bitmap_to_array
Converts a BITMAP into a BIGINT array.
 ARRAY<BIGINT> BITMAP_TO_ARRAY (bitmap)
bitmap: the bitmap you want to convert.
Returns a BIGINT array.
select bitmap_to_array(bitmap_from_string("1, 7"));
| bitmap_to_array(bitmap_from_string('1, 7')) |
| [1,7] |
select bitmap_to_array(NULL);
| bitmap_to_array(NULL) |
StarRocks Assistant
