipelineDriver, and Operator. Different levels provide different details of the profile:
- 0: StarRocks combines metrics of the profile and shows only a few core metrics.
- 1: default value. StarRocks simplifies the profile and combines metrics of the profile to reduce profile layers.
- 2: StarRocks retains all the layers of the profile. The profile size is large in this scenario, especially when the SQL query is complex. This value is not recommended.
Default: 1
Data type: Int
query_cache_entry_max_bytes
- Description: The threshold for triggering the Passthrough mode. When the number of bytes or rows from the computation results of a specific tablet accessed by a query exceeds the threshold specified by
orquery_cache_entry_max_rows
, the query is switched to Passthrough mode. - Valid values: 0 to 9223372036854775807
- Default: 4194304
- Unit: Byte
- Description: The upper limit of rows that can be cached. See the description in
. Default value: . - Default: 409600
- Description: The upper limit of cardinality for GROUP BY in Query Cache. Query Cache is not enabled if the rows generated by GROUP BY exceeds this value. Default value: 5000000. If
is set to 0, the Passthrough mode is used even when no computation results are generated from the involved tablets. - Default: 5000000
- Data type: Long
query_cache_size (global)
query_cache_type
query_mem_limit
- Description: Used to set the memory limit of a query on each BE node. The default value is 0, which means no limit for it. This item takes effect only after Pipeline Engine is enabled. When the
Memory Exceed Limit
error happens, you could try to increase this variable. Setting it to0
indicates no limit is imposed. - Default: 0
- Unit: Byte
- Description: The upper limit of concurrent queries on a BE. It takes effect only after being set greater than
0
. Setting it to0
- Data type: Int
- Description: The upper limit of CPU usage permille (CPU usage * 1000) on a BE. It takes effect only after being set greater than
0
. Setting it to0
indicates no limit is imposed. - Value range: [0, 1000]
- Default:
0
- Description: The upper limit of queries in a queue. When this threshold is reached, incoming queries are rejected. It takes effect only after being set greater than
0
. Setting it to0
1024
- Description: The upper limit of memory usage percentage on a BE. It takes effect only after being set greater than
0
. Setting it to0
indicates no limit is imposed. - Value range: [0, 1]
- Default: 0
- Description: The maximum timeout of a pending query in a queue. When this threshold is reached, the corresponding query is rejected.
- Default: 300
- Unit: Second
query_timeout
- Description: Used to set the query timeout in "seconds". This variable will act on all query statements in the current connection, as well as INSERT statements. The default value is 300 seconds.
- Value range: [1, 259200]
- Default: 300
- Data type: Int
- Unit: Second
range_pruner_max_predicate
- Description: The maximum number of IN predicates that can be used for Range partition pruning. Default value: 100. A value larger than 100 may cause the system to scan all tablets, which compromises the query performance.
- Default: 100
Description: Whether to place GRF on Exchange Node after GRF is pushed down across the Exchange operator to a lower-level operator. The default value is
false
, which means GRF will not be placed on Exchange Node after it is pushed down across the Exchange operator to a lower-level operator. This prevents repetitive use of GRF and reduces the computation time.However, GRF delivery is a "try-best" process. If the lower-level operator fails to receive the GRF but the GRF is not placed on Exchange Node, data cannot be filtered, which compromises filter performance.
true
means GRF will still be placed on Exchange Node even after it is pushed down across the Exchange operator to a lower-level operator. -
Default: false
- Description: The maximum number of rows allowed for the Hash table based on which Bloom filter Local RF is generated. Local RF will not be generated if this value is exceeded. This variable prevents the generation of an excessively long Local RF.
- Default: 1024000
- Data type: Int
- Description: The time interval at which runtime profiles are reported.
- Default: 10
- Unit: Second
- Data type: Int
- Introduced in: v3.1.0
spill_mode (3.0 and later)
auto
: Spilling is automatically triggered when the memory usage threshold is reached.force
: StarRocks forcibly executes spilling for all relevant operators, regardless of memory usage.
This variable takes effect only when the variable enable_spill
is set to true
SQL_AUTO_IS_NULL
sql_dialect
Description: The SQL dialect that is used. For example, you can run the
set sql_dialect = 'trino';
command to set the SQL dialect to Trino, so you can use Trino-specific SQL syntax and functions in your queries.NOTICE
Data type: StarRocks
Introduced in: v3.0
sql_mode
PIPES_AS_CONCAT
: The pipe symbol|
is used to concatenate strings, for example,select 'hello ' || 'world'
.ONLY_FULL_GROUP_BY
(Default): The SELECT LIST can only contain GROUP BY columns or aggregate functions.ALLOW_THROW_EXCEPTION
: returns an error instead of NULL when type conversion fails.FORBID_INVALID_DATE
: prohibits invalid dates.MODE_DOUBLE_LITERAL
: interprets floating-point types as DOUBLE rather than DECIMAL.SORT_NULLS_LAST
: places NULL values at the end after sorting.ERROR_IF_OVERFLOW
: returns an error instead of NULL in the case of arithmetic overflow. Currently, only the DECIMAL data type supports this option.GROUP_CONCAT_LEGACY
: uses thegroup_concat
syntax of v2.5 and earlier. This option is supported from v3.0.9 and v3.1.6.
sql_safe_updates
sql_select_limit
- Description: Used to limit the maximum number of rows returned by a query, which can prevent issues such as insufficient memory or network congestion caused by the query returning too much data.
- Default: Unlimited
- Data type: Long
statistic_collect_parallel
- Description: Used to adjust the parallelism of statistics collection tasks that can run on BEs. Default value: 1. You can increase this value to speed up collection tasks.
- Default: 1
- Data type: Int
storage_engine
- olap (default): StarRocks system-owned engine.
- mysql: MySQL external tables.
- broker: Access external tables through a broker program.
- elasticsearch or es: Elasticsearch external tables.
- hive: Hive external tables.
- iceberg: Iceberg external tables, supported from v2.1.
- hudi: Hudi external tables, supported from v2.2.
- jdbc: external table for JDBC-compatible databases, supported from v2.3.
streaming_preaggregation_mode
auto
: The system first tries local preaggregation. If the effect is not satisfactory, it switches to the streaming mode. This is the default value.force_preaggregation
: The system directly performs local preaggregation.force_streaming
: The system directly performs streaming.
