User-defined variables
This topic describes how to declare and use user-defined variables.
StarRocks 2.5 and later versions support user-defined variables. These variables are used to store specific values that are referenced in later SQL statements, thereby simplifying the writing of SQL statements and avoiding duplicate computation.
Usage notesβ
- User-defined variables are variables, which can be created by the user and exist in the session. This means that no one can access user-defined variables that have been declared by another user, and when the session is closed these variables expire.
- StarRocks does not support using the SHOW statement to display existing user-defined variables.
- The following types of values cannot be declared as user-defined variables: BITMAP, HLL, PERCENTILE, and ARRAY. User-defined variables of the JSON type are converted to the STRING type for storage.
Declare user-defined variablesβ
SET @var_name = expr [, ...];
- All variables must be preceded by a single at sign (@).
- Multiple variables can be declared in the same SET statement and need to be separated with commas (
,).- You can declare the same variable multiple times. The newly declared value overwrites the original value.
- If an undeclared variable is used, the value of the variable is
NULLby default, and the NULL type is STRING.
Parametersβ
| var_name | Yes | The name of the user-defined variable. The naming conventions are as follows:
| expr | Yes | The value of the user-defined variable. You can specify a number (such as 43) or a complex expression (such as the value returned by a SELECT statement) for this parameter. The data type of the variable is the same as the data type of the result returned by the expression. |
Example 1: Declare a number as a user-defined variable.
SET @var = 43;
Example 2: Declare the value returned by a SELECT query as a user-defined variable.
SET @var = (SELECT SUM(v1) FROM test);
Example 3: Declare multiple user-defined variables in the same SET statement.
SET @v1=1, @v2=2;
Use user-defined variables in SQLβ
Simplifies the writing of SQL statements. For example, when you execute the following SELECT statement, StarRocks parses
@varas1.SET @var = 1;
SELECT @var, v1 from test; -
Avoids duplicate computation. For example, when you execute the following SELECT statement, StarRocks parses
@varas the result returned by theselect sum(c1) from tblcommand.SET @var = (select sum(c1) from tbl);
