Version: Latest-4.1
array_top_n
Sorts the elements of a given array in their natural descending order, and returns the top-n elements in an array. If n is larger than the length of the input array, the length of the returned array will be the same as the input instead of n.
array_top_n(array, count)
  • array: The array from which to extract the top-n elements. The array can contain elements of any comparable data type supported by StarRocks.
  • count: The number of top elements to return. It must be a non-negative integer.
Returns an array containing the top-n elements from the input array, sorted in descending order. The data type of the return value is the same ARRAY type as the input array.
Usage notes​
  • Elements are sorted in descending order according to their natural ordering.
  • If count is 0 or negative, an empty array is returned.
  • If count is larger than the array size, the entire array, sorted in descending order, is returned.
  • If the input array or count is NULL, the result is NULL.
  • NULL elements within the array are considered smaller than any non-NULL value and will appear at the end if included in the result.
Example 1: Get the top 3 elements from an integer array.
mysql> SELECT array_top_n([1, 100, 2, 5, 3], 3);
| array_top_n([1,100,2,5,3], 3) |
| [100,5,3] |
Example 2: Get the top 5 elements from an array of two integers (count is larger than the array length).
mysql> SELECT array_top_n([1, 100], 5);
| array_top_n([1,100], 5) |
| [100,1] |
Example 3: Get the top 3 elements from a string array.
mysql> SELECT array_top_n(['a', 'zzz', 'zz', 'b', 'g', 'f'], 3);
| array_top_n(['a','zzz','zz','b','g','f'], 3) |
| ['zzz','zz','g'] |
Example 4: Call the function when count is 0.
mysql> SELECT array_top_n([1, 2, 3], 0);
| array_top_n([1,2,3], 0) |
Example 5: Get the top 3 elements from an integer array where NULL is one of the elements.
mysql> SELECT array_top_n([1, NULL, 3, 2], 3);
| array_top_n([1,null,3,2], 3) |
| [3,2,1] |
Example 6: Call the function with table data.
mysql> CREATE TABLE IF NOT EXISTS test (id INT, arr ARRAY<INT>) PROPERTIES ("replication_num"="1");
mysql> INSERT INTO test VALUES (1, [5, 2, 8, 1, 9]), (2, [10, 3, 7]);
mysql> SELECT id, array_top_n(arr, 2) FROM test;
| id | array_top_n(arr, 2) |
| 1 | [9,8] |
| 2 | [10,7] |
