版本:Latest-4.1
ds_theta_count_distinct
返回类似于 COUNT(DISTINCT col) 结果的聚合函数的近似值。ds_theta_count_distinctCOUNT(DISTINCT col) 更快,并且在处理高基数列时使用更少的内存。
ds_theta_count_distinct 类似于 APPROX_COUNT_DISTINCT(expr)DS_HLL_COUNT_DISTINCT(expr),但由于采用了 Apache DataSketches,因此精度不同。更多信息请参见 Theta Sketches
相对误差为 3.125%(95% 置信度)。更多信息请参见 relative error table
BIGINT ds_theta_count_distinct(expr)
  • expr: 要计算近似 COUNT DISTINCT 值的列。
mysql> CREATE TABLE t1 (
-> id BIGINT NOT NULL,
-> province VARCHAR(64),
-> age SMALLINT,
-> dt VARCHAR(10) NOT NULL
-> DUPLICATE KEY(id)
mysql> select ds_theta_count_distinct(id), ds_theta_count_distinct(province), ds_theta_count_distinct(age), ds_theta_count_distinct(dt) from t1 order by 1, 2;
| ds_theta_count_distinct(id) | ds_theta_count_distinct(province) | ds_theta_count_distinct(age) | ds_theta_count_distinct(dt) |
| 100215 | 100846 | 100 | 1 |
1 row in set (0.62 sec)
关键词
DS_THETA_COUNT_DISTINCT,DS_HLL_COUNT_DISTINCT,APPROX_COUNT_DISTINCT
