regexp_count
Counts the number of times a pattern occurs in a string. It returns the number of occurrences of the regular expression pattern in the target string.
INT regexp_count(VARCHAR str, VARCHAR pattern)
  • str: The string to search in. Supported data type is VARCHAR. If the input is NULL, NULL is returned.
  • pattern: The regular expression pattern to search for. Supported data type is VARCHAR. If the pattern is NULL, NULL is returned.
Returns an INT representing the count of occurrences. Returns 0 if no matches are found or if the input string is empty.
tip
This example uses the Local Climatological Data(LCD) dataset featured in the StarRocks Basics Quick Start. You can load the data and try the example yourself.
-- Count occurrences of digits
SELECT regexp_count('abc123def456', '[0-9]');
| regexp_count('abc123def456', '[0-9]') |
| 6 |
-- Count occurrences of dots
SELECT regexp_count('test.com test.net test.org', '\\.');
| regexp_count('test.com test.net test.org', '\\.') |
| 3 |
-- Count occurrences of whitespace sequences
SELECT regexp_count('a b c d', '\\s+');
| regexp_count('a b c d', '\\s+') |
| 3 |
-- Count occurrences of a repeated pattern
SELECT regexp_count('ababababab', 'ab');
| regexp_count('ababababab', 'ab') |
| 5 |
-- Using with NULL and empty values
regexp_count('', '.') AS empty_str,
regexp_count(NULL, '.') AS null_str,
regexp_count('abc', NULL) AS null_pattern;
| empty_str | null_str | null_pattern |
| 0 | NULL | NULL |
-- Count occurrence of Unicode/Chinese characters
SELECT regexp_count('abc中文def', '[\\p{Han}]+');
| regexp_count('abc中文def', '[\\p{Han}]+') |
With table data
CREATE TABLE sample_text (
str VARCHAR(65533) NULL,
regex VARCHAR(65533) NULL
INSERT INTO sample_text VALUES
('abc123def456', '[0-9]'),
('test.com test.net test.org', '\\.'),
('a b c d', '\\s+'),
SELECT str, regex, regexp_count(str, regex) AS count
FROM sample_text
ORDER BY str;
| str | regex| count |
| a b c d | \s+ | 3 |
| abc123def456 | [0-9]| 6 |
| ababababab | ab | 5 |
| test.com test.net test.org | \. | 3 |
keyword
REGEXP_COUNT,REGEXP,COUNT
