bitmap_to_binary
Converts Bitmap values to a Binary string.
bitmap_to_binary is mainly used for exporting Bitmap data. The compression effect is better than bitmap_to_base64.
If you plan to export data directly to a binary file such as Parquet, this function is recommended.
VARBINARY bitmap_to_binary(BITMAP bitmap)
bitmap: the Bitmap to convert, required. If the input value is invalid, an error is returned.
Returns a value of the VARBINARY type.
Example 1: Use this function with other bitmap functions.
mysql> select hex(bitmap_to_binary(bitmap_from_string("0, 1, 2, 3")));
| hex(bitmap_to_binary(bitmap_from_string('0, 1, 2, 3'))) |
| 023A3000000100000000000300100000000000010002000300 |
mysql> select hex(bitmap_to_binary(to_bitmap(1)));
| hex(bitmap_to_binary(to_bitmap(1))) |
| 0101000000 |
mysql> select hex(bitmap_to_binary(bitmap_empty()));
| hex(bitmap_to_binary(bitmap_empty())) |
| 00 |
Example 2: Convert each value in a BITMAP column into a binary string.
  1. Create an Aggregate table page_uv where the AGGREGATE KEY is (page_id, visit_date). This table contains a BITMAP column visit_users whose values are to be aggregated.
        CREATE TABLE `page_uv`
    (`page_id` INT NOT NULL,
    "storage_format" = "DEFAULT"
  2. Insert data into this table.
      insert into page_uv values
  3. Convert each value in the visit_users column into a binary-encoded string.
       mysql> select page_id, hex(bitmap_to_binary(visit_users)) from page_uv;
    | page_id | hex(bitmap_to_binary(visit_users)) |
    | 1 | 0A030000000D0000000000000017000000000000002100000000000000 |
    | 1 | 010D000000 |
    | 2 | 0117000000 |
    3 rows in set (0.01 sec)
StarRocks Assistant
