percentile_disc
percentile_disc
Returns a percentile value based on a discrete distribution of the input column expr. If the exact percentile value cannot be found, this function returns the larger value between the two closest values.
This function is supported from v2.5 onwards.
  • expr: the column for which you want to calculate the percentile value. The column can be of any data type that is sortable.
  • percentile: the percentile of the value you want to find. It must be a constant floating-point number between 0 and 1. For example, if you want to find the median value, set this parameter to 0.5. If you want to find the value at the 70th percentile, specify 0.7.
The data type of the return value is the same as expr.
Usage notes​
NULL values are ignored in the calculation.
Create table exam and insert data into this table.
CREATE TABLE exam (
subject STRING,
score INT
INSERT INTO exam VALUES
('chemistry',80),
('chemistry',100),
('chemistry',null),
('math',60),
('math',70),
('math',85),
('physics',75),
('physics',80),
('physics',85),
('physics',99);
| subject | score |
| chemistry | 80 |
| chemistry | 100 |
| chemistry | NULL |
| math | 60 |
| math | 70 |
| math | 85 |
| physics | 75 |
| physics | 80 |
| physics | 85 |
| physics | 99 |
Calculate the median of each subject.
select subject, percentile_disc(score, 0.5)
from exam group by subject;
Output
| chemistry | 100 |
| math | 70 |
| physics | 85 |
