Version: Candidate-4.1
map_from_arrays
Creates a MAP value from the given pair of key item array and value item array.
MAP map_from_arrays(ARRAY keys, ARRAY values)
  • keys: uses to construct the keys of the result MAP. Make sure the elements of keys are unique.
  • values: used to construct the values of the result MAP.
Returns a MAP that is constructed from the input keys and values.
  • Keys and values must have the same length, otherwise it will return an error.
  • If key or value is NULL, this function returns NULL.
  • The returned MAP value has distinct keys.
select map_from_arrays([1, 2], ['Star', 'Rocks']);
| map_from_arrays([1, 2], ['Star', 'Rocks']) |
| {1:"Star",2:"Rocks"} |
select map_from_arrays([1, 2], NULL);
| map_from_arrays([1, 2], NULL) |
select map_from_arrays([1,3,null,2,null],['ab','cdd',null,null,'abc']);
| map_from_arrays([1, 3, NULL, 2, NULL], ['ab', 'cdd', NULL, NULL, 'abc']) |
| {1:"ab",3:"cdd",2:null,null:"abc"} |
