Data Cache
From v3.1.7 and v3.2.3 onwards, StarRocks introduced Data Cache to accelerate queries in shared-data clusters, replacing File Cache in earlier versions. Data Cache loads data from remote storage in blocks (on the order of MBs) as needed, while File Cache loads entire data files each time in the background, regardless of how many data rows are actually needed.
Compared to File Cache, Data Cache has the following advantages:
- Fewer reads from object storage, meaning less cost on access to object storage (if your object storage charges based on access frequency).
- Less write pressure on local disks and CPU usage, thus less impact on other loading or query tasks (because background loading threads are no longer needed).
- Optimized cache effectiveness (because File Cache may load less frequently used data in the file).
- Optimized control over the cached data, thus avoiding overwhelmed local disks caused by excessive data failed to be evicted by File Cache.
Enable Data Cache
From v3.2.3 onwards, Data Cache is enabled by default. If you want to use Data Cache in a v3.1 cluster, or you have manually disabled this feature previously, you need to perform the following procedures to enable it.
To dynamically enable Data Cache at runtime, execute the following statement:
UPDATE information_schema.be_configs SET VALUE = 1
WHERE name = "starlet_use_star_cache";
Dynamic configurations will become invalid after the CN nodes are restarted.
To permanently enable Data Cache, you need to add the following configuration to the CN configuration file cn.conf, and restart the CN nodes:
starlet_use_star_cache = true
Configure Data Cache
You can configure Data Cache using the following CN(BE) configuration items:
- storage_root_path (In shared-data clusters, this item is used to specify the root path where the cached data is stored.)
- starlet_use_star_cache
- starlet_star_cache_disk_size_percent
If you have enabled File Cache before upgrading your StarRocks cluster to v3.1.7, v3.2.3, or later versions, please check whether you have modified the configuration item starlet_cache_evict_high_water
. The default value of this item is 0.2
, indicating that File Cache will use 80% of the storage space to store the cached data files. If you have modified this item, you must configure starlet_star_cache_disk_size_percent
accordingly during upgrading. Suppose you have previously set starlet_cache_evict_high_water
to 0.3
. When upgrading your StarRocks cluster, you need to set starlet_star_cache_disk_size_percent
to 70
to ensure that Data Cache will use the same percentage of disk capacity as you set for File Cache.
View Data Cache status
Execute the following statement to check whether Data Cache is enabled:
WHERE NAME LIKE "%starlet_use_star_cache%"; -
Execute the following statement to view the root path that stores the cached data:
WHERE NAME LIKE "%storage_root_path%";The cached data is stored under the sub-path
starlet_cache/star_cache
of yourstorage_root_path
Execute the following statement to view the maximum percentage of storage that Data Cache can use:
WHERE NAME LIKE "%starlet_star_cache_disk_size_percent%";
Monitor Data Cache
StarRocks provides various metrics that monitor Data Cache.
Dashboard templates
You can download the following Grafana Dashboard templates based on your StarRocks environment:
- Dashboard template for StarRocks shared-data cluster on virtual machines
- Dashboard template for StarRocks shared-data cluster on Kubernetes
For more instructions on deploying monitoring and alert services for StarRocks, see Monitor and alert.
Important metrics
fslib read io_latency
Records the read latency of Data Cache.
fslib write io_latency
Records the write latency of Data Cache.
Records the estimated memory usage of Data Cache.
Records the actual disk usage of Data Cache.
Disable Data Cache
To dynamically disable Data Cache at runtime, execute the following statement:
UPDATE information_schema.be_configs SET VALUE = 0
To permanently disable Data Cache, you need to add the following configuration to the CN configuration file cn.conf, and restart the CN nodes:
starlet_use_star_cache = false
Clear cached data
You can clear the cached data in case of emergencies. This will not affect the original data in your remote storage.
Follow these steps to clear the cached data on a CN node:
Remove the sub-directory that stores the data, that is,
${storage_root_path}/starlet_cache
.Example:
# Suppose `storage_root_path = /data/disk1;/data/disk2`
rm -rf /data/disk1/starlet_cache/
rm -rf /data/disk2/starlet_cache/ -
Restart the CN node.
Usage notes
- If the
datacache.enable
property is set tofalse
for a cloud-native table, Data Cache will not be enabled for the table. - If the
datacache.partition_duration
property is set to a specific time range, data beyond the time range will not be cached.
Known issues
High memory usage
- Description: While the cluster is running under low-load conditions, the total memory usage of the CN node is far beyond the sum of each module's memory usage.
- Identification: If the sum of
andfslib star cache data memory size
takes a significant proportion of the total memory usage of the CN node, it might indicate this issue. - Affected versions: v3.1.8 and earlier patch versions, and v3.2.3 and earlier patch versions
- Fixed versions: v3.1.9, v3.2.4
- Solutions:
- Upgrade the cluster to the fixed versions.
- If you do not want to upgrade the cluster, you can clear the directory
${storage_root_path}/starlet_cache/star_cache/meta
of the CN nodes, and restart the nodes.
Q&A
Q1: Why does the Data Cache directory occupy much larger storage space (observed through du
and ls
commands) than the actual size of cached data?
The disk space occupied by Data Cache represents the historical peak usage and is irrelevant to the current actual cached data size. For example, if 100 GB of data is cached, the data size will become 200 GB after compaction. Then, after garbage collection (GC), the data size was reduced to 100 GB. However, the disk space occupied by Data Cache will remain at its peak of 200 GB, even though the actual cached data within is 100 GB.
Q2: Does Data Cache automatically evict data?
No. Data Cache evicts data only when it reaches the disk usage limit (80%
of the disk space by default). The eviction process does not delete the data; it merely marks the disk space that stores the old cache as empty. The new cache will then overwrite the old cache. Therefore, even if eviction occurs, the disk usage will not decrease and will not affect actual usage.
Q3: Why does the disk usage remain at the configured maximum level and not decrease?
Refer to Q2. Data Cache eviction mechanism does not delete the cached data but marks the old data as overwritable. Hence, the disk usage will not decrease.
Q4: Why does the disk usage of Data Cache remain at the same level after I dropped a table and the table files are deleted from remote storage?
Dropping a table does not trigger the deletion of data in the Data Cache. The cache of the deleted table will gradually be evicted over time based on Data Cache's LRU (Least Recently Used) logic, and this does not affect actual usage.
Q5: Why does the actual disk usage reach 90% or more even though 80% disk capacity is configured?
The disk usage by Data Cache is accurate and will not exceed the configured limit. The excessive disk usage may be caused by:
- Log files generated during runtime.
- Core files generated by CN crashes.
- Persistent indexes of Primary Key tables (stored under
${storage_root_path}/persist/
). - Mixed deployments of BE/CN/FE instances sharing the same disk.
- External table caches (stored under
${STARROCKS_HOME}/block_cache/
). - Disk issues, for example, the ext3 file system is used.
You can execute du -h . -d 1
in the disk root directory or sub-directories to check the specific space-occupying directories, and then delete the unexpected portions. You can also reduce the disk capacity limit of Data Cache by configuring starlet_star_cache_disk_size_percent
Q6: Why is there a significant difference in disk usage of Data Cache between nodes?
It is impossible to ensure consistent cache usage across nodes due to the inherent limitations of single-node caching. As long as it does not affect query latency, differences in cache usage are acceptable. This discrepancy may be caused by:
- Different time points at which the nodes were added to the cluster.
- Differences in the number of tablets owned by different nodes.
- Differences in the size of data owned by different tablets.
- Differences in compaction and GC situations across nodes.
- Nodes experiencing crashes or Out-Of-Memory (OOM) issues.
In summary, the differences in cache usage are influenced by multiple factors.
