Version: Latest-4.1
MIN_N, MAX_N
Returns the n smallest or largest values from an expression as an array.
These functions are supported from v4.0.
MIN_N(<expr>, <n>)
MAX_N(<expr>, <n>)
  • expr: An expression of any sortable type (STRING, BOOLEAN, DATE, DATETIME, or numeric type).
  • n: An INTEGER literal greater than 0. The maximum value is 10000.
  • MIN_N: Returns an ARRAY containing the n smallest values from the expression, sorted in ascending order.
  • MAX_N: Returns an ARRAY containing the n largest values from the expression, sorted in ascending order.
The array elements have the same type as the input expression.
  • If the number of distinct values is less than n, returns all values.
  • NULL values are ignored.
  • If all values are NULL, returns an empty array.
Basic usage with MIN_N and MAX_N​
  1. Create a table scores.
    CREATE TABLE scores (
    student_id INT,
    subject STRING,
    score INT
    ) DISTRIBUTED BY HASH(`student_id`);
  2. Insert values into this table.
    INSERT INTO scores VALUES
    (1, 'math', 85),
    (2, 'math', 92),
    (3, 'math', 78),
    (4, 'math', 95),
    (5, 'math', 88),
    (6, 'math', 82),
    (7, 'math', 90),
    (8, 'math', 87),
    (9, 'math', 93),
    (10, 'math', 89);
  3. Get the 3 smallest and 3 largest scores.
    MIN_N(score, 3) AS min_3_scores,
    MAX_N(score, 3) AS max_3_scores
    FROM scores;
    | min_3_scores | max_3_scores |
    | [85,82,78] | [90,92,95] |
  4. Get the smallest and largest scores by subject.
    subject,
    MIN_N(score, 2) AS min_2_scores,
    MAX_N(score, 2) AS max_2_scores
    FROM scores
    GROUP BY subject;
    | subject | min_2_scores | max_2_scores |
    | math | [82,78] | [92,95] |
Using with string values​
CREATE TABLE products (
id INT,
name STRING,
price DECIMAL(10,2)
) DISTRIBUTED BY HASH(`id`);
INSERT INTO products VALUES
(1, 'apple', 2.50),
(2, 'banana', 1.80),
(3, 'cherry', 4.20),
(4, 'date', 3.10),
(5, 'elderberry', 5.50);
MIN_N(name, 3) AS min_3_names,
MAX_N(name, 3) AS max_3_names
FROM products;
| min_3_names | max_3_names |
| [cherry,banana,apple] | [cherry,date,elderberry] |
Edge case: n larger than number of values​
MIN_N(score, 15) AS all_scores_min,
MAX_N(score, 15) AS all_scores_max
FROM scores;
| all_scores_min | all_scores_max |
| [95,93,92,90,89,88,87,85,82,78] | [78,82,85,87,88,89,90,92,93,95] |
Using with date values​
CREATE TABLE events (
id INT,
event_name STRING,
event_date DATE
INSERT INTO events VALUES
(1, 'conference', '2024-03-15'),
(2, 'workshop', '2024-01-20'),
(3, 'seminar', '2024-05-10'),
(4, 'meeting', '2024-02-28'),
(5, 'training', '2024-04-05');
MIN_N(event_date, 3) AS earliest_3_dates,
MAX_N(event_date, 3) AS latest_3_dates
FROM events;
| earliest_3_dates | latest_3_dates |
| [2024-03-15,2024-02-28,2024-01-20] | [2024-03-15,2024-04-05,2024-05-10] |
keyword​
MIN_N, MAX_N
