バージョン: Candidate-4.1
variant_typeof
Returns the type name of a VARIANT value as a string.
This function inspects a VARIANT value and returns its type as a string. This is useful for understanding the structure of VARIANT data or for conditional processing based on the data type.
VARCHAR variant_typeof(variant_expr)
  • variant_expr: the expression that represents the VARIANT object. This is typically a VARIANT column from an Iceberg table or a VARIANT value returned by variant_query.
Returns a VARCHAR value representing the type name.
Possible return values include:
  • "Null" - for NULL values
  • "Boolean(true)" - for boolean true values
  • "Boolean(false)" - for boolean false values
  • "Int8", "Int16", "Int32", "Int64" - for integer values
  • "Float", "Double" - for floating-point values
  • "Decimal4", "Decimal8", "Decimal16" - for decimal values with different precision
  • "String" - for string values
  • "Binary" - for binary data
  • "Date" - for date values
  • "TimestampTz", "TimestampNtz" - for timestamp values with or without timezone
  • "TimestampTzNanos", "TimestampNtzNanos" - for nanosecond-precision timestamp values
  • "TimeNtz" - for time values without timezone
  • "Uuid" - for UUID values
  • "Object" - for struct or map values
  • "Array" - for array values
Example 1: Get the type of a VARIANT value at the root level.
SELECT variant_typeof(data) AS type
FROM bluesky
LIMIT 1;
| type |
| Object |
Example 2: Get the type of nested fields.
variant_typeof(variant_query(data, '$.kind')) AS kind_type,
variant_typeof(variant_query(data, '$.did')) AS did_type,
variant_typeof(variant_query(data, '$.commit')) AS commit_type
FROM bluesky
LIMIT 1;
| kind_type | did_type | commit_type |
| String | String | Object |
Example 3: Check types of multiple fields.
variant_typeof(variant_query(data, '$.commit')) AS commit_type,
variant_typeof(variant_query(data, '$.time_us')) AS time_type
FROM bluesky
LIMIT 1;
| commit_type | time_type |
| Object | Int64 |
Example 4: Use in conditional logic to handle different types.
CASE variant_typeof(variant_query(data, '$.time_us'))
WHEN 'Int64' THEN get_variant_int(data, '$.time_us')
ELSE NULL
END AS timestamp_value
FROM bluesky
LIMIT 3;
| timestamp_value |
| 1733267476040329 |
| 1733267476040803 |
| 1733267476041472 |
Example 5: Filter rows based on type.
SELECT COUNT(*) AS object_count
FROM bluesky
WHERE variant_typeof(variant_query(data, '$.commit')) = 'Object';
| object_count |
| 9960624 |
keyword
VARIANT_TYPEOF,VARIANT
