Information Schema
The StarRocks Information Schema is a database within each StarRocks instance. Information Schema contains several read-only, system-defined views that store extensive metadata information of all objects that the StarRocks instance maintains. The StarRocks Information Schema is based on the SQL-92 ANSI Information Schema, but with the addition of views and functions that are specific to StarRocks.
From v3.2.0, The StarRocks Information Schema supports manage metadata for external catalogs.
View metadata via Information Schemaβ
You can view the metadata information within a StarRocks instance by querying the content of views in Information Schema.
The following example checks metadata information about a table named table1 in StarRocks by querying the view tables.
TABLE_CATALOG: def
TABLE_SCHEMA: test_db
TABLE_NAME: table1
TABLE_TYPE: BASE TABLE
ENGINE: StarRocks
VERSION: NULL
ROW_FORMAT:
TABLE_ROWS: 4
AVG_ROW_LENGTH: 1657
DATA_LENGTH: 6630
MAX_DATA_LENGTH: NULL
INDEX_LENGTH: NULL
DATA_FREE: NULL
AUTO_INCREMENT: NULL
CHECK_TIME: NULL
CHECKSUM: NULL
CREATE_OPTIONS:
TABLE_COMMENT:
Views in Information Schemaβ
The StarRocks Information Schema contains the following metadata views:
ποΈ analyze_status
analyze_status provides information about the status of analyze jobs.
ποΈ applicable_roles
applicable_roles provides information about roles that are applicable to the current user.
ποΈ be_bvars
be_bvars provides statistical information regarding bRPC. You can view RPC latency, QPS, and other statistics for some components of StarRocks.
ποΈ be_cloud_native_compactions
becloudnativecompactions provides information on compaction transactions running on CNs (or BEs for v3.0) of a shared-data cluster. A compaction transaction is divided into multiple tasks on the partition level, and each row in becloudnativecompactions corresponds to a task in the compaction transaction.
ποΈ be_compactions
be_compactions provides statistical information on compaction tasks.
ποΈ be_configs
be_configs provides information about the configuration parameters of each BE node.
ποΈ be_logs
be_logs provides information about the logs of each BE node.
ποΈ be_metrics
be_metrics provides information about the metrics of each BE node.
ποΈ be_tablets
be_tablets provides information about tablets on each BE node.
ποΈ be_threads
be_threads provides information about the threads running on each BE node.
ποΈ be_txns
be_txns provides information about transactions on each BE node.
ποΈ character_sets
character_sets identifies the character sets available.
ποΈ collations
collations contains the available collations.
ποΈ column_privileges
This view does not apply to the available features in StarRocks.
ποΈ column_stats_usage
columnstatsusage provides information about the usage of column statistics.
ποΈ columns
columns contains information about all table columns (or view columns).
ποΈ engines
ποΈ events
ποΈ fe_metrics
fe_metrics provides information about the metrics of each FE node.
ποΈ fe_tablet_schedules
fetabletschedules provides information about tablet scheduling tasks on FE nodes.
ποΈ global_variables
global_variables provides information about global variables.
ποΈ key_column_usage
ποΈ load_tracking_logs
loadtrackinglogs provides error logs of load jobs. This view is supported from StarRocks v3.0 onwards.
ποΈ loads
loads provides the results of load jobs. This view is supported from StarRocks v3.1 onwards.
π οΈ materialized_views
materialized_views provides information about all materialized views.
ποΈ partitions
ποΈ partitions_meta
partitions_meta provides information about partitions of tables.
ποΈ pipe_files
pipe_files provides the status of the data files to be loaded via a specified pipe. This view is supported from StarRocks v3.2 onwards.
ποΈ pipes
pipes provides information about all pipes stored in the current or specified database. This view is supported from StarRocks v3.2 onwards.
ποΈ recyclebin_catalogs
recyclebin_catalogs provides metadata information of deleted databases, tables, and partitions temporarily stored in the FE recycle bin.
ποΈ referential_constraints
ποΈ routine_load_jobs
routineloadjobs provides information about routine load jobs.
ποΈ routines
ποΈ schema_privileges
ποΈ schemata
schemata provides information about databases.
ποΈ session_variables
session_variables provides information about session variables.
ποΈ statistics
ποΈ stream_loads
stream_loads provides information about stream load jobs.
ποΈ table_constraints
ποΈ table_privileges
ποΈ tables
tables provides information about tables.
ποΈ tables_config
tables_config provides information about the configuration of tables.
ποΈ task_runs
task_runs provides information about the execution of asynchronous tasks.
ποΈ tasks
tasks provides information about asynchronous tasks.
ποΈ triggers
ποΈ user_privileges
ποΈ verbose_session_variables
verbosesessionvariables provides detailed information about session variables, including their default values and whether they have been changed from the default.
ποΈ views
views provides information about all user-defined views.
ποΈ warehouse_metrics
warehouse_metrics provides information about the metrics of each warehouse.
ποΈ warehouse_queries
warehouse_queries provides information about queries running on each warehouse.
