System variables
If you want to make a setting change for the current session and also make that setting change apply to all future sessions, you can make the change twice, once without the
GLOBALmodifier and once with it. For example:SET query_mem_limit = 137438953472; -- Apply to the current session.
Variable hierarchy and typesβ
- Global variables take effect on global level, and can be overridden by session variables and
SET_VARhints. - Session variables take effect only on the current session, and can be overridden by
SET_VARhints. SET_VARhints take effect only on the current query statement.
View variablesβ
SHOW VARIABLES;
Set variablesβ
Set variables globally or for a single sessionβ
SET forward_to_master = true;
- activate_all_roles_on_login
- character_set_database
- default_rowset_type
- enable_query_queue_select
- enable_query_queue_load
- init_connect
- lower_case_table_names
- license
- language
- query_cache_size
- system_time_zone
- version_comment
- version
Set variables in a single query statementβ
- SELECT
- INSERT (from v3.1.12 and v3.2.0 onwards)
- UPDATE (from v3.1.12 and v3.2.0 onwards)
- DELETE (from v3.1.12 and v3.2.0 onwards)
Example:
FROM my_table PARTITION p1
WHERE k1 = 3;
INTO insert_wiki_edit
SELECT * FROM FILES(
"format" = "parquet",
"aws.s3.region" = "us-west-2"
SELECT /*+ SET_VAR
query_timeout=10000000,
batch_size=4096,
*/ * FROM TABLE;
Set variables as user propertiesβ
Example:
Descriptions of variablesβ
activate_all_roles_on_login (global)β
- Description: Whether to enable all roles (including default roles and granted roles) for a StarRocks user when the user connects to the StarRocks cluster.
- If enabled (
true), all roles of the user are activated at user login. This takes precedence over the roles set by SET DEFAULT ROLE. - If disabled (
false), the roles set by SET DEFAULT ROLE are activated.
- If enabled (
- Default: false
- Introduced in: v3.0
auto_increment_incrementβ
autocommitβ
chunk_sizeβ
- Description: Used to specify the number of rows of a single packet transmitted by each node during query execution. The default is 4096, i.e., every 4096 rows of data generated by the source node is packaged and sent to the destination node. A larger number of rows will improve the query throughput in large data volume scenarios, but may increase the query latency in small data volume scenarios. Also, it may increase the memory overhead of the query. We recommend to set
batch_sizebetween 1024 to 4096. - Default: 4096
big_query_profile_thresholdβ
Description: Used to set the threshold for big queries. When the session variable
enable_profileis set tofalseand the amount of time taken by a query exceeds the threshold specified by the variablebig_query_profile_threshold, a profile is generated for that query.Note: In versions v3.1.5 to v3.1.7, as well as v3.2.0 to v3.2.2, we introduced the
big_query_profile_second_thresholdfor setting the threshold for big queries. In versions v3.1.8, v3.2.3, and subsequent releases, this parameter has been replaced bybig_query_profile_thresholdto offer more flexible configuration options. -
Default: 0
Unit: Second
Data type: String
Introduced in: v3.1
catalogβ
- Description: Used to specify the catalog to which the session belongs.
- Default: default_catalog
- Data type: String
- Introduced in: v3.2.4
cbo_decimal_cast_string_strictβ
- Description: Controls how the CBO converts data from the DECIMAL type to the STRING type. If this variable is set to
true, the logic built in v2.5.x and later versions prevails and the system implements strict conversion (namely, the system truncates the generated string and fills 0s based on the scale length). If this variable is set tofalse, the logic built in versions earlier than v2.5.x prevails and the system processes all valid digits to generate a string. - Default: true
- Introduced in: v2.5.14
cbo_enable_low_cardinality_optimizeβ
- Description: Whether to enable low cardinality optimization. After this feature is enabled, the performance of querying STRING columns improves by about three times.
- Default: true
cbo_eq_base_typeβ
- Description: Specifies the data type used for data comparison between DECIMAL data and STRING data. The default value is
DECIMAL, and VARCHAR is also a valid value. This variable takes effect only for=and!=comparison. - Data type: String
cbo_json_v2_dict_optβ
- Description: Whether to enable low-cardinality dictionary optimization for Flat JSON (JSON v2) extended string subcolumns created by JSON path rewrite. When enabled, the optimizer may build and use global dictionaries for those subcolumns to accelerate string expressions, GROUP BY, and JOIN operations.
- Default: true
- Data type: Boolean
cbo_json_v2_rewriteβ
- Description: Whether to enable JSON v2 path rewrite in the optimizer. When enabled, JSON functions (such as
get_json_*) can be rewritten to direct access of Flat JSON subcolumns, enabling predicate pushdown, column pruning, and dictionary optimization. - Default: true
cbo_materialized_view_rewrite_related_mvs_limitβ
- Description: Specifies the maximum number of candidate materialized views allowed during query planning.
- Default: 64
- Introduced in: v3.1.9, v3.2.5
cbo_prune_subfieldβ
- Description: Whether to enable JSON subfield pruning. This variable must be used with the BE dynamic parameter
enable_json_flat. Otherwise, it may degrade JSON data query performance. - Default: false
- Data type: Int
- Introduced in: v3.3.0
custom_query_id (session)β
- Description: Used to bind some external identifier to a current query. Can be set using
SET SESSION custom_query_id = 'my-query-id';before executing a query. The value is reset after query is finished. This value can be passed toKILL QUERY 'my-query-id'. Value can be found in audit logs as acustomQueryIdfield. - Default: ""
- Data type: String
- Introduced in: v3.4.0
enable_sync_materialized_view_rewriteβ
- Description: Whether to enable query rewrite based on synchronous materialized views.
- Default: true
- Introduced in: v3.1.11, v3.2.5
query_including_mv_namesβ
- Description: Specifies the name of the asynchronous materialized views to include in query execution. You can use this variable to limit the number of candidate materialized views and improve the query rewrite performance in the optimizer. This item takes effect prior to
query_excluding_mv_names. - Default: empty
- Data type: String
query_excluding_mv_namesβ
- Description: Specifies the name of the asynchronous materialized views to exclude from query execution. You can use this variable to limit the number of candidate materialized views and reduce the time of query rewrite in the optimizer.
query_including_mv_namestakes effect prior to this item. - Default: empty
- Data type: String
optimizer_materialized_view_timelimitβ
- Description: Specifies the maximum time that one materialized view rewrite rule can consume. When the threshold is reached, this rule will not be used for query rewrite.
- Default: 1000
- Unit: ms
enable_materialized_view_agg_pushdown_rewriteβ
- Description: Whether to enable aggregation pushdown for materialized view query rewrite. If it is set to
true, aggregate functions will be pushed down to Scan Operator during query execution and rewritten by the materialized view before the Join Operator is executed. This will relieve the data expansion caused by Join and thereby improve the query performance. For detailed information about the scenarios and limitations of this feature, see Aggregation pushdown. - Default: false
enable_materialized_view_text_match_rewriteβ
- Description: Whether to enable text-based materialized view rewrite. When this item is set to true, the optimizer will compare the query with the existing materialized views. A query will be rewritten if the abstract syntax tree of the materialized view's definition matches that of the query or its sub-query.
- Default: true
- Introduced in: v3.2.5, v3.3.0
materialized_view_subuqery_text_match_max_countβ
- Description: Specifies the maximum number of times that the system checks whether a query's sub-query matches the materialized views' definition.
- Default: 4
enable_force_rule_based_mv_rewriteβ
- Description: Whether to enable query rewrite for queries against multiple tables in the optimizer's rule-based optimization phase. Enabling this feature will improve the robustness of the query rewrite. However, it will also increase the time consumption if the query misses the materialized view.
- Default: true
enable_view_based_mv_rewriteβ
- Description: Whether to enable query rewrite for logical view-based materialized views. If this item is set to
true, the logical view is used as a unified node to rewrite the queries against itself for better performance. If this item is set tofalse, the system transcribes the queries against logical views into queries against physical tables or materialized views and then rewrites them. - Default: false
- Introduced in: v3.1.9, v3.2.5, v3.3.0
enable_materialized_view_union_rewriteβ
- Description: Whether to enable materialized view union rewrite. If this item is set to
true, the system seeks to compensate the predicates using UNION ALL when the predicates in the materialized view cannot satisfy the query's predicates. - Default: true
- Introduced in: v2.5.20, v3.1.9, v3.2.7, v3.3.0
enable_materialized_view_plan_cacheβ
- Description: Whether to enable materialized view plan cache, which can optimize the automatic rewrite performance of materialized views. Setting it to
trueindicates enabling it. - Default: true
- Introduced in: v2.5.13, v3.0.7, v3.1.4, v3.2.0, v3.3.0
enable_cbo_based_mv_rewriteβ
- Description: Whether to enable materialized view rewrite in CBO phase which can maximize the likelihood of successful query rewriting (e.g., when the join order differs between materialized views and queries), but it will increase the execution time of the optimizer phase.
- Default: true
- Introduced in: v3.5.5, v4.0.1
enable_parquet_reader_bloom_filterβ
- Description: Whether to enable the bloom filter of Parquet file to improve performance.
trueindicates enabling the bloom filter, andfalseindicates disabling it. You can also control this behavior on system level using the BE configurationparquet_reader_bloom_filter_enable. Bloom filters in Parquet are maintained at the column level within each row group. If a Parquet file contains bloom filters for certain columns, queries can use predicates on those columns to efficiently skip row groups. - Default: true
enable_plan_advisorβ
- Description: Whether to enable Query Feedback feature for slow queries and manually marked queries.
- Default: true
enable_plan_analyzerβ
- Description: Whether to enable Query Feedback feature for all queries. This variable takes effect only when
enable_plan_advisoris set totrue. - Default: false
- Default: true
- Type: Boolean
- Unit: -
- Description: Whether to enable Bloom Filter optimization when reading Parquet files.
true(Default): Enable Bloom Filter optimization when reading Parquet files.false: Disable Bloom Filter optimization when reading Parquet files.
- Introduced in: v3.5.0
enable_parquet_reader_page_indexβ
- Default: true
- Type: Boolean
- Unit: -
- Description: Whether to enable Page Index optimization when reading Parquet files.
true(Default): Enable Page Index optimization when reading Parquet files.false: Disable Page Index optimization when reading Parquet files.
follower_query_forward_modeβ
Description: Specifies to which FE nodes the query statements are routed.
Valid values:
default: Routes the query statement to the Leader FE or Follower FEs, depending on the Follower's replay progress. If the Follower FE nodes have not completed replay progress, queries will be routed to the Leader FE node. If the replay progress is complete, queries will be preferentially routed to the Follower FE node.leader: Routes the query statement to the Leader FE.follower: Routes the query statement to Follower FE.
Default: default
Data type: String
character_set_database (global)β
- Data type: StringThe character set supported by StarRocks. Only UTF8 (
utf8) is supported. - Default: utf8
- Data type: String
connector_io_tasks_per_scan_operatorβ
- Description: The maximum number of concurrent I/O tasks that can be issued by a scan operator during external table queries. The value is an integer. Currently, StarRocks can adaptively adjust the number of concurrent I/O tasks when querying external tables. This feature is controlled by the variable
enable_connector_adaptive_io_tasks, which is enabled by default. - Default: 16
- Data type: Int
connector_sink_compression_codecβ
- Description: Specifies the compression algorithm used for writing data into Hive tables or Iceberg tables, or exporting data with Files(). This parameter only takes effect in the following situations:
- The
compression_codecproperty does not exist in the Hive tables. - The
write.parquet.compression-codecproperties do not exist in the Iceberg tables. - The
compressionproperty is not set forINSERT INTO FILES.
- The
- Valid values:
uncompressed,snappy,lz4,zstd, andgzip. - Default: uncompressed
- Data type: String
- Introduced in: v3.2.3
connector_sink_target_max_file_sizeβ
- Description: Specifies the maximum size of target file for writing data into Hive tables or Iceberg tables, or exporting data with Files(). The limit is not exact and is applied on a best-effort basis.
- Unit: Bytes
- Default: 1073741824
- Data type: Long
count_distinct_column_bucketsβ
- Description: The number of buckets for the COUNT DISTINCT column in a group-by-count-distinct query. This variable takes effect only when
enable_distinct_column_bucketizationis set totrue. - Default: 1024
default_rowset_type (global)β
default_table_compressionβ
Description: The default compression algorithm for table storage. Supported compression algorithms are
snappy, lz4, zlib, zstd.Note that if you specified the
compressionproperty in a CREATE TABLE statement, the compression algorithm specified bycompressiontakes effect. -
Default: lz4_frame
Introduced in: v3.0
disable_colocate_joinβ
- Description: Used to control whether the Colocation Join is enabled. The default value is
false, meaning the feature is enabled. When this feature is disabled, query planning will not attempt to execute Colocation Join. - Default: false
disable_streaming_preaggregationsβ
div_precision_incrementβ
dynamic_overwriteβ
- Description: Whether to enable the Dynamic Overwrite semantic for INSERT OVERWRITE with partitioned tables. Valid values:
true: Enables Dynamic Overwrite.false: Disables Dynamic Overwrite and uses the default semantic.
- Default: false
enable_datacache_async_populate_modeβ
- Description: Whether to populate the data cache in asynchronous mode. By default, the system uses the synchronous mode to populate data cache, that is, populating the cache while querying data.
- Default: false
- Introduced in: v3.2.7
enable_connector_adaptive_io_tasksβ
- Description: Whether to adaptively adjust the number of concurrent I/O tasks when querying external tables. Default value is
true. If this feature is not enabled, you can manually set the number of concurrent I/O tasks using the variableconnector_io_tasks_per_scan_operator. - Default: true
enable_distinct_column_bucketizationβ
Description: Whether to enable bucketization for the COUNT DISTINCT colum in a group-by-count-distinct query. Use the
select a, count(distinct b) from t group by a;query as an example. If the GROUP BY columais a low-cardinality column and the COUNT DISTINCT columnbis a high-cardinality column which has severe data skew, performance bottleneck will occur. In this situation, you can split data in the COUNT DISTINCT column into multiple buckets to balance data and prevent data skew. You must use this variable with the variablecount_distinct_column_buckets.You can also enable bucketization for the COUNT DISTINCT column by adding the
skewhint to your query, for example,select a,count(distinct [skew] b) from t group by a;. -
Default: false, which means this feature is disabled.
Introduced in: v2.5
enable_group_by_compressed_keyβ
- Description: Whether to use accurate statistical information to compress the GROUP BY Key column. Valid values:
trueandfalse. - Default: true
- Introduced in: v4.0
enable_gin_filterβ
- Description: Whether to utilize the fulltext inverted index during queries.
- Default: true
enable_group_executionβ
- Description: Whether to enable Colocate Group Execution. Colocate Group Execution is an execution pattern that leverages physical data partitioning, where a fixed number of threads sequentially process their respective data ranges to enhance locality and throughput. Enabling this feature can reduce memory usage.
- Default: true
enable_group_level_query_queue (global)β
- Description: Whether to enable resource group-level query queue.
- Default: false, which means this feature is disabled.
- Introduced in: v3.1.4
enable_insert_partial_updateβ
- Description: Whether to enable Partial Update for INSERT statements on Primary Key tables. When this item is set to
true(default), if an INSERT statement specifies only a subset of columns (fewer than the number of all non-generated columns in the table), the system performs a Partial Update to update only the specified columns while preserving existing values in other columns. When set tofalse, the system uses default values for unspecified columns instead of preserving existing values. This feature is particularly useful for updating specific columns in Primary Key tables without affecting other column values. - Default: true
- Introduced in: v3.3.20, v3.4.9, v3.5.8, v4.0.2
enable_iceberg_metadata_cacheβ
- Description: Whether to cache pointers and partition names for Iceberg tables. From v3.2.1 to v3.2.3, this parameter is set to
trueby default, regardless of what metastore service is used. In v3.2.4 and later, if the Iceberg cluster uses AWS Glue as metastore, this parameter still defaults totrue. However, if the Iceberg cluster uses other metastore service such as Hive metastore, this parameter defaults tofalse. - Introduced in: v3.2.1
max_unknown_string_meta_length (global)β
- Description: Fallback length for string columns in query result metadata when the max length is unknown. Clients that rely on the metadata may return empty values or truncation if the reported length is smaller than actual values. Valid range is
1to1048576. - Default: 64
- Data Type: int
- Introduced in: v3.5.13
enable_metadata_profileβ
- Description: Whether to enabled Profile for Iceberg Catalog metadata.
- Default: true
- Introduced in: v3.3.3
plan_modeβ
- Description: The metadata retrieval strategy of Iceberg Catalog. For more information, see Iceberg Catalog metadata retrieval strategy. Valid values:
auto: The system will automatically select the retrieval plan.local: Use the local cache plan.distributed: Use the distributed plan.
- Default: auto
enable_iceberg_column_statisticsβ
- Description: Whether to obtain column statistics, such as
min,max,null count,row size, andndv(if a puffin file exists). When this item is set tofalse, only the row count information will be collected. - Default: false
enable_parallel_mergeβ
- Description: Whether to enable parallel merge for sorting. When this feature is enabled, the merge phase of sorting will utilize multiple threads for merge operations.
- Default: true
enable_per_bucket_optimizeβ
- Description: Whether to enable bucketed computation. When this feature is enabled, stage-one aggregation can be computed in bucketed order, reducing memory usage.
- Default: true
metadata_collect_query_timeoutβ
- Description: The timeout duration for Iceberg Catalog metadata collection queries.
- Unit: Second
- Default: 60
enable_insert_strictβ
- Description: Whether to enable strict mode while loading data using INSERT from files(). Valid values:
trueandfalse(Default). When strict mode is enabled, the system loads only qualified rows. It filters out unqualified rows and returns details about the unqualified rows. For more information, see Strict mode. In versions earlier than v3.4.0, whenenable_insert_strictis set totrue, the INSERT jobs fails when there is an unqualified rows. - Default: true
insert_max_filter_ratioβ
- Description: The maximum error tolerance of INSERT from files(). It's the maximum ratio of data records that can be filtered out due to inadequate data quality. When the ratio of unqualified data records reaches this threshold, the job fails. Range: [0, 1].
- Default: 0
insert_timeoutβ
- Description: The timeout duration of the INSERT job. Unit: Seconds. From v3.4.0 onwards,
insert_timeoutapplies to operations involved INSERT (for example, UPDATE, DELETE, CTAS, materialized view refresh, statistics collection, and PIPE), replacingquery_timeout. - Default: 14400
enable_materialized_view_for_insertβ
- Description: Whether to allow StarRocks to rewrite queries in INSERT INTO SELECT statements.
- Default: false, which means Query Rewrite in such scenarios is disabled by default.
- Introduced in: v2.5.18, v3.0.9, v3.1.7, v3.2.2
enable_rule_based_materialized_view_rewriteβ
- Description: Controls whether to enable rule-based materialized view query rewrite. This variable is mainly used in single-table query rewrite. * Default: true
enable_short_circuitβ
- Description: Whether to enable short circuiting for queries. Default:
false. If it is set totrue, when the query meets the criteria (to evaluate whether the query is a point query): the conditional columns in the WHERE clause include all primary key columns, and the operators in the WHERE clause are=orIN, the query takes the short circuit. - Default: false
enable_spm_rewriteβ
- Description: Whether to enable SQL Plan Manager (SPM) query rewrite. When enabled, StarRocks automatically rewrites queries to use bound query plans, improving query performance and stability.
- Default: false
enable_spillβ
- Description: Whether to enable intermediate result spilling. Default:
false. If it is set totrue, StarRocks spills the intermediate results to disk to reduce the memory usage when processing aggregate, sort, or join operators in queries. - Default: false
enable_spill_to_remote_storageβ
- Description: Whether to enable intermediate result spilling to object storage. If it is set to
true, StarRocks spills the intermediate results to the storage volume specified inspill_storage_volumeafter the capacity limit of the local disk is reached. For more information, see Spill to object storage. - Default: false
enable_strict_order_byβ
- Description: Used to check whether the column name referenced in ORDER BY is ambiguous. When this variable is set to the default value
TRUE, an error is reported for such a query pattern: Duplicate alias is used in different expressions of the query and this alias is also a sorting field in ORDER BY, for example,select distinct t1.* from tbl1 t1 order by t1.k1;. The logic is the same as that in v2.3 and earlier. When this variable is set toFALSE, a loose deduplication mechanism is used, which processes such queries as valid SQL queries. - Default: true
- Introduced in: v2.5.18 and v3.1.7
enable_profileβ
Description: Specifies whether to send the profile of a query for analysis. The default value is
false, which means no profile is required.By default, a profile is sent to the FE only when a query error occurs in the BE. Profile sending causes network overhead and therefore affects high concurrency.
If you need to analyze the profile of a query, you can set this variable to
true. After the query is completed, the profile can be viewed on the web page of the currently connected FE (address:fe_host:fe_http_port/query). This page displays the profiles of the latest 100 queries withenable_profileturned on. -
Default: false
enable_query_queue_load (global)β
- Description: Boolean value to enable query queues for loading tasks.
- Default: false
enable_query_queue_select (global)β
- Description: Whether to enable query queues for SELECT queries.
- Default: false
enable_query_queue_statistic (global)β
- Description: Whether to enable query queues for statistics queries.
- Default: false
enable_query_tablet_affinityβ
Description: Boolean value to control whether to direct multiple queries against the same tablet to a fixed replica.
However, if there are some hotspot tablets, this feature may degrade the query performance because it directs the queries to the same BE, making it unable to fully use the resources of multiple BEs in high concurrency scenarios.
Default: false, which means the system selects a replica for each query.
Introduced in: v2.5.6, v3.0.8, v3.1.4, and v3.2.0.
enable_lake_tablet_internal_parallelβ
- Description: Whether to enable Parallel Scan for Cloud-native tables in a shared-data cluster.
- Default: true
tablet_internal_parallel_modeβ
- Description: Internal Parallel Scan strategy of tablets. Valid Values:
auto: When the number of Tablets to be scanned on BE or CN nodes is less than the Degree of Parallelism (DOP), the system automatically determines whether Parallel Scan is needed based on the estimated size of the Tablets.force_split: Forces the splitting of Tablets and performs Parallel Scan.
- Default: auto
- Data type: String
- Introduced in: v2.5.0
enable_scan_datacacheβ
- Description: Specifies whether to enable the Data Cache feature. After this feature is enabled, StarRocks caches hot data read from external storage systems into blocks, which accelerates queries and analysis. For more information, see Data Cache. In versions prior to 3.2, this variable was named as
enable_scan_block_cache. - Default: true
populate_datacache_modeβ
- Description: Specifies the population behavior of Data Cache when reading data blocks from external storage systems. Valid values:
auto(default): the system automatically caches data selectively based on the population rule.always: Always cache the data.never: Never cache the data.
- Default: auto
enable_datacache_io_adaptorβ
- Description: Whether to enable the Data Cache I/O Adaptor. Setting this to
trueenables the feature. When this feature is enabled, the system automatically routes some cache requests to remote storage when the disk I/O load is high, reducing disk pressure. - Default: true
enable_file_metacacheβ
- Description: Whether to enable metadata cache for files in remote storage (Footer Cache). Setting this to
trueenables the feature. Footer Cache directly caches the parsed Footer object in memory. When the same file's Footer is accessed in subsequent queries, the object descriptor can be obtained directly from the cache, avoiding repetitive parsing. This feature uses the memory module of the Data Cache for data caching. Therefore, you must ensure that the BE parameterdatacache_enableis set totrueand configure a reasonable value fordatacache_mem_size. - Default: true
enable_file_pagecacheβ
- Description: Whether to enable Page Cache for files in remote storage. Setting this to
trueenables the feature. Page Cache stores decompressed Parquet page data in memory. When the same page is accessed in subsequent queries, the data can be obtained directly from the cache, avoiding repetitive I/O operations and decompression. This feature works together with the Data Cache and uses the same memory module. When enabled, Page Caache can significantly improve query performance for workloads with repetitive page access patterns. - Default: true
enable_datacache_sharingβ
- Description: Whether to enable Cache Sharing. Setting this to
trueenables the feature. Cache Sharing is used to support accessing cache data from other nodes through the network, which can help to reduce performance jitter caused by cache invalidation during cluster scaling. This variable takes effect only when the FE parameterenable_trace_historical_nodeis set totrue. - Default: true
datacache_sharing_work_periodβ
- Description: The period of time that Cache Sharing takes effect. After each cluster scaling operation, only the requests within this period of time will try to access the cache data from other nodes if the Cache Sharing feature is enabled.
- Default: 600
- Unit: Seconds
historical_nodes_min_update_intervalβ
- Description: The minimum interval between two updates of historical node records. If the nodes of a cluster change frequently in a short period of time (that is, less than the value set in this variable), some intermediate states will not be recorded as valid historical node snapshots. The historical nodes are the main basis for the Cache Sharing feature to choose the right cache nodes during cluster scaling.
- Default: 600
- Unit: Seconds
enable_tablet_internal_parallelβ
- Description: Whether to enable adaptive parallel scanning of tablets. After this feature is enabled, multiple threads can be used to scan one tablet by segment, increasing the scan concurrency.
- Default: true
- Introduced in: v2.3
enable_query_cacheβ
- Description: Specifies whether to enable the Query Cache feature. Valid values: true and false.
truespecifies to enable this feature, andfalsespecifies to disable this feature. When this feature is enabled, it works only for queries that meet the conditions specified in the application scenarios of Query Cache. - Default: false
enable_adaptive_sink_dopβ
- Description: Specifies whether to enable adaptive parallelism for data loading. After this feature is enabled, the system automatically sets load parallelism for INSERT INTO and Broker Load jobs, which is equivalent to the mechanism of
pipeline_dop. For a newly deployed v2.5 StarRocks cluster, the value istrueby default. For a v2.5 cluster upgraded from v2.4, the value isfalse. - Default: false
enable_bucket_aware_execution_on_lakeβ
- Description: Whether to enable bucket-aware execution for queries against data lakes (such as Iceberg tables). When this feature is enabled, the system optimizes query execution by leveraging bucketing information to reduce data shuffling and improve performance. This optimization is particularly effective for join operations and aggregations on bucketed tables.
- Default: true
lake_bucket_assign_modeβ
- Description: The bucket assignment mode for queries against tables in data lakes. This variable controls how buckets are distributed among worker nodes when bucket-aware execution takes effect during query execution. Valid values:
balance: Distributes buckets evenly across worker nodes to achieve balanced workload and better performance.elastic: Uses consistent hashing to assign buckets to worker nodes, which can provide better load distribution in elastic environments.
- Default: balance
- Data type: String
enable_pipeline_engineβ
- Description: Specifies whether to enable the pipeline execution engine.
trueindicates enabled andfalseindicates the opposite. Default value:true. - Default: true
enable_sort_aggregateβ
- Description: Specifies whether to enable sorted streaming.
trueindicates sorted streaming is enabled to sort data in data streams. - Default: false
enable_global_runtime_filterβ
enable_multicolumn_global_runtime_filterβ
- If this feature is disabled, only Local RF works.
- If this feature is enabled, multi-column Global RF takes effect and carries
multi-columnin the partition by clause.
enable_write_hive_external_tableβ
- Description: Whether to allow for sinking data to external tables of Hive.
- Default: false
enable_query_trigger_analyzeβ
- Default: true
- Type: Boolean
- Description: Whether to enable query-trigger ANALYZE tasks on tables under external catalogs.
event_schedulerβ
enable_strict_typeβ
- Description: Whether to allow implicit conversions for all compound predicates and for all expressions in the WHERE clause.
- Default: false
force_streaming_aggregateβ
forward_to_leaderβ
SHOW FRONTENDS: Forwarding to the leader FE allows users to view the last heartbeat message.
SHOW BACKENDS: Forwarding to the leader FE allows users to view the boot time, last heartbeat information, and disk capacity information.
SHOW BROKER: Forwarding to the leader FE allows users to view the boot time and last heartbeat information.
SHOW TABLET
ADMIN SHOW REPLICA STATUS: Forwarding to the leader FE allows users to view the tablet information stored in the metadata of the leader FE. Normally, the tablet information should be the same in the metadata of different FEs. If an error occurs, you can use this method to compare the metadata of the current FE and the leader FE.
Show PROC: Forwarding to the leader FE allows users to view the PROC information stored in the metadata. This is mainly used for metadata comparison.
group_concat_max_lenβ
- Description: The maximum length of string returned by the group_concat function.
- Default: 1024
- Min value: 4
- Unit: Characters
- Data type: Long
group_execution_max_groupsβ
- Description: Maximum number of groups allowed for Group Execution. It is used to limit the granularity of splitting, preventing excessive scheduling overhead caused by an excessive number of groups.
- Default: 128
group_execution_min_scan_rowsβ
- Description: Minimum number of rows processed per group for Group Execution.
- Default: 5000000
hash_join_push_down_right_tableβ
- Description: Used to control whether the data of the left table can be filtered by using the filter condition against the right table in the Join query. If so, it can reduce the amount of data that needs to be processed during the query.
Default:
trueindicates the operation is allowed and the system decides whether the left table can be filtered.falseindicates the operation is disabled. The default value istrue.
init_connect (global)β
interactive_timeoutβ
interpolate_passthroughβ
- Description: Whether to add local-exchange-passthrough for certain operators. Currently supported operators include streaming aggregates, etc. Adding local-exchange can mitigate the impact of data skew on computation, but will slightly increase memory usage.
- Default: true
- Description: The number of concurrent I/O tasks that can be issued by a scan operator. Increase this value if you want to access remote storage systems such as HDFS or S3 but the latency is high. However, a larger value causes more memory consumption.
- Default: 4
- Data type: Int
jit_levelβ
- Description: The level at which JIT compilation for expressions is enabled. Valid values:
1: The system adaptively enables JIT compilation for compilable expressions.-1: JIT compilation is enabled for all compilable, non-constant expressions.0: JIT compilation is disabled. You can disable it manually if any error is returned for this feature.
- Default: 1
- Data type: Int
- Introduced in: -
language (global)β
license (global)β
- Description: Displays the license of StarRocks.
- Default: Apache License 2.0
load_mem_limitβ
log_rejected_record_num (v3.1 and later)β
- The value
0specifies that data rows that are filtered out will not be logged. - The value
-1specifies that all data rows that are filtered out will be logged. - A non-zero positive integer such as
nspecifies that up tondata rows that are filtered out can be logged on each BE.
lower_case_table_names (global)β
lower_upper_support_utf8β
- Default: false
- Type: Boolean
- Unit: -
- Description: Whether to support case conversion for UTF-8 characters in
lowerandupperfunctions. Valid values:true: Support case conversion for UTF-8 characters.false(Default): Not to support case conversion for UTF-8 characters.
low_cardinality_optimize_on_lakeβ
- Default: true
- Type: Boolean
- Unit: -
- Description: Whether to enable low cardinality optimization on data lake queries. Valid values:
true(Default): Enable low cardinality optimization on data lake queries.false: Disable low cardinality optimization on data lake queries.
materialized_view_rewrite_mode (v3.2 and later)β
disable: Disable automatic query rewrite of asynchronous materialized views.default(Default value): Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, it directly scans the data in the base table.default_or_error: Enable automatic query rewrite of asynchronous materialized views, and allow the optimizer to decide whether a query can be rewritten using the materialized view based on the cost. If the query cannot be rewritten, an error is returned.force: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, it directly scans the data in the base table.force_or_error: Enable automatic query rewrite of asynchronous materialized views, and the optimizer prioritizes query rewrite using the materialized view. If the query cannot be rewritten, an error is returned.
max_allowed_packetβ
- Description: Used for compatibility with the JDBC connection pool C3P0. This variable specifies the maximum size of packets that can be transmitted between the client and server.
- Default: 33554432 (32 MB). You can raise this value if the client reports "PacketTooBigException".
- Unit: Byte
- Data type: Int
max_pushdown_conditions_per_columnβ
- Description: The maximum number of predicates that can be pushed down for a column.
- Default: -1, indicating that the value in the
be.conffile is used. If this variable is set to a value greater than 0, the value inbe.confis ignored. - Data type: Int
max_scan_key_numβ
- Description: The maximum number of scan key segmented by each query.
nested_mv_rewrite_max_levelβ
- Description: The maximum levels of nested materialized views that can be used for query rewrite.
- Value range: [1, +β). The value of
1indicates that only materialized views created on base tables can be used for query rewrite. - Default: 3
- Data type: Int
net_buffer_lengthβ
net_read_timeoutβ
net_write_timeoutβ
new_planner_optimize_timeoutβ
- Description: The timeout duration of the query optimizer. When the optimizer times out, an error is returned and the query is stopped, which affects the query performance. You can set this variable to a larger value based on your query or contact StarRocks technical support for troubleshooting. A timeout often occurs when a query has too many joins.
- Default: 3000
- Unit: ms
parallel_exchange_instance_numβ
parallel_fragment_exec_instance_numβ
parallel_merge_late_materialization_modeβ
- Description: The late materialization mode of parallel merge for sorting. Valid values:
AUTOALWAYSNEVER
- Default:
AUTO - Introduced in: v3.3
partial_update_modeβ
Description: Used to control the mode of partial updates. Valid values:
auto(default): The system automatically determines the mode of partial updates by analyzing the UPDATE statement and the columns involved.column: The column mode is used for the partial updates, which is particularly suitable for the partial updates which involve a small number of columns and a large number of rows.
Default: auto
Introduced in: v3.1
performance_schema (global)β
prefer_compute_nodeβ
- Description: Specifies whether the FEs distribute query execution plans to CN nodes. Valid values:
true: indicates that the FEs distribute query execution plans to CN nodes.false: indicates that the FEs do not distribute query execution plans to CN nodes.
- Default: false
- Introduced in: v2.4
pipeline_dopβ
Description: The parallelism of a pipeline instance, which is used to adjust the query concurrency. Default value: 0, indicating the system automatically adjusts the parallelism of each pipeline instance. This variable also controls the parallelism of loading jobs on OLAP tables. You can also set this variable to a value greater than 0. Generally, set the value to half the number of physical CPU cores. From v3.0 onwards, StarRocks adaptively adjusts this variable based on query parallelism.
Default: 0
Data type: Int
pipeline_sink_dopβ
- Description: The parallelism of sink for loading data into Iceberg tables and Hive tables, and unloading data using INSERT INTO FILES(). It is used to adjust the concurrency of these loading jobs. Default value: 0, indicating the system automatically adjusts the parallelism. You can also set this variable to a value greater than 0.
- Default: 0
- Data type: Int
pipeline_profile_levelβ
Description: Controls the level of the query profile. A query profile often has five layers: Fragment, FragmentInstance, Pipeline, PipelineDriver, and Operator. Different levels provide different details of the profile:
- 0: StarRocks combines metrics of the profile and shows only a few core metrics.
- 1: default value. StarRocks simplifies the profile and combines metrics of the profile to reduce profile layers.
- 2: StarRocks retains all the layers of the profile. The profile size is large in this scenario, especially when the SQL query is complex. This value is not recommended.
Default: 1
Data type: Int
query_cache_entry_max_bytesβ
- Description: The threshold for triggering the Passthrough mode. When the number of bytes or rows from the computation results of a specific tablet accessed by a query exceeds the threshold specified by
query_cache_entry_max_bytesorquery_cache_entry_max_rows, the query is switched to Passthrough mode. - Valid values: 0 to 9223372036854775807
- Default: 4194304
- Unit: Byte
query_cache_entry_max_rowsβ
- Description: The upper limit of rows that can be cached. See the description in
query_cache_entry_max_bytes. Default value: . - Default: 409600
query_cache_agg_cardinality_limitβ
- Description: The upper limit of cardinality for GROUP BY in Query Cache. Query Cache is not enabled if the rows generated by GROUP BY exceeds this value. Default value: 5000000. If
query_cache_entry_max_bytesorquery_cache_entry_max_rowsis set to 0, the Passthrough mode is used even when no computation results are generated from the involved tablets. - Default: 5000000
- Data type: Long
query_cache_size (global)β
query_cache_typeβ
query_mem_limitβ
- Description: Used to set the memory limit of a query on each BE node. The default value is 0, which means no limit for it. This item takes effect only after Pipeline Engine is enabled. When the
Memory Exceed Limiterror happens, you could try to increase this variable. Setting it to0indicates no limit is imposed. - Default: 0
- Unit: Byte
query_queue_concurrency_limit (global)β
- Description: The upper limit of concurrent queries on a BE. It takes effect only after being set greater than
0. Setting it to0indicates no limit is imposed. - Default: 0
- Data type: Int
query_queue_cpu_used_permille_limit (global)β
- Description: The upper limit of CPU usage permille (CPU usage * 1000) on a BE. It takes effect only after being set greater than
0. Setting it to0indicates no limit is imposed. - Value range: [0, 1000]
- Default:
0
query_queue_max_queued_queries (global)β
- Description: The upper limit of queries in a queue. When this threshold is reached, incoming queries are rejected. It takes effect only after being set greater than
1024.
query_queue_mem_used_pct_limit (global)β
- Description: The upper limit of memory usage percentage on a BE. It takes effect only after being set greater than
0. Setting it to0indicates no limit is imposed. - Value range: [0, 1]
- Default: 0
query_queue_pending_timeout_second (global)β
- Description: The maximum timeout of a pending query in a queue. When this threshold is reached, the corresponding query is rejected.
- Default: 300
- Unit: Second
query_timeoutβ
- Description: Used to set the query timeout in "seconds". This variable will act on all query statements in the current connection. The default value is 300 seconds. From v3.4.0 onwards,
query_timeoutdoes not apply to operations involved INSERT (for example, UPDATE, DELETE, CTAS, materialized view refresh, statistics collection, and PIPE). - Value range: [1, 259200]
- Default: 300
- Data type: Int
- Unit: Second
range_pruner_max_predicateβ
- Description: The maximum number of IN predicates that can be used for Range partition pruning. Default value: 100. A value larger than 100 may cause the system to scan all tablets, which compromises the query performance.
- Default: 100
rewrite_count_distinct_to_bitmap_hllβ
runtime_filter_on_exchange_nodeβ
Description: Whether to place GRF on Exchange Node after GRF is pushed down across the Exchange operator to a lower-level operator. The default value is
false, which means GRF will not be placed on Exchange Node after it is pushed down across the Exchange operator to a lower-level operator. This prevents repetitive use of GRF and reduces the computation time.However, GRF delivery is a "try-best" process. If the lower-level operator fails to receive the GRF but the GRF is not placed on Exchange Node, data cannot be filtered, which compromises filter performance.
truemeans GRF will still be placed on Exchange Node even after it is pushed down across the Exchange operator to a lower-level operator. -
Default: false
runtime_join_filter_push_down_limitβ
- Description: The maximum number of rows allowed for the Hash table based on which Bloom filter Local RF is generated. Local RF will not be generated if this value is exceeded. This variable prevents the generation of an excessively long Local RF.
- Default: 1024000
- Data type: Int
runtime_profile_report_intervalβ
- Description: The time interval at which runtime profiles are reported.
- Default: 10
- Unit: Second
- Data type: Int
- Introduced in: v3.1.0
scan_olap_partition_num_limitβ
- Description: The number of partitions allowed to be scanned for a single table in the execution plan.
- Default: 0 (No limit)
- Introduced in: v3.3.9
spill_mode (3.0 and later)β
auto: Spilling is automatically triggered when the memory usage threshold is reached.force: StarRocks forcibly executes spilling for all relevant operators, regardless of memory usage.
spill_storage_volumeβ
- Description: The storage volume with which you want to store the intermediate results of queries that triggered spilling. For more information, see Spill to object storage.
- Default: Empty string
SQL_AUTO_IS_NULLβ
sql_dialectβ
Description: The SQL dialect that is used. For example, you can run the
set sql_dialect = 'trino';command to set the SQL dialect to Trino, so you can use Trino-specific SQL syntax and functions in your queries.NOTICE
Data type: StarRocks
Introduced in: v3.0
sql_modeβ
PIPES_AS_CONCAT: The pipe symbol|is used to concatenate strings, for example,select 'hello ' || 'world'.ONLY_FULL_GROUP_BY(Default): The SELECT LIST can only contain GROUP BY columns or aggregate functions.ALLOW_THROW_EXCEPTION: returns an error instead of NULL when type conversion fails.FORBID_INVALID_DATE: prohibits invalid dates.MODE_DOUBLE_LITERAL: interprets floating-point types as DOUBLE rather than DECIMAL.SORT_NULLS_LAST: places NULL values at the end after sorting.ERROR_IF_OVERFLOW: returns an error instead of NULL in the case of arithmetic overflow. Currently, only the DECIMAL data type supports this option.GROUP_CONCAT_LEGACY: uses thegroup_concatsyntax of v2.5 and earlier. This option is supported from v3.0.9 and v3.1.6.
sql_safe_updatesβ
sql_select_limitβ
- Description: Used to limit the maximum number of rows returned by a query, which can prevent issues such as insufficient memory or network congestion caused by the query returning too much data.
- Default: Unlimited
- Data type: Long
statistic_collect_parallelβ
- Description: Used to adjust the parallelism of statistics collection tasks that can run on BEs. Default value: 1. You can increase this value to speed up collection tasks.
- Default: 1
- Data type: Int
storage_engineβ
- olap (default): StarRocks system-owned engine.
- mysql: MySQL external tables.
- broker: Access external tables through a broker program.
- elasticsearch or es: Elasticsearch external tables.
- hive: Hive external tables.
- iceberg: Iceberg external tables, supported from v2.1.
- hudi: Hudi external tables, supported from v2.2.
- jdbc: external table for JDBC-compatible databases, supported from v2.3.
streaming_preaggregation_modeβ
auto: The system first tries local preaggregation. If the effect is not satisfactory, it switches to the streaming mode. This is the default value.force_preaggregation: The system directly performs local preaggregation.force_streaming: The system directly performs streaming.
system_time_zoneβ
time_zoneβ
trace_log_modeβ
Description: Used to control where to output the logs of query trace profiles. Valid values:
command: Return query trace profile logs as the Explain String after executing TRACE LOGS.file: Return query trace profile logs in the FE log file fe.log with the class name beingFileLogTracer.
Default:
command -
Data type: String
Introduced in: v3.2.0
transaction_read_onlyβ
- Description: Used for MySQL 5.8 compatibility. The alias is
tx_read_only. This variable specifies the transaction access mode.ONindicates read only andOFFindicates readable and writable. - Default: OFF
tx_isolationβ
use_compute_nodesβ
Description: The maximum number of CN nodes that can be used. This variable is valid when
prefer_compute_node=true. Valid values:-1: indicates that all CN nodes are used.0: indicates that no CN nodes are used.
Default: -1
Data type: Int
Introduced in: v2.4
use_v2_rollupβ
vectorized_engine_enable (deprecated from v2.4 onwards)β
version (global)β
version_comment (global)β
wait_timeoutβ
- Description: The number of seconds the server waits for activity on a non-interactive connection before closing it. If a client does not interact with StarRocks for this length of time, StarRocks will actively close the connection.
- Default: 28800 (8 hours).
- Unit: Second
- Data type: Int
orc_use_column_namesβ
- Description: Used to specify how columns are matched when StarRocks reads ORC files from Hive. The default value is
false, which means columns in ORC files are read based on their ordinal positions in the Hive table definition. If this variable is set totrue, columns are read based on their names. - Default: false
- Introduced in: v3.1.10
enable_phased_schedulerβ
- Description: Whether to enable multi-phased scheduling. When multi-phased scheduling is enabled, it will schedule fragments according to their dependencies. For example, the system will first schedule the fragment on the build side of a Shuffle Join, and then the fragment on the probe side (Note that, unlike stage-by-stage scheduling, phased scheduling is still under the MPP execution mode). Enabling multi-phased scheduling can significantly reduce memory usage for a large number of UNION ALL queries.
- Default: false
phased_scheduler_max_concurrencyβ
- Description: The concurrency for phased scheduler scheduling leaf node fragments. For example, the default value means that, in a large number of UNION ALL Scan queries, at most two scan fragments are allowed to be scheduled at the same time.
- Default: 2
enable_wait_dependent_eventβ
- Description: Whether Pipeline waits for a dependent operator to finish execution before continuing within the same fragment. For example, in a left join query, when this feature is enabled, the probe-side operator waits for the build-side operator to finish before it starts executing. Enabling this feature can reduce memory usage, but may increase the query latency. However, for queries reused in CTE, enabling this feature may increase memory usage.
- Default: false
enable_topn_runtime_filterβ
- Description: Whether to enable TopN Runtime Filter. If this feature is enabled, a runtime filter will be dynamically constructed for ORDER BY LIMIT queries and pushed down to the scan for filtering.
- Default: true
enable_partition_hash_joinβ
- Description: Whether to enable adaptive Partition Hash Join.
- Default: true
spill_enable_direct_ioβ
- Description: Whether to skip Page Cache when reading or writing files for Spilling. If this feature is enabled, Spilling will use direct I/O mode to read or write files directly. Direct I/O mode can reduce the impact on the OS Page Cache, but it may cause increases in disk read/write time.
- Default: false
spill_enable_compactionβ
- Description: Whether to enable Compaction for small files from Spilling. When this feature is enabled, it reduces memory usage for aggregation and sorting.
- Default: true
