Version: 3.1
Deploy StarRocks with Operator
This topic introduces how to use the StarRocks Operator to automate the deployment and management of a StarRocks cluster on a Kubernetes cluster.
note
The StarRocks Operator is designed to be a level 2 operator. To understand more about the capabilities of a level 2 operator, see Operator Capability Levels.
How it works​
Before you begin​
Create Kubernetes cluster​
You can use the cloud-managed Kubernetes service, such as an Amazon Elastic Kubernetes Service (EKS) or Google Kubernetes Engine (GKE) cluster, or a self-managed Kubernetes cluster.
Deploy StarRocks Operator​
  1. Add the custom resource StarRocksCluster.
    kubectl apply -f https://raw.githubusercontent.com/StarRocks/starrocks-kubernetes-operator/main/deploy/starrocks.com_starrocksclusters.yaml
  2. Deploy the StarRocks Operator. You can choose to deploy the StarRocks Operator by using a default configuration file or a custom configuration file.
    1. Deploy the StarRocks Operator by using a default configuration file.
      kubectl apply -f https://raw.githubusercontent.com/StarRocks/starrocks-kubernetes-operator/main/deploy/operator.yaml
      The StarRocks Operator is deployed to the namespace starrocks and manages all StarRocks clusters under all namespaces.
    2. Deploy the StarRocks Operator by using a custom configuration file.
      • Download the configuration file operator.yaml, which is used to deploy the StarRocks Operator.
        curl -O https://raw.githubusercontent.com/StarRocks/starrocks-kubernetes-operator/main/deploy/operator.yaml
      • Modify the configuration file operator.yaml to suit your needs.
      • Deploy the StarRocks Operator.
        kubectl apply -f operator.yaml
  3. Check the running status of the StarRocks Operator. If the pod is in the Running state and all containers inside the pod are READY, the StarRocks Operator is running as expected.
    $ kubectl -n starrocks get pods
    NAME READY STATUS RESTARTS AGE
    starrocks-controller-65bb8679-jkbtg 1/1 Running 0 5m6s
If you customize the namespace in which the StarRocks Operator is located, you need to replacestarrocks with the name of your customized namespace.
Deploy StarRocks Cluster​
You can directly use the sample configuration files provided by StarRocks to deploy a StarRocks cluster (an object instantiated by using the custom resource StarRocks Cluster). For example, you can use starrocks-fe-and-be.yaml to deploy a StarRocks cluster that contains three FE nodes and three BE nodes.
kubectl apply -f https://raw.githubusercontent.com/StarRocks/starrocks-kubernetes-operator/main/examples/starrocks/starrocks-fe-and-be.yaml
The following table describes a few important fields in the starrocks-fe-and-be.yaml file.
FieldDescription
KindThe resource type of the object. The value must be StarRocksCluster.
MetadataMetadata, in which the following sub-fields are nested:
  • name: the name of the object. Each object name uniquely identifies an object of the same resource type.
  • namespace: the namespace to which the object belongs.
SpecThe expected status of the object. Valid values are starRocksFeSpec, starRocksBeSpec, and starRocksCnSpec.
You can also deploy the StarRocks cluster by using a modified configuration file. For supported fields and detailed descriptions, see api.md.
Deploying the StarRocks cluster takes a while. During this period, you can use the command kubectl -n starrocks get pods to check the starting status of the StarRocks cluster. If all the pods are in the Running state and all containers inside the pods are READY, the StarRocks cluster is running as expected.
If you customize the namespace in which the StarRocks cluster is located, you need to replace starrocks with the name of your customized namespace.
starrocks-controller-65bb8679-jkbtg 1/1 Running 0 22h
starrockscluster-sample-be-0 1/1 Running 0 23h
starrockscluster-sample-be-1 1/1 Running 0 23h
starrockscluster-sample-be-2 1/1 Running 0 22h
starrockscluster-sample-fe-0 1/1 Running 0 21h
starrockscluster-sample-fe-1 1/1 Running 0 21h
starrockscluster-sample-fe-2 1/1 Running 0 22h
Note
If some pods cannot start after a long period of time, you can use kubectl logs -n starrocks <pod_name> to view the log information or use kubectl -n starrocks describe pod <pod_name> to view the event information to locate the problem.
Manage StarRocks Cluster​
Access StarRocks Cluster​
The components of the StarRocks cluster can be accessed through their associated Services, such as the FE Service. For detailed descriptions of Services and their access addresses, see api.md and Services.
  • Only the FE Service is deployed by default. If you need to deploy the BE Service and CN Service, you need to configure starRocksBeSpec and starRocksCnSpec in the StarRocks cluster configuration file.
  • The name of a Service is <cluster name>-<component name>-service by default, for example, starrockscluster-sample-fe-service. You can also specify the Service name in the spec of each component.
Access StarRocks Cluster from within Kubernetes Cluster​
From within the Kubernetes cluster, the StarRocks cluster can be accessed through the FE Service's ClusterIP.
  1. Obtain the internal virtual IP address CLUSTER-IP and port PORT(S) of the FE Service.
    $ kubectl -n starrocks get svc
    NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
    be-domain-search ClusterIP None <none> 9050/TCP 23m
    fe-domain-search ClusterIP None <none> 9030/TCP 25m
    starrockscluster-sample-fe-service ClusterIP 10.100.162.xxx <none> 8030/TCP,9020/TCP,9030/TCP,9010/TCP 25m
  2. Access the StarRocks cluster by using the MySQL client from within the Kubernetes cluster.
    mysql -h 10.100.162.xxx -P 9030 -uroot
Access StarRocks Cluster from outside Kubernetes Cluster​
From outside the Kubernetes cluster, you can access the StarRocks cluster through the FE Service's LoadBalancer or NodePort. This topic uses LoadBalancer as an example:
  1. Run the command kubectl -n starrocks edit src starrockscluster-sample to update the StarRocks cluster configuration file, and change the Service type of starRocksFeSpec to LoadBalancer.
    starRocksFeSpec:
    image: starrocks/fe-ubuntu:3.0-latest
    replicas: 3
    requests:
    cpu: 4
    memory: 16Gi
    service:
    type: LoadBalancer # specified as LoadBalancer
  2. Obtain the IP address EXTERNAL-IP and port PORT(S) that the FE Service exposes to the outside.
    be-domain-search ClusterIP None <none> 9050/TCP 127m
    fe-domain-search ClusterIP None <none> 9030/TCP 129m
    starrockscluster-sample-fe-service LoadBalancer 10.100.162.xxx a7509284bf3784983a596c6eec7fc212-618xxxxxx.us-west-2.elb.amazonaws.com 8030:30629/TCP,9020:32544/TCP,9030:32244/TCP,9010:32024/TCP 129m ClusterIP None <none> 9030/TCP 23h
  3. Log in to your machine host and access the StarRocks cluster by using the MySQL client.
    mysql -h a7509284bf3784983a596c6eec7fc212-618xxxxxx.us-west-2.elb.amazonaws.com -P9030 -uroot
Upgrade StarRocks Cluster​
Upgrade BE nodes​
Run the following command to specify a new BE image file, such as starrocks/be-ubuntu:latest:
kubectl -n starrocks patch starrockscluster starrockscluster-sample --type='merge' -p '{"spec":{"starRocksBeSpec":{"image":"starrocks/be-ubuntu:latest"}}}'
Upgrade FE nodes​
Run the following command to specify a new FE image file, such as starrocks/fe-ubuntu:latest:
kubectl -n starrocks patch starrockscluster starrockscluster-sample --type='merge' -p '{"spec":{"starRocksFeSpec":{"image":"starrocks/fe-ubuntu:latest"}}}'
The upgrade process lasts for a while. You can run the command kubectl -n starrocks get pods to view the upgrade progress.
Scale StarRocks cluster​
Scale out BE cluster​
Run the following command to scale the BE cluster to 9 nodes:
kubectl -n starrocks patch starrockscluster starrockscluster-sample --type='merge' -p '{"spec":{"starRocksBeSpec":{"replicas":9}}}'
Scale in BE cluster​
When scaling in BE nodes, you need to scale them one at a time, and wait for the tablets on the BEs to be re-distributed before proceeding. If there are tables with single replicas, taking a BE node offline may cause data loss if the tablets fail to be redistributed.
Execute the following command to scale in a cluster with 10 BE nodes to 9.
After scaling in, you must manually drop the nodes whose alive status is false.
The redistribution of tablets will take some time. You can check the progress by executing SHOW PROC '/statistic';.
Scale out FE cluster​
Run the following command to scale out the FE cluster to 4 nodes:
kubectl -n starrocks patch starrockscluster starrockscluster-sample --type='merge' -p '{"spec":{"starRocksFeSpec":{"replicas":4}}}'
The scaling process lasts for a while. You can use the command kubectl -n starrocks get pods to view the scaling progress.
Automatic scaling for CN cluster​
Run the command kubectl -n starrocks edit src starrockscluster-sample to configure the automatic scaling policy for the CN cluster. You can specify the resource metrics for CNs as the average CPU utilization, average memory usage, elastic scaling threshold, upper elastic scaling limit, and lower elastic scaling limit. The upper elastic scaling limit and lower elastic scaling limit specify the maximum number and minimum number of CNs allowed for elastic scaling.
If the automatic scaling policy for the CN cluster is configured, delete the replicas field from the starRocksCnSpec in the StarRocks cluster configuration file.
Kubernetes also supports using behavior to customize scaling behaviors according to business scenarios, helping you achieve rapid or slow scaling or disable scaling. For more information about automatic scaling policies, see Horizontal Pod Scaling.
The following is a template provided by StarRocks to help you configure automatic scaling policies:
  starRocksCnSpec:
image: starrocks/cn-ubuntu:latest
limits:
cpu: 16
memory: 64Gi
requests:
cpu: 16
memory: 64Gi
autoScalingPolicy: # Automatic scaling policy of the CN cluster.
maxReplicas: 10 # The maximum number of CNs is set to 10.
minReplicas: 1 # The minimum number of CNs is set to 1.
# operator creates an HPA resource based on the following field.
# see https://kubernetes.io/docs/tasks/run-application/horizontal-pod-autoscale/ for more information.
hpaPolicy:
metrics: # Resource metrics
- type: Resource
resource:
name: memory # The average memory usage of CNs is specified as a resource metric.
target:
# The elastic scaling threshold is 60%.
# When the average memory utilization of CNs exceeds 60%, the number of CNs increases for scale-out.
# When the average memory utilization of CNs is below 60%, the number of CNs decreases for scale-in.
averageUtilization: 60
type: Utilization
- type: Resource
resource:
name: cpu # The average CPU utilization of CNs is specified as a resource metric.
target:
# When the average CPU utilization of CNs exceeds 60%, the number of CNs increases for scale-out.
# When the average CPU utilization of CNs is below 60%, the number of CNs decreases for scale-in.
type: Utilization
behavior: # The scaling behavior is customized according to business scenarios, helping you achieve rapid or slow scaling or disable scaling.
scaleUp:
policies:
- type: Pods
value: 1
periodSeconds: 10
scaleDown:
selectPolicy: Disabled
The following table describes a few important fields:
  • The upper and lower elastic scaling limit.
  • The elastic scaling threshold.
# For example, the average CPU utilization of CNs is specified as a resource metric.
- type: Resource
resource:
target:
FAQ​
Issue description: When a custom resource StarRocksCluster is installed using kubectl apply -f xxx, an error is returned The CustomResourceDefinition 'starrocksclusters.starrocks.com' is invalid: metadata.annotations: Too long: must have at most 262144 bytes.
Cause analysis: Whenever kubectl apply -f xxx is used to create or update resources, a metadata annotation kubectl.kubernetes.io/last-applied-configuration is added. This metadata annotation is in JSON format and records the last-applied-configuration. kubectl apply -f xxx" is suitable for most cases, but in rare situations , such as when the configuration file for the custom resource is too large, it may cause the size of the metadata annotation to exceed the limit.
Solution: If you install the custom resource StarRocksCluster for the first time, it is recommended to use kubectl create -f xxx. If the custom resource StarRocksCluster is already installed in the environment, and you need to update its configuration, it is recommended to use kubectl replace -f xxx.
