For AI agents: a machine-readable documentation index is available at https://docs.starrocks.io/llms.txt. Every documentation page is also available as Markdown by appending ".md" to its URL.
Converts a binary value to a VARCHAR string based on the specified binary format (binary_type). The following binary formats are supported: hex, encode64, and utf8. If no binary_type is specified, hex is the default.
