Version: Candidate-4.0
all_match
Returns whether all elements of an array match the given predicate.
  • Returns true (1) if all the elements match the predicate (a special case is when the array is empty).
  • Returns false (0) if one or more elements do not match.
  • Returns NULL if the predicate returns NULL for one or more elements and true for all other elements.
This function is supported from v3.0.6 onwards.
Returns whether all elements of arr1 match the given predicate in the lambda function.
  • arr1: the array to match.
  • arrN: optional arrays used in the lambda function.
  • lambda_function: the lambda function used to match values.
Returns a BOOLEAN value.
Usage notes​
  • The lambda function follows the usage notes in array_map().
  • If the input array is null or the lambda function results in null, null is returned.
  • If arr1 is empty, true is returned.
  • To apply this function to MAP, rewrite all_match((k,v)->k>v,map) to all_match(map_values(transform_values((k,v)->k>v, map))). For example, select all_match(map_values(transform_values((k,v)->k>v, map{2:1}))); returns 1.
Check whether all elements in x are less than the elements in y.
| 0 |
