Version: Latest-4.1
variant_query
Queries the value of an element that can be located by the path expression in a VARIANT object and returns a VARIANT value.
This function is used to navigate and extract sub-elements from VARIANT data read from Iceberg tables in Parquet format.
variant_query(variant_expr, path)
  • variant_expr: the expression that represents the VARIANT object. This is typically a VARIANT column from an Iceberg table.
  • path: the expression that represents the path to an element in the VARIANT object. The value of this parameter is a string. The path syntax is similar to JSON path:
    • $ represents the root element
    • . is used to access object fields
    • [index] is used to access array elements (0-based indexing)
    • Field names with special characters can be quoted: $."field.name"
Returns a VARIANT value.
If the element does not exist or the path is invalid, the function returns NULL.
Example 1: Query the root element of a VARIANT value.
SELECT variant_query(data, '$') AS root_data
FROM bluesky
LIMIT 1;
| root_data |
| {"commit":{"collection":"app.bsky.graph.follow","operation":"delete","rev":"3lcgs4mw...} |
Example 2: Query a nested field in a VARIANT object.
SELECT variant_query(data, '$.commit') AS commit_info
FROM bluesky
LIMIT 1;
| commit_info |
Example 3: Check the type of nested fields using variant_typeof.
variant_typeof(variant_query(data, '$.commit')) AS commit_type,
variant_typeof(variant_query(data, '$.time_us')) AS time_type
FROM bluesky
LIMIT 1;
| commit_type | time_type |
| Object | Int64 |
Example 4: Cast the result to a SQL type.
SELECT CAST(variant_query(data, '$.commit') AS STRING) AS commit_info
FROM bluesky
LIMIT 1;
| commit_info |
| {"cid":"bafyreia3k...","collection":"app.bsky.feed.repost","operation":"create"...} |
Example 5: Filter using variant_query results.
SELECT COUNT(*) AS total
FROM bluesky
WHERE variant_query(data, '$.commit.record') IS NOT NULL;
| total |
| 9500118 |
keyword​
VARIANT_QUERY,VARIANT
