encode_sort_key
Creates an order-preserving composite binary key from multiple heterogeneous input columns. This function is essential for creating efficient sort keys that maintain the original sort order when compared lexicographically.
encode_sort_key(column1, column2, ..., columnN)
  • column1, column2, ..., columnN: One or more columns of any supported data type. The function accepts a variable number of arguments.
Returns a value of the VARBINARY type representing the composite sort key.
Supported data types​
The following data types are supported:
Data TypeDescription
TINYINT8-bit signed integer
SMALLINT16-bit signed integer
INT32-bit signed integer
BIGINT64-bit signed integer
LARGEINT128-bit signed integer
FLOAT32-bit floating point
DOUBLE64-bit floating point
VARCHARVariable-length string
CHARFixed-length string
DATEDate value
DATETIMEDate and time value
TIMESTAMPTimestamp value
The following complex types are not supported and will return an error:
  • JSON
  • ARRAY
  • MAP
  • STRUCT
  • HLL
  • BITMAP
  • PERCENTILE
Encoding strategy​
The function uses different encoding strategies for different data types to ensure that lexicographic comparison of the resulting binary keys preserves the original sort order:
  • Integer types: Big-endian byte order with sign bit flipped for signed types
  • Floating-point types: Custom encoding to ensure correct sort order
  • String types: Special encoding with 0x00 byte escaping and 0x00 0x00 terminator for non-last fields
  • Date/Time types: Internal integer representation encoded as integral value
NULL handling​
  • Each column gets a NULL marker (0x00 for NULL, 0x01 for NOT NULL) for every row
  • NULL markers are added even for non-nullable columns to ensure consistent encoding
  • A separator byte (0x00) is used between columns (except after the last column)
Generated sort key column​
CREATE TABLE user_analytics (
user_id INT,
region VARCHAR(50),
score DOUBLE,
created_date DATE,
sort_key VARBINARY(1024) AS (
encode_sort_key(region, score, created_date)
) ORDER BY (sort_key);
JSON field extraction​
CREATE TABLE json_data (
id INT,
json_content JSON,
encode_sort_key(
get_json_int(json_content, '$.priority'),
get_json_string(json_content, '$.category'),
get_json_double(json_content, '$.score')
Limitations​
Data type restrictions​
Complex types like JSON, ARRAY, MAP, and STRUCT cannot be directly encoded. Use JSON extraction functions to get primitive values:
-- Instead of: encode_sort_key(json_col)
-- Use: encode_sort_key(get_json_int(json_col, '$.field1'), get_json_string(json_col, '$.field2'))
Performance considerations​
  • Each call to encode_sort_key requires encoding all input columns
  • Binary keys can be significantly larger than original data
  • Use generated columns to avoid repeated encoding
Key size limitations​
  • Keep the number of columns reasonable (typically < 10)
  • Prefer shorter string columns when possible
  • Consider using hash functions for very long strings
