percentile_approx_raw
Returns the value that corresponds to a specified percentile from x.
If x is a column, this function first sorts values in x in ascending order and returns the value that corresponds to percentile y.
PERCENTILE_APPROX_RAW(x, y);
  • x: It can be a column or a set of values. It must evaluate to PERCENTILE.
  • y: the percentile. The supported data type is DOUBLE. Value range: [0.0,1.0].
Returns a PERCENTILE value.
Create table aggregate_tbl, where the percent column is the input of percentile_approx_raw().
CREATE TABLE `aggregate_tbl` (
`site_id` largeint(40) NOT NULL COMMENT "id of site",
`date` date NOT NULL COMMENT "time of event",
`city_code` varchar(20) NULL COMMENT "city_code of user",
`pv` bigint(20) SUM NULL DEFAULT "0" COMMENT "total page views",
`percent` PERCENTILE PERCENTILE_UNION COMMENT "others"
AGGREGATE KEY(`site_id`, `date`, `city_code`)
DISTRIBUTED BY HASH(`site_id`)
Insert data into the table.
insert into aggregate_tbl values (5, '2020-02-23', 'city_code', 555, percentile_hash(1));
insert into aggregate_tbl values (5, '2020-02-23', 'city_code', 555, percentile_hash(2));
insert into aggregate_tbl values (5, '2020-02-23', 'city_code', 555, percentile_hash(3));
insert into aggregate_tbl values (5, '2020-02-23', 'city_code', 555, percentile_hash(4));
Calculate the value corresponding to percentile 0.5.
mysql> select percentile_approx_raw(percent, 0.5) from aggregate_tbl;
| percentile_approx_raw(percent, 0.5) |
| 2.5 |
1 row in set (0.03 sec)
StarRocks Assistant
