ds_hll_count_distinct
集計関数の近似値を返します。これは COUNT(DISTINCT col) の結果に似ています。APPROX_COUNT_DISTINCT(expr) も同様の関数です。
ds_hll_count_distinct は COUNT と DISTINCT の組み合わせ よりも高速で、固定サイズのメモリを使用するため、高いカーディナリティの列に対して必要なメモリが少なくなります。
APPROX_COUNT_DISTINCT(expr) よりも遅いですが、Apache Datasketches を採用しているため、精度が高くなっています。詳細については、HyperLogLog Sketches を参照してください。
ds_hll_count_distinct(expr, [log_k], [tgt_type])
log_k: 整数。範囲 [4, 21]。デフォルト: 17。tgt_type: 有効 な値はHLL_4、HLL_6(デフォルト)、HLL_8です。
mysql> CREATE TABLE t1 (
-> id BIGINT NOT NULL,
-> province VARCHAR(64),
-> age SMALLINT,
-> dt VARCHAR(10) NOT NULL
-> DUPLICATE KEY(id)
mysql> select ds_hll_count_distinct(id), ds_hll_count_distinct(province), ds_hll_count_distinct(age), ds_hll_count_distinct(dt) from t1 order by 1, 2;
| ds_hll_count_distinct(id) | ds_hll_count_distinct(province) | ds_hll_count_distinct(age) | ds_hll_count_distinct(dt) |
| 100090 | 100140 | 100 | 1 |
1 row in set (0.07 sec)
mysql> select ds_hll_count_distinct(id, 21), ds_hll_count_distinct(province, 21), ds_hll_count_distinct(age, 21), ds_hll_count_distinct(dt, 21) from t1 order by 1, 2;
| ds_hll_count_distinct(id, 21) | ds_hll_count_distinct(province, 21) | ds_hll_count_distinct(age, 21) | ds_hll_count_distinct(dt, 21) |
| 99995 | 100001 | 100 | 1 |
mysql> select ds_hll_count_distinct(id, 10, "HLL_8"), ds_hll_count_distinct(province, 10, "HLL_8"), ds_hll_count_distinct(age, 10, "HLL_8"), ds_hll_count_distinct(dt, 10, "HLL_8") from t1 order by 1, 2;
| ds_hll_count_distinct(id, 10, 'HLL_8') | ds_hll_count_distinct(province, 10, 'HLL_8') | ds_hll_count_distinct(age, 10, 'HLL_8') | ds_hll_count_distinct(dt, 10, 'HLL_8') |
| 99844 | 101905 | 96 | 1 |
1 row in set (0.09 sec)
キーワード
DS_HLL_COUNT_DISTINCT,APPROX_COUNT_DISTINCT
