SHOW CREATE MATERIALIZED VIEW
SHOW CREATE MATERIALIZED VIEW shows the definition of a specific asynchronous materialized view.
tip
This operation does not require privileges.
SHOW CREATE MATERIALIZED VIEW [database.]<mv_name>
Parameters in brackets [] is optional.
ParameterRequiredDescription
mv_nameyesThe name of the materialized view to show.
Returns​
ReturnDescription
Materialized ViewThe name of the materialized view.
Create Materialized ViewThe definition of the materialized view.
Example 1: Show the definition of a specific materialized view
MySQL > SHOW CREATE MATERIALIZED VIEW lo_mv1\G
Materialized View: lo_mv1
Create Materialized View: CREATE MATERIALIZED VIEW `lo_mv1`
COMMENT "MATERIALIZED_VIEW"
DISTRIBUTED BY HASH(`lo_orderkey`)
REFRESH ASYNC
"storage_medium" = "HDD"
AS SELECT `wlc_test`.`lineorder`.`lo_orderkey` AS `lo_orderkey`, `wlc_test`.`lineorder`.`lo_custkey` AS `lo_custkey`, sum(`wlc_test`.`lineorder`.`lo_quantity`) AS `total_quantity`, sum(`wlc_test`.`lineorder`.`lo_revenue`) AS `total_revenue`, count(`wlc_test`.`lineorder`.`lo_shipmode`) AS `shipmode_count` FROM `wlc_test`.`lineorder` GROUP BY `wlc_test`.`lineorder`.`lo_orderkey`, `wlc_test`.`lineorder`.`lo_custkey` ORDER BY `wlc_test`.`lineorder`.`lo_orderkey` ASC ;
StarRocks Assistant
