About Routine Loadβ
Routine load is a method using Apache Kafka, or in this lab, Redpanda, to continuously stream data into StarRocks. The data is streamed into a Kafka topic, and a Routine Load job consumes the data into StarRocks. More details on Routine Load are provided at the end of the lab.
About shared-dataβ
In systems that separate storage from compute, data is stored in low-cost reliable remote storage systems such as Amazon S3, Google Cloud Storage, Azure Blob Storage, and other S3-compatible storage like MinIO. Hot data is cached locally and when the cache is hit, the query performance is comparable to that of storage-compute coupled architecture. Compute nodes (CN) can be added or removed on demand within seconds. This architecture reduces storage costs, ensures better resource isolation, and provides elasticity and scalability.
This tutorial covers:
- Running StarRocks, Redpanda, and MinIO with Docker Compose
- Using MinIO as the StarRocks storage layer
- Configuring StarRocks for shared-data
- Adding a Routine Load job to consume data from Redpanda
The data used is synthetic.
There is a lot of information in this document, and it is presented with step-by-step content at the beginning, and the technical details at the end. This is done to serve these purposes in this order:
- Configure Routine Load.
- Allow the reader to load data in a shared-data deployment and analyze that data.
- Provide the configuration details for shared-data deployments.
Prerequisitesβ
Dockerβ
- Docker
- 4Β GB RAM assigned to Docker
- 10 GB free disk space assigned to Docker
SQL clientβ
You can use the SQL client provided in the Docker environment, or use one on your system. Many MySQL-compatible clients will work, and this guide covers the configuration of DBeaver and MySQL Workbench.
curlβ
curl is used to download the Compose file and the script to generate the data. Check to see if you have it installed by running curl or curl.exe at your OS prompt. If curl is not installed, get curl here.
Pythonβ
Python 3 and the Python client for Apache Kafka, kafka-python, are required.
Terminologyβ
FEβ
Frontend nodes are responsible for metadata management, client connection management, query planning, and query scheduling. Each FE stores and maintains a complete copy of metadata in its memory, which guarantees indiscriminate services among the FEs.
CNβ
Compute Nodes are responsible for executing query plans in shared-data deployments.
BEβ
Backend nodes are responsible for both data storage and executing query plans in shared-nothing deployments.
This guide does not use BEs, this information is included here so that you understand the difference between BEs and CNs.
Launch StarRocksβ
To run StarRocks with shared-data using Object Storage you need:
- A frontend engine (FE)
- A compute node (CN)
- Object Storage
This guide uses MinIO, which is S3 compatible Object Storage provider. MinIO is provided under the GNU Affero General Public License.
Download the lab filesβ
docker-compose.ymlβ
mkdir routineload
cd routineload
gen.pyβ
gen.py is a script that uses the Python client for Apache Kafka to publish (produce) data to a Kafka topic. The script has been written with the address and port of the Redpanda container.
Start StarRocks, MinIO, and Redpandaβ
Check the progress of the services. It should take 30 seconds or more for the containers to become healthy. The routineload-minio_mc-1 container will not show a health indicator, and it will exit once it is done configuring MinIO with the access key that StarRocks will use. Wait for routineload-minio_mc-1 to exit with a 0 code and the rest of the services to be Healthy.
Run docker compose ps until the services are healthy:
docker compose ps
[+] Running 6/7
β Network routineload_default Crea... 0.0s
β Container minio Healthy 5.6s
β Container redpanda Healthy 3.6s
β Container redpanda-console Healt... 1.1s
β § Container routineload-minio_mc-1 Waiting 23.1s
β Container starrocks-fe Healthy 11.1s
β Container starrocks-cn Healthy 23.0s
Examine MinIO credentialsβ
In order to use MinIO for Object Storage with StarRocks, StarRocks needs a MinIO access key. The access key was generated during the startup of the Docker services. To help you better understand the way that StarRocks connects to MinIO you should verify that the key exists.
Open the MinIO web UIβ
Browse to http://localhost:9001/access-keys The username and password are specified in the Docker compose file, and are miniouser and miniopassword. You should see that there is one access key. The Key is AAAAAAAAAAAAAAAAAAAA, you cannot see the secret in the MinIO Console, but it is in the Docker compose file and is BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB:
Create a bucket for your dataβ
When you create a storage volume in StarRocks you will specify the LOCATION for the data:
LOCATIONS = ("s3://my-starrocks-bucket/")
Open http://localhost:9001/buckets and add a bucket for the storage volume. Name the bucket my-starrocks-bucket. Accept the defaults for the three listed options.
SQL Clientsβ
These three clients are tested with this tutorial, you only need one:
- mysql CLI: You can run this from the Docker environment or your machine.
- DBeaver is available as a community version and a Pro version.
- MySQL Workbench
Configuring the clientβ
- mysql CLI
- DBeaver
- MySQL Workbench
The easiest way to use the mysql CLI is to run it from the StarRocks container starrocks-fe:
All docker compose commands must be run from the directory containing the docker-compose.yml file.
If you would like to install the mysql CLI expand mysql client install below:
- macOS: If you use Homebrew and do not need MySQL Server run
brew install mysql-client@8.0to install the CLI. - Linux: Check your repository system for the
mysqlclient. For example,yum install mariadb. - Microsoft Windows: Install the MySQL Community Server and run the provided client, or run
mysqlfrom WSL.
- Install DBeaver, and add a connection:
- Configure the port, IP, and username. Test the connection, and click Finish if the test succeeds:
- Install the MySQL Workbench, and add a connection.
- Configure the port, IP, and username and then test the connection:
- You will see warnings from the Workbench as it is checking for a specific MySQL version. You can ignore the warnings and when prompted, you can configure Workbench to stop displaying the warnings:
StarRocks configuration for shared-dataβ
At this point you have StarRocks running, and you have MinIO running. The MinIO access key is used to connect StarRocks and Minio.
This is the part of the FE configuration that specifies that the StarRocks deployment will use shared data. This was added to the file fe.conf when Docker Compose created the deployment.
# enable the shared data run mode
run_mode = shared_data
You can verify these settings by running this command from the quickstart directory and looking at the end of the file:
cat /opt/starrocks/fe/conf/fe.conf
Connect to StarRocks with a SQL clientβ
Run this command from the directory containing the docker-compose.yml file.
If you are using a client other than the mysql CLI, open that now.
Examine the storage volumesβ
SHOW STORAGE VOLUMES;
There should be no storage volumes, you will create one next.
Empty set (0.04 sec)
Create a shared-data storage volumeβ
Earlier you created a bucket in MinIO named my-starrocks-volume, and you verified that MinIO has an access key named AAAAAAAAAAAAAAAAAAAA. The following SQL will create a storage volume in the MionIO bucket using the access key and secret.
CREATE STORAGE VOLUME s3_volume
TYPE = S3
PROPERTIES
"enabled" = "true",
"aws.s3.endpoint" = "minio:9000",
"aws.s3.access_key" = "AAAAAAAAAAAAAAAAAAAA",
"aws.s3.secret_key" = "BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB",
"aws.s3.use_aws_sdk_default_behavior" = "false"
Now you should see a storage volume listed, earlier it was an empty set:
| Storage Volume |
| s3_volume |
1 row in set (0.02 sec)
View the details of the storage volume and note that this is nott yet the default volume, and that it is configured to use your bucket:
DESC STORAGE VOLUME s3_volume\G
Some of the SQL in this document, and many other documents in the StarRocks documentation, and with \G instead
of a semicolon. The \G causes the mysql CLI to render the query results vertically.
Many SQL clients do not interpret vertical formatting output, so you should replace \G with ;.
Type: S3
IsDefault: false
Params: {"aws.s3.access_key":"******","aws.s3.secret_key":"******","aws.s3.endpoint":"minio:9000","aws.s3.region":"us-east-1","aws.s3.use_instance_profile":"false","aws.s3.use_web_identity_token_file":"false","aws.s3.use_aws_sdk_default_behavior":"false"}
Enabled: true
Comment:
Set the default storage volumeβ
SET s3_volume AS DEFAULT STORAGE VOLUME;
Type: S3
IsDefault: true
Enabled: true
Comment:
Create a tableβ
These SQL commands are run in your SQL client.
Verify that the database quickstart is using the storage volume s3_volume:
SHOW CREATE DATABASE quickstart \G
Database: quickstart
Create Database: CREATE DATABASE `quickstart`
PROPERTIES ("storage_volume" = "s3_volume")
USE quickstart;
CREATE TABLE site_clicks (
DISTRIBUTED BY HASH(`uid`)
Open the Redpanda Consoleβ
There will be no topics yet, a topic will be created in the next step.
Publish data to a Redpanda topicβ
From a command shell in the routineload/ folder run this command to generate data:
python gen.py 5
On your system, you might need to use python3 in place of python in the command.
If you are missing kafka-python try:
pip install kafka-python
or
pip3 install kafka-python
Verify in the Redpanda Consoleβ
Navigate to http://localhost:8080/topics in the Redpanda Console, and you will see one topic named test2. Select that topic and then the Messages tab and you will see five messages matching the output of gen.py.
Consume the messagesβ
In StarRocks you will create a Routine Load job to:
- Consume the messages from the Redpanda topic
test2 - Load those messages into the table
site_clicks
StarRocks is configured to use MinIO for storage, so the data inserted into the site_clicks table will be stored in MinIO.
Create a Routine Load jobβ
Run this command in the SQL client to create the Routine Load job, the command will be explained in detail at the end of the lab.
PROPERTIES
"format" = "JSON",
FROM KAFKA
"kafka_topic" = "test2",
"kafka_partitions" = "0",
Verify the Routine Load jobβ
SHOW ROUTINE LOAD\G
Verify the three highlighted lines:
- The state should be
RUNNING - The topic should be
test2and the broker should beredpanda:2092 - The statistics should show either 0 or 5 loaded rows depending on how soon you ran the
SHOW ROUTINE LOADcommand. If there are 0 loaded rows run it again.
PauseTime: NULL
EndTime: NULL
DbName: quickstart
TableName: site_clicks
State: RUNNING
DataSourceType: KAFKA
CurrentTaskNum: 1
Progress: {"0":"OFFSET_ZERO"}
TimestampProgress: {}
ReasonOfStateChanged:
ErrorLogUrls:
TrackingSQL:
OtherMsg:
LatestSourcePosition: {}
SHOW ROUTINE LOAD\G
PauseTime: NULL
EndTime: NULL
DbName: quickstart
State: RUNNING
CurrentTaskNum: 1
Progress: {"0":"4"}
ErrorLogUrls:
TrackingSQL:
OtherMsg:
Verify that data is stored in MinIOβ
Open MinIO http://localhost:9001/browser/ and verify that there are objects stored under my-starrocks-bucket.
Query the data from StarRocksβ
USE quickstart;
SELECT * FROM site_clicks;
| uid | site | vtime |
5 rows in set (0.07 sec)
Publish additional dataβ
Running gen.py again will publish another five records to Redpanda.
python gen.py 5
Verify that data is addedβ
Since the Routine Load job runs on a schedule (every 10 seconds by default), the data will be loaded within a few seconds.
10 rows in set (0.02 sec)
Configuration detailsβ
Now that you have experienced using StarRocks with shared-data it is important to understand the configuration.
CN configurationβ
The CN configuration used here is the default, as the CN is designed for shared-data use. The default configuration is shown below. You do not need to make any changes.
sys_log_level = INFO
be_port = 9060
be_http_port = 8040
heartbeat_service_port = 9050
brpc_port = 8060
starlet_port = 9070
FE configurationβ
The FE configuration is slightly different from the default as the FE must be configured to expect that data is stored in Object Storage rather than on local disks on BE nodes.
The docker-compose.yml file generates the FE configuration in the command.
This config file does not contain the default entries for an FE, only the shared-data configuration is shown.
The non-default FE configuration settings:
Many configuration parameters are prefixed with s3_. This prefix is used for all Amazon S3 compatible storage types (for example: S3, GCS, and MinIO). When using Azure Blob Storage the prefix is azure_.
run_mode=shared_dataβ
This enables shared-data use.
cloud_native_storage_type=S3β
This specifies whether S3 compatible storage or Azure Blob Storage is used. For MinIO this is always S3.
Details of CREATE storage volumeβ
TYPE = S3
PROPERTIES
"enabled" = "true",
aws_s3_endpoint=minio:9000β
The MinIO endpoint, including port number.
aws_s3_path=starrocksβ
The bucket name.
aws_s3_access_key=AAAAAAAAAAAAAAAAAAAAβ
The MinIO access key.
aws_s3_secret_key=BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBβ
The MinIO access key secret.
aws_s3_use_instance_profile=falseβ
When using MinIO an access key is used, and so instance profiles are not used with MinIO.
aws_s3_use_aws_sdk_default_behavior=falseβ
When using MinIO this parameter is always set to false.
Notes on the Routine Load commandβ
StarRocks Routine Load takes many arguments. Only the ones used in this tutorial are described here, the rest will be linked to in the more information section.
PROPERTIES
"format" = "JSON",
FROM KAFKA
Parametersβ
The parameters for CREATE ROUTINE LOAD ON are:
- database_name.job_name
- table_name
database_name is optional. In this lab, it is quickstart and is specified.
job_name is required, and is clicks
table_name is required, and is site_clicks
Job propertiesβ
Property formatβ
"format" = "JSON",
In this case, the data is in JSON format, so the property is set to JSON. The other valid formats are: CSV, JSON, and Avro. CSV is the default.
Property jsonpathsβ
The names of the fields that you want to load from JSON-formatted data. The value of this parameter is a valid JsonPath expression. More information is available at the end of this page.
Data source propertiesβ
kafka_broker_listβ
Kafka's broker connection information. The format is <kafka_broker_name_or_ip>:<broker_ port>. Multiple brokers are separated by commas.
