Version: Stable-3.5
Gather statistics for CBO
What is CBO​
Types of statistical information​
Basic statistics​
  • row_count: total number of rows in a table
  • data_size: data size of a column
  • ndv: column cardinality, which is the number of distinct values in a column
  • null_count: the amount of data with NULL values in a column
  • min: minimum value in a column
  • max: maximum value in a column
Full statistics are stored in the column_statistics of the _statistics_ database. You can view this table to query table statistics. Following is an example of querying statistics data from this table.
table_id: 10174
partition_id: 10170
column_name: is_minor
db_id: 10169
partition_name: p06
row_count: 2
data_size: 2
ndv: NULL
null_count: 0
max: 1
min: 0
Histogram​
Histograms are stored in the histogram_statistics table of the _statistics_ database. Following is an example of querying statistics data from this table:
table_id: 10174
column_name: added
db_id: 10169
buckets: NULL
mcv: [["23","1"],["5","1"]]
Multi-column joint statistics​
Since v3.5.0, StarRocks supports multi-column joint statistics collection. Currently, when StarRocks performs cardinality estimation, the optimizer in most scenarios assumes that multiple columns are completely independent of each other, that is, there is no correlation among them. However, if there is a correlation among columns, the current estimation method may lead to an incorrect result. This causes the optimizer to generate an incorrect execution plan. Currently, only multi-column joint NDV is supported, and it is mainly used in the following scenarios for cardinality estimation.
  • Evaluating multiple AND-joined equivalent predicates.
  • Evaluating Agg nodes.
  • Apply to the aggregate push-down strategy.
Currently, multi-column joint statistics collection only supports manual collection. The default type is sampled collection. Multi-column statistics are stored in the multi_column_statistics table of the _statistics_ database in each StarRocks cluster. A query will return information similar to the following:
mysql> select * from _statistics_.multi_column_statistics \G
table_id: 1695021
column_ids: 0#1
db_id: 110099
table_name: db.test_multi_col_stats
column_names: id,name
ndv: 11
update_time: 2025-04-11 15:09:50
Collection types and methods​
StarRocks supports full and sampled collection, both can be performed automatically and manually. By default, StarRocks automatically collects full statistics of a table. It checks for any data updates every 5 minutes. If data change is detected, data collection will be automatically triggered. If you do not want to use automatic full collection, you can customize a collection task.
Collection typeCollection methodDescriptionAdvantage and disadvantage
Full collectionAutomatic/manualScans the full table to gather statistics.Statistics are collected partition. If a partition has no data change, data will not be collected from this partition, reducing resource consumption.Full statistics are stored in the _statistics_.column_statistics table.Advantage: The statistics are accurate, which helps the CBO make accurate estimation.Disadvantage: It consumes system resources and is slow. From 2.5 onwards, StarRocks allows you to specify an automatic collection period, which reduces resource consumption.
Sampled collectionAutomatic/manualEvenly extracts N rows of data from each partition of a table.Statistics are collected by table. Basic statistics of each column are stored as one record. Cardinality information (ndv) of a column is estimated based on the sampled data, which is not accurate. Sampled statistics are stored in the _statistics_.table_statistic_v1 table.Advantage: It consumes less system resources and is fast.Disadvantage: The statistics are not complete, which may affect the accuracy of cost estimation.
Since v3.5.0, both sampled and full collection statistics are stored in the _statistics_.column_statistics table. This is because the current optimizer will focus on the most recently collected statistics in the cardinality estimation, while each time the background automatically collects statistics, it may use a different collection method due to the different health status of the table. If there is data skew, the error rate of the sampled statistical information of the full table may be higher, and the same query may use different statistical information due to the different collection methods, which may cause the optimizer to generate an incorrect execution plan. Therefore, both sampled collection and full collection assume that the statistical information is collected at the partition level. You can adjust to the previous collection and storage method by modifying the FE configuration item statistic_use_meta_statistics to false.
Predicate Column​
Since v3.5.0, StarRocks supports collecting Predicate Column statistics.
A Predicate Column is a column that is often used as a filter condition (WHERE clause, JOIN condition, GROUP BY column, DISTINCT column) in a query. StarRocks automatically records each Predicate Column for the table involved in a query and stores it in _statistics_. predicate_columns table. The query will return the following:
select * from _statistics_.predicate_columns \G
fe_id: 127.0.0.1_9011_1735874871718
db_id: 1684773
table_id: 1685786
column_id: 1
usage: normal,predicate,join,group_by
last_used: 2025-04-11 20:39:32
created: 2025-04-11 20:39:53
You can also query the information_schema.column_stats_usage view for more observable information. In extreme scenarios (with a large number of columns), there is a large overhead for full collection, whereas in reality, for a stable workload, you often do not need statistics for all columns, but only the columns involved in some key Filter, Join, and Aggregation. Therefore, in order to weigh the cost and accuracy, StarRocks supports collecting Predicate Column statistics manually, and collecting Predicate Column statistics according to the policy when collecting statistics automatically, avoiding collecting all column statistics in the table. Each FE node in the cluster synchronously updates the Predicate Column information to the FE cache at regular intervals to accelerate the usage.
Collect statistics​
By default, StarRocks automatically collects the full amount of statistics for a table on a periodic basis. The default interval is 10 minutes. If the system finds that the update ratio of the data meets the condition, the collection will be triggered automatically. Collecting full statistics may consume a lot of system resources. If you do not want to use automatic full statistics collection, you can set the FE configuration item enable_collect_full_statistic to false, and the periodic collection task will be changed from full statistics collection to sampled collection.
Since v3.5.0, StarRocks will automatically change the full collection to sampled collection if it finds that the data of a table has changed a lot since the last collection to the current table during automatic collection. In the case of sampled collection is used, if there is a Predicate Column (PREDICATE/JOIN/GROUP BY/DISTINCT) in the table, StarRocks will convert the sampling task to full collection and collect the statistics of the Predicate Column to ensure the accuracy of the statistics, and will not collect the statistics of all columns in the table. It will not collect statistics from all columns in the table. You can configure this with the FE configuration item statistic_auto_collect_use_full_predicate_column_for_sample. In addition, StarRocks also switches from full collection of all columns to full collection of Predicate Columns if the number of columns in the table exceeds the FE configuration item statistic_auto_collect_predicate_columns_threshold when full collection is used.
Automatic collection​
For basic statistics, StarRocks automatically collects full statistics of a table by default, without requiring manual operations. For tables on which no statistics have been collected, StarRocks automatically collects statistics within the scheduling period. For tables on which statistics have been collected, StarRocks updates the total number of rows and modified rows in the tables, and persists this information regularly for judging whether to trigger automatic collection. Histograms and multi-column joint statistics are not captured by the current automatic collection task.
From 2.4.5 onwards, StarRocks allows you to specify a collection period for automatic full collection, which prevents cluster performance jitter caused by automatic full collection. This period is specified by FE parameters statistic_auto_analyze_start_time and statistic_auto_analyze_end_time.
  • Table data has changed since previous statistics collection.
  • The collection time falls within the range of the configured collection period. (The default collection period is all day.)
  • The update time of the previous collecting job is earlier than the latest update time of partitions.
  • The health of table statistics is below the specified threshold (statistic_auto_collect_ratio).
  1. If the number of partitions with data updated is less than 10, the formula is 1 - (Number of updated rows since previous collection/Total number of rows).
  2. If the number of partitions with data updated is greater than or equal to 10, the formula is 1 - MIN(Number of updated rows since previous collection/Total number of rows, Number of updated partitions since previous collection/Total number of partitions).
  3. Since v3.5.0, in order to determine whether a partition is healthy or not, StarRocks no longer compares the statistic information collection time with the data update time, but rather the ratio of partition update rows. You can configure this via the FE configuration item statistic_partition_health_v2_threshold. Also, you can set the FE configuration item statistic_partition_healthy_v2 to false to use to the previous health check behavior.
  • For tables with small data volume, **statistics are collected in real time with no restrictions, even though the table data is frequently updated. The statistic_auto_collect_small_table_size parameter can be used to determine whether a table is a small table or a large table. You can also use statistic_auto_collect_small_table_interval to configure collection intervals for small tables.
  • For tables with large data volume, the following restrictions apply:
    • The default collection interval is not less than 12 hours, which can be configured using statistic_auto_collect_large_table_interval.
    • When the collection interval is met and the statistics health is lower than the threshold for automatic sampled collection, sampled collection is triggered. You can configure this behavior using the FE configurartion item statistic_auto_collect_sample_threshold. Since v3.5.0, sampled collection is converted to full collection of Predicate Columns if all of the following conditions are met:
      • Predicate Column exists in the table, and the number of Predicate Columns is less than statistic_auto_collect_max_predicate_column_size_on_sample_strategy.
      • The FE configuration statistic_auto_collect_use_full_predicate_column_for_sample is set to true.
    • When the collection interval is met and the statistics health is higher than the threshold for automatic sampled collection (statistic_auto_collect_sample_threshold) and lower than the automatic collection threshold (statistic_auto_collect_ratio), full collection is triggered.
    • When the size of partitions to collect data (statistic_max_full_collect_data_size) is greater than 100 GB, sampled collection is triggered.
    • Only statistics of partitions whose update time is later than the time of the previous collection task are collected. Statistics of partitions with no data change are not collected.
  • For tables that have a Predicate Column and the total number of columns exceeds the statistic_auto_collect_predicate_columns_threshold, statistics are only collected for the Predicate Column in the table.
tip
FE configuration itemTypeDefault valueDescription
enable_statistic_collectBOOLEANTRUEWhether to turn on the default and user-defined auto collection tasks. This switch is turned on by default.
enable_collect_full_statisticBOOLEANTRUEWhether to enable the default auto collection. This switch is turned on by default.
statistic_collect_interval_secLONG600The interval for checking data updates during automatic collection. Unit: seconds.
statistic_auto_analyze_start_timeSTRING00:00:00The start time of automatic collection. Value range: 00:00:00 - 23:59:59.
statistic_auto_analyze_end_timeSTRING23:59:59The end time of automatic collection. Value range: 00:00:00 - 23:59:59.
statistic_auto_collect_small_table_sizeLONG5368709120The threshold for determining whether a table is a small table for automatic full collection. A table whose size is greater than this value is considered a large table, whereas a table whose size is less than or equal to this value is considered a small table. Unit: Byte. Default value: 5368709120 (5 GB).
statistic_auto_collect_small_table_intervalLONG0The interval for automatically collecting full statistics of small tables. Unit: seconds.
statistic_auto_collect_large_table_intervalLONG43200The interval for automatically collecting full statistics of large tables. Unit: seconds. Default value: 43200 (12 hours).
statistic_auto_collect_ratioFLOAT0.8The threshold for determining whether the statistics for automatic collection are healthy. If statistics health is below this threshold, automatic collection is triggered.
statistic_auto_collect_sample_thresholdDOUBLE0.3The statistics health threshold for triggering automatic sampled collection. If the health value of statistics is lower than this threshold, automatic sampled collection is triggered.
statistic_max_full_collect_data_sizeLONG107374182400The data size of the partitions for automatic collection to collect data. Unit: Byte. Default value: 107374182400 (100 GB). If the data size exceeds this value, full collection is discarded and sampled collection is performed instead.
statistic_full_collect_bufferLONG20971520The maximum buffer size taken by automatic collection tasks. Unit: Byte. Default value: 20971520 (20 MB).
statistic_collect_max_row_count_per_queryINT5000000000The maximum number of rows to query for a single analyze task. An analyze task will be split into multiple queries if this value is exceeded.
statistic_collect_too_many_version_sleepLONG600000The sleep time of automatic collection tasks if the table on which the collection task runs has too many data versions. Unit: ms. Default value: 600000 (10 minutes).
statistic_auto_collect_use_full_predicate_column_for_sampleBOOLEANTRUEWhether to convert an automatic full collection task to full collection of a Predicate Column when it hits the sampled collection policy.
statistic_auto_collect_max_predicate_column_size_on_sample_strategyINT16When the Auto Full Collection task hits the sampled collection policy, if the table has an unusually large number of Predicate Columns and exceeds this configuration item, the task will not switch to full collection of the Predicate Columns, but maintains to be the sampled collection of all columns. This configuration item controls the maximum value of Predicate Column for this behavior.
statistic_auto_collect_predicate_columns_thresholdINT32If the number of columns in the table exceeds this configuration during automatic collection, only the column statistics for the Predicate Column will be collected.
statistic_predicate_columns_persist_interval_secLONG60The interval at which FE synchronize and persists statistics of Predicate Column.
statistic_predicate_columns_ttl_hoursLONG24The elimination time of the Predicate Column statistics cached in FE.
enable_predicate_columns_collectionBOOLEANTRUEWhether to enable predicate columns collection. If disabled, predicate columns will not be recorded during query optimization.
enable_manual_collect_array_ndvBOOLEANFALSEWhether to enable manual collection for the NDV information of the ARRAY type.
enable_auto_collect_array_ndvBOOLEANFALSEWhether to enable automatic collection for the NDV information of the ARRAY type.
Manual collection​
Manually collect basic statistics​
ANALYZE [FULL|SAMPLE] TABLE tbl_name
[( col_name [, col_name]... )
| ALL COLUMNS
| PREDICATE COLUMNS
| MULTIPLE COLUMNS ( col_name [, col_name]... )]
[PARTITION (partition_name [, partition_name]...)]
[WITH [SYNC | ASYNC] MODE]
[PROPERTIES (property [, property]...)]
Parameter description:
  • Collection type
    • FULL: indicates full collection.
    • SAMPLE: indicates sampled collection.
    • If no collection type is specified, full collection is used by default.
  • The type of the column from which to collect statistics:
    • col_name: Columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected.
    • ALL COLUMNS: Collect statistics from all columns. Supported since v3.5.0.
    • PREDICATE COLUMNS: Collect statistics from only Predicate Columns. Supported since v3.5.0.
    • MULTIPLE COLUMNS: Collects joint statistics from the specified multiple columns. Currently, only manual synchronous collection of multiple columns is supported. The number of columns for manual statistics collection cannot exceed statistics_max_multi_column_combined_num, the default value is 10. Supported since v3.5.0.
  • [WITH SYNC | ASYNC MODE]: whether to run the manual collection task in synchronous or asynchronous mode. Synchronous collection is used by default if you do not specify this parameter.
  • PROPERTIES: custom parameters. If PROPERTIES is not specified, the default settings in the fe.conf file are used. The properties that are actually used can be viewed via the Properties column in the output of SHOW ANALYZE STATUS.
PROPERTIESTypeDefault valueDescription
statistic_sample_collect_rowsINT200000The minimum number of rows to collect for sampled collection.If the parameter value exceeds the actual number of rows in your table, full collection is performed.
Manual full collection
ANALYZE TABLE tbl_name;
ANALYZE FULL TABLE tbl_name;
Manual sampled collection
  • Manual collection of multi-column joint statistics
-- Manual sampled collection of multi-column joint statistics
ANALYZE SAMPLE TABLE tbl_name MULTIPLE COLUMNS (v1, v2);
-- Manual full collection of multi-column joint statistics
ANALYZE FULL TABLE tbl_name MULTIPLE COLUMNS (v1, v2);
  • Manual collection of Predicate Column
-- Manual sampled collection of Predicate Column
ANALYZE SAMPLE TABLE tbl_name PREDICATE COLUMNS
-- Manual full collection of Predicate Column
ANALYZE FULL TABLE tbl_name PREDICATE COLUMNS
Manually collect histograms​
[WITH N BUCKETS]
  • col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected. This parameter is required for histograms.
  • [WITH SYNC | ASYNC MODE]: whether to run the manual collection task in synchronous or asynchronous mode. Synchronous collection is used by default if you not specify this parameter.
  • WITH N BUCKETS: N is the number of buckets for histogram collection. If not specified, the default value in fe.conf is used.
  • PROPERTIES: custom parameters. If PROPERTIES is not specified, the default settings in fe.conf are used.
statistic_sample_collect_rowsINT200000The minimum number of rows to collect. If the parameter value exceeds the actual number of rows in your table, full collection is performed.
histogram_buckets_sizeLONG64The default bucket number for a histogram.
histogram_mcv_sizeINT100The number of most common values (MCV) for a histogram.
histogram_sample_ratioFLOAT0.1The sampling ratio for a histogram.
histogram_max_sample_row_countLONG10000000The maximum number of rows to collect for a histogram.
PROPERTIES(
"histogram_mcv_size" = "32",
Custom collection​
Customize an automatic collection task​
The default collection tasks provided by StarRocks automatically collect statistics for all databases and all tables according to the policy, and by default, you do not need to create custom collection tasks.
If you want to customize an automatic collection task, you need to create it through the CREATE ANALYZE statement. To create a collection task, you need the INSERT and SELECT permissions for the table being collected.
-- Automatically collect histograms of specified columns in a table.
CREATE ANALYZE TABLE tbl_name UPDATE HISTOGRAM ON col_name [, col_name]
[WITH N BUCKETS]
  • Collection type
    • If no collection type is specified, sample collection is used by default.
statistic_auto_collect_ratioFLOAT0.8The threshold for determining whether the statistics for automatic collection are healthy. If the statistics health is below this threshold, automatic collection is triggered.
statistic_sample_collect_rowsINT200000The minimum number of rows to collect.If the parameter value exceeds the actual number of rows in your table, full collection is performed.
statistic_exclude_patternStringnullThe name of the database or table that needs to be excluded in the job. You can specify the database and table that do not collect statistics in the job. Note that this is a regular expression pattern, and the match content is database.table.
statistic_auto_collect_intervalLONG0The interval for automatic collection. Unit: seconds. By default, StarRocks chooses statistic_auto_collect_small_table_interval or statistic_auto_collect_large_table_interval as the collection interval based on the table size. If you specified the statistic_auto_collect_interval property when you create an analyze job, this setting takes precedence over statistic_auto_collect_small_table_interval and statistic_auto_collect_large_table_interval.
CREATE ANALYZE ALL;
-- Automatically collect histograms of specified database, table, or columns.
CREATE ANALYZE TABLE tbl_name UPDATE HISTOGRAM ON c1,c2;
Automatic sampled collection
Instead of the auto collection task provided by StarRocks, use a user-defined collection task that does not collect the db_name.tbl_name table.
ADMIN SET FRONTEND CONFIG("enable_auto_collect_statistics"="false");
DROP ALL ANALYZE JOB;
CREATE ANALYZE FULL ALL db_name PROPERTIES (
Collect statistics during data loading​
To ensure a good execution plan for queries immediately after data loading, StarRocks triggers an asynchronous statistic collection task at the end of the INSERT INTO/OVERWRITE DML statements, which by default waits for 30 seconds after the DML finishes. If the statistics collection task does not finish in 30 seconds, the DML execution result is returned.
INSERT INTO​
  • Statistics is collected only for the first import of data into the partition.
  • If the number of rows in this import is greater than statistic_sample_collect_rows, the sampled collection task is triggered, otherwise full collection is used.
INSERT OVERWRITE​
  • If the ratio of the change in the number of rows before and after the OVERWRITE is less than statistic_sample_collect_ratio_threshold_of_first_load, the statistics collection task is not triggered.
  • If the number of rows in this OVERWRITE operation is greater than statistic_sample_collect_rows, then a sampled collection task is triggered, otherwise full collection is used.
The following properties (PROPERTIES) are used to create customized collection tasks for data loading. If not configured, the value of the corresponding FE configuration item is used.
PROPERTIESTypeDedaultDescription
enable_statistic_collect_on_first_loadBOOLEANTRUEWhether to trigger the statistics collection task after executing INSERT INTO/OVERWRITE.
semi_sync_collect_statistic_await_secondsLONG30Maximum time to wait for statistics to be collected before returning results.
statistic_sample_collect_ratio_threshold_of_first_loadDOUBLE0.1The ratio of data changes in OVERWRITE operations that will not trigger statistics collection tasks.
statistic_sample_collect_rowsLONG200000When the total data rows loaded via DML statements exceeds this value, sampled collection is used for statistics collection.
View custom collection tasks​
SHOW ANALYZE JOB [WHERE predicate][ORDER BY columns][LIMIT num]
ColumnDescription
IdThe ID of the collection task.
DatabaseThe database name.
TableThe table name.
ColumnsThe column names.
TypeThe type of statistics, including FULL and SAMPLE.
ScheduleThe type of scheduling. The type is SCHEDULE for an automatic task.
PropertiesCustom parameters.
StatusThe task status, including PENDING, RUNNING, SUCCESS, and FAILED.
LastWorkTimeThe time of the last collection.
ReasonThe reason why the task failed. NULL is returned if task execution was successful.
SHOW ANALYZE JOB
Delete a custom collection task​
DROP ANALYZE <ID>
DROP ANALYZE 266030;
View status of collection tasks​
You can use LIKE or WHERE to filter the information to return.
List nameDescription
TypeThe type of statistics, including FULL, SAMPLE, and HISTOGRAM.
ScheduleThe type of scheduling. ONCE means manual and SCHEDULE means automatic.
StatusThe status of the task.
StartTimeThe time when the task starts executing.
EndTimeThe time when the task execution ends.
ReasonThe reason why the task failed. NULL is returned if the execution was successful.
View statistics​
View metadata of basic statistics​
SHOW STATS META [WHERE predicate][ORDER BY columns][LIMIT num]
ColumnDescription
TypeThe type of statistics. FULL means full collection and SAMPLE means sampled collection.
UpdateTimeThe latest statistics update time for the current table.
HealthyThe health of statistical information.
ColumnStatsColumn ANALYZE type.
TabletStatsReportTimeThe time when the Tablet metadata for the table was updated in the FE.
TableHealthyMetricsMetric of health in statistical information.
TableUpdateTimeThe time when the table was updated.
View metadata of histograms​
ColumnDescription
ColumnThe columns.
TypeType of statistics. The value is HISTOGRAM for histograms.
Delete statistics​
Delete basic statistics​
The following statement deletes the statistics stored in the default_catalog._statistics_.column_statistics table, and the corresponding table statistics cached by FE will also be invalidated. Since v3.5.0, this statement also deletes multi-column joint statistics for this table.
DROP STATS tbl_name
The following statement deletes the multi-column joint statistics stored in the default_catalog._statistics_.multi_column_statistics table, and the multi-column joint statistics in the corresponding table cached by FE will also be invalidated. This statement does not delete the basic statistics of the table.
DROP MULTIPLE COLUMNS STATS tbl_name
Delete histograms​
Cancel a collection task​
KILL ANALYZE <ID>
Other FE configuration items​
statistic_manager_sleep_time_secLONG60The interval at which metadata is scheduled. Unit: seconds. The system performs the following operations based on this interval:Create tables for storing statistics.Delete statistics that have been deleted.Delete expired statistics.
statistic_analyze_status_keep_secondLONG259200The duration to retain the history of collection tasks. Unit: seconds. Default value: 259200 (3 days).
Session variable​
statistic_collect_parallel: Used to adjust the parallelism of statistics collection tasks that can run on BEs. Default value: 1. You can increase this value to speed up collection tasks.
Collect statistics of external tables​
Since v3.2.0, StarRocks supports collecting statistics of Hive, Iceberg, and Hudi tables. The syntax is similar to collecting StarRocks internal tables. However, only manual full collection, manual histogram collection (since v3.2.7), and automatic full collection are supported. Sampled collection is not supported. Since v3.3.0, StarRocks supports collecting statistics of Delta Lake tables and statistics of sub-fields in STRUCT. Since v3.4.0, StarRocks supports automatic statistics collection via query-triggered ANALYZE tasks.
The collected statistics are stored in the external_column_statistics table of the _statistics_ in the default_catalog. They are not stored in Hive Metastore and cannot be shared by other search engines. You can query data from the default_catalog._statistics_.external_column_statistics table to verify whether statistics are collected for a Hive/Iceberg/Hudi table.
Following is an example of querying statistics data from external_column_statistics.
partition_name:
column_name: k1
catalog_name: hive_catalog
db_name: tn_test
table_name: ex_hive_tbl
row_count: 3
data_size: 12
ndv: NULL
null_count: 0
max: 3
min: 2
Limits​
The following limits apply when you collect statistics for external tables:
  • You can collect statistics of only Hive, Iceberg, Hudi, and Delta Lake (Since v3.3.0) tables.
  • Only manual full collection, manual histogram collection (since v3.2.7), and automatic full collection are supported. Sampled collection is not supported.
  • For the system to automatically collect full statistics, you must create an Analyze job, which is different from collecting statistics of StarRocks internal tables where the system does this in the background by default.
  • For automatic collection tasks:
    • You can only collect statistics of a specific table. You cannot collect statistics of all tables in a database or statistics of all databases in an external catalog.
    • StarRocks can detect whether data in Hive and Iceberg tables are updated and if so, collect statistics of only partitions whose data is updated. StarRocks cannot perceive whether data in Hudi tables are updated and can only perform periodic full collection.
  • For query-triggered collection tasks:
    • Currently, only Leader FE node can trigger ANALYZE tasks.
    • The system only supports checking for partition changes on Hive and Iceberg tables, and only collects statistics on the partitions where the data has changed. For the Delta Lake/Hudi tables, the system collects statistics of the entire table.
    • If Partition Transforms are applied to Iceberg tables, the collection of statistics is supported only for identity, year, month, day, hour type Transforms.
    • Collecting statistics for Partition Evolution for Iceberg tables is not supported.
The following examples happen in a database under the Hive external catalog. If you want to collect statistics of a Hive table from the default_catalog, reference the table in the [catalog_name.][database_name.]<table_name> format.
Query-triggered collection​
Since v3.4.0, the system supports automatic statistics collection of external tables by query-triggered ANALYZE tasks. When querying Hive, Iceberg, Hudi, or Delta Lake tables, the system will automatically trigger ANALYZE tasks in the background to collect statistics of the corresponding tables and columns, and use it for subsequent query plan optimization.
Workflow:
  1. When the optimizer queries the cached statistics in FE, it will determine the object of the ANALYZE task based on the queried tables and columns (the ANALYZE task will only collect the statistics of the columns included in the query).
  2. The system will encapsulate the task object as an ANALYZE task and add it to the PendingTaskQueue.
  3. The Scheduler thread periodically fetches tasks from the PendingTaskQueue and add them to the RunningTasksQueue.
  4. During the execution of the ANALYZE task, it collects statistics and writes them to the BE and clears the expired statistics cached in the FE.
This feature is enabled by default. You can control the above process with the following system variables and configuration items.
System variable​
enable_query_trigger_analyze​
  • Default: true
  • Type: Boolean
  • Description: Whether to enable query-trigger ANALYZE tasks.
  • Introduced in: v3.4.0
FE configuration​
connector_table_query_trigger_analyze_small_table_rows​
  • Default: 10000000
  • Type: Int
  • Unit: -
  • Is mutable: Yes
  • Description: The threshold for determining whether a table is a small table for query-trigger ANALYZE tasks.
connector_table_query_trigger_analyze_small_table_interval​
  • Default: 2 * 3600
  • Type: Int
  • Unit: Second
  • Is mutable: Yes
  • Description: The interval for query-trigger ANALYZE tasks of small tables.
connector_table_query_trigger_analyze_large_table_interval​
  • Default: 12 * 3600
  • Type: Int
  • Unit: Second
  • Is mutable: Yes
  • Description: The interval for query-trigger ANALYZE tasks of large tables.
connector_table_query_trigger_analyze_max_pending_task_num​
  • Default: 100
  • Type: Int
  • Unit: -
  • Is mutable: Yes
  • Description: Maximum number of query-trigger ANALYZE tasks that are in Pending state on the FE.
connector_table_query_trigger_analyze_schedule_interval​
  • Default: 30
  • Type: Int
  • Unit: Second
  • Is mutable: Yes
  • Description: The interval at which the Scheduler thread schedules to query-trigger ANALYZE tasks.
connector_table_query_trigger_analyze_max_running_task_num​
  • Default: 2
  • Type: Int
  • Unit: -
  • Is mutable: Yes
  • Description: Maximum number of query-trigger ANALYZE tasks that are in Running state on the FE.
Manual collection​
Create a manual collection task​
Syntax:
-- Manual histogram collection (since v3.3.0)
[WITH N BUCKETS]
Following is an example of manual full collection:
View the task status​
Syntax:
Example:
View metadata of statistics​
Syntax:
Example:
Syntax:
KILL ANALYZE <ID>
  • statistic_collect_interval_sec
    The interval for checking data updates during automatic collection. Unit: seconds. Default: 5 minutes.
  • statistic_auto_collect_small_table_rows (v3.2 and later)
    Threshold to determine whether a table in an external data source (Hive, Iceberg, Hudi) is a small table during automatic collection. Default: 10000000.
  • statistic_auto_collect_small_table_interval
    The interval for collecting statistics of small tables. Unit: seconds. Default: 0.
  • statistic_auto_collect_large_table_interval
    The interval for collecting statistics of large tables. Unit: seconds. Default: 43200 (12 hours).
Automatic collection threads checks data updates at the interval specified by statistic_collect_interval_sec. If the number of rows in a table is less than statistic_auto_collect_small_table_rows, it collects statistics of such tables based on statistic_auto_collect_small_table_interval.
If the number of rows in a table exceeds statistic_auto_collect_small_table_rows, it collects statistics of such tables based on statistic_auto_collect_large_table_interval. It updates statistics of large tables only when Last table update time + Collection interval > Current time. This prevents frequent analyze tasks for large tables.
Create an automatic collection task​
Syntax:
You can specify the property statistic_auto_collect_interval to set the collection interval exclusively for the automatic collection task. The FE configuration items statistic_auto_collect_small_table_interval and statistic_auto_collect_large_table_interval will not take effect on this task.
Example:
View the status of an automatic collection task​
Same as manual collection.
View automatic collection tasks​
Syntax:
Example:
Empty set (0.00 sec)
Delete statistics​
DROP STATS tbl_name
References​
