バージョン: Candidate-4.1
get_variant
A family of functions that extract typed values from VARIANT objects at specified paths.
These functions navigate to a specified path in a VARIANT value and return the value as a specific data type. If the value at the path does not exist, the path is invalid, or the value cannot be converted to the requested type, the functions return NULL.
BIGINT get_variant_int(variant_expr, path)
DOUBLE get_variant_double(variant_expr, path)
VARCHAR get_variant_string(variant_expr, path)
BOOLEAN get_variant_bool(variant_expr, path)
  • variant_expr: the expression that represents the VARIANT object. This is typically a VARIANT column from an Iceberg table.
  • path: the expression that represents the path to an element in the VARIANT object. The value of this parameter is a string. The path syntax is similar to JSON path:
    • $ represents the root element
    • . is used to access object fields
    • [index] is used to access array elements (0-based indexing)
    • Field names with special characters can be quoted: $."field.name"
Return values
  • get_variant_int: Returns a BIGINT value, or NULL if the value cannot be converted to an integer.
  • get_variant_double: Returns a DOUBLE value, or NULL if the value cannot be converted to a double.
  • get_variant_string: Returns a VARCHAR value, or NULL if the value cannot be converted to a string.
  • get_variant_bool: Returns a BOOLEAN value (1 or 0), or NULL if the value cannot be converted to a boolean.
Example 1: Extract basic fields from root level
Extract string and integer values from the Bluesky firehose data:
get_variant_string(data, '$.kind') AS kind,
get_variant_string(data, '$.did') AS did,
get_variant_int(data, '$.time_us') AS timestamp_us
FROM bluesky
LIMIT 3;
| kind | did | timestamp_us |
| commit | did:plc:gw3yid42zz6qx6gxukvkgxgq | 1733267476040329 |
| commit | did:plc:jbaujn4dd466ebt6pdf5vxod | 1733267476040803 |
| commit | did:plc:ytgql26s6zoifhlnvf7qheea | 1733267476041472 |
Example 2: Extract nested fields
Extract operation details from nested commit structures:
get_variant_string(data, '$.commit.collection') AS collection,
get_variant_string(data, '$.commit.operation') AS operation,
get_variant_string(data, '$.commit.rkey') AS record_key
FROM bluesky
WHERE get_variant_string(data, '$.commit.operation') = 'create'
LIMIT 5;
| collection | operation | record_key |
| app.bsky.feed.post | create | 3lckw3k2abc2d |
| app.bsky.graph.follow | create | 3lckw3k2def3e |
| app.bsky.feed.repost | create | 3lckw3k2ghi4f |
| app.bsky.feed.repost | create | 3lckw3k2jkl5g |
| app.bsky.feed.like | create | 3lckw3k2mno6h |
Example 3: Extract deeply nested content
Extract post text and metadata from deeply nested structures:
get_variant_string(data, '$.commit.record.text') AS post_text,
get_variant_string(data, '$.commit.record.langs[0]') AS language,
get_variant_int(data, '$.commit.record.createdAt') AS created_timestamp
FROM bluesky
WHERE get_variant_string(data, '$.commit.collection') = 'app.bsky.feed.post'
AND get_variant_string(data, '$.commit.record.text') IS NOT NULL
LIMIT 3;
| post_text | language | created_timestamp |
| I went on a walk today | en | 1733267476 |
| Are you interested in developing your own graph sequence model based on a sp... | en | 1733267476 |
| Tam im tiež celkom slušne práši... | sk | 1733267476 |
Example 4: Extract boolean values
Extract boolean flags from post records:
get_variant_bool(data, '$.commit.record.bridgyOriginalUrl') AS is_bridged,
get_variant_bool(data, '$.commit.record.selfLabel.settings.adult') AS has_adult_label
FROM bluesky
LIMIT 5;
| post_text | is_bridged | has_adult_label |
| Great day for coding! | NULL | 0 |
| Check out this amazing view | 1 | 0 |
| Working on my new project | NULL | NULL |
| Another beautiful sunset | NULL | 0 |
| Weekend plans anyone? | 0 | NULL |
Example 5: Extract numeric values with calculations
Convert microseconds to seconds and perform timestamp calculations:
get_variant_int(data, '$.time_us') AS timestamp_us,
get_variant_int(data, '$.time_us') / 1000000 AS timestamp_seconds,
FROM_UNIXTIME(get_variant_int(data, '$.time_us') / 1000000) AS readable_time
FROM bluesky
LIMIT 3;
| timestamp_us | timestamp_seconds | readable_time |
| 1733267476040329 | 1733267476 | 2024-12-03 20:17:56 |
| 1733267476040803 | 1733267476 | 2024-12-03 20:17:56 |
| 1733267476041472 | 1733267476 | 2024-12-03 20:17:56 |
Example 6: Use in aggregation queries
Count records by collection type:
COUNT(*) AS count
FROM bluesky
GROUP BY collection
ORDER BY count DESC
LIMIT 5;
| collection | count |
| app.bsky.feed.like | 5067917 |
| app.bsky.graph.follow | 2931757 |
| app.bsky.feed.post | 960723 |
| app.bsky.feed.repost | 666364 |
| app.bsky.graph.block | 196053 |
Example 7: Count records by operation type
COUNT(*) AS count
FROM bluesky
GROUP BY operation;
| operation | count |
| delete | 420223 |
| update | 40283 |
| NULL | 39361 |
| create | 9500118 |
Example 8: Extract and analyze engagement metrics
Extract numeric engagement metrics from posts:
get_variant_int(data, '$.commit.record.likeCount') AS likes,
get_variant_int(data, '$.commit.record.replyCount') AS replies,
get_variant_int(data, '$.commit.record.repostCount') AS reposts,
get_variant_double(data, '$.commit.record.engagementRate') AS engagement_rate
FROM bluesky
AND get_variant_int(data, '$.commit.record.likeCount') > 100
LIMIT 5;
| post_text | likes | replies | reposts | engagement_rate |
| This is amazing! | 245 | 23 | 45 | 0.12 |
| Can't believe this happened | 189 | 12 | 34 | 0.08 |
| Just finished my project | 156 | 8 | 19 | 0.05 |
| Beautiful day at the park | 134 | 15 | 28 | 0.07 |
| Check out this cool thing I made | 112 | 6 | 11 | 0.04 |
Example 9: Combine multiple variant functions in filtering
Find verified accounts that are actively posting:
get_variant_string(data, '$.did') AS user_did,
get_variant_bool(data, '$.commit.record.verified') AS is_verified
FROM bluesky
AND get_variant_bool(data, '$.commit.record.verified') = TRUE
AND get_variant_int(data, '$.time_us') > 1733267476000000
LIMIT 5;
| user_did | post_text | is_verified |
| did:plc:rhqpfbdmabrwrd3o552tlsy7 | Official announcement coming up | 1 |
| did:plc:vlq5rxxanqrzrqdcjfoirgfz | New feature release today | 1 |
| did:plc:iefkhz4tg3vldzmtgyqkj3xb | Thank you all for your support | 1 |
| did:plc:2phsrz5r5kynlq6pnrrzvrno | Excited to share this news | 1 |
| did:plc:hxz45fftjaa62vnwiiwh6fhj | Join us for the live stream | 1 |
Example 10: NULL handling
Returns NULL when paths don't exist or values can't be converted:
get_variant_int(data, '$.nonexistent.field') AS missing_int,
get_variant_double(data, '$.kind') AS string_as_double,
get_variant_bool(data, '$.time_us') AS int_as_bool,
get_variant_string(data, '$.commit.record.nonexistent') AS missing_string
FROM bluesky
LIMIT 1;
| missing_int | string_as_double | int_as_bool | missing_string |
| NULL | NULL | NULL | NULL |
keyword
GET_VARIANT_INT,GET_VARIANT_DOUBLE,GET_VARIANT_STRING,GET_VARIANT_BOOL,VARIANT
