Version: Candidate-4.1
DROP MATERIALIZED VIEW
DROP MATERIALIZED VIEW drops a materialized view.
You cannot drop a synchronous materialized view that is being created in process with this command unless you use the FORCE option. With FORCE, StarRocks cancels any stuck sync MV build jobs, restores the base table state to NORMAL, and then drops the materialized view. Without FORCE, see Synchronous materialized View - Drop an unfinished materialized view for further instructions.
tip
This operation requires the DROP privilege on the target materialized view.
DROP MATERIALIZED VIEW [IF EXISTS] [database.]mv_name [FORCE]
Parameters in brackets [] are optional.
ParameterRequiredDescription
IF EXISTSnoIf this parameter is specified, StarRocks will not throw an exception when deleting a materialized view that does not exist. If this parameter is not specified, the system will throw an exception when deleting a materialized view that does not exist.
mv_nameyesThe name of the materialized view to delete.
FORCEnoWhen the base table is not in NORMAL state (e.g., a sync MV build is stuck), FORCE cancels the related alter jobs, sets the table to NORMAL, and then drops the materialized view. Omit FORCE for normal drops.
Example 1: Drop an existing materialized view
  1. View all existing materialized views in the database.
MySQL > SHOW MATERIALIZED VIEWS\G
database_name: default_cluster:sr_hub
text: SELECT `sr_hub`.`orders`.`dt` AS `dt`, `sr_hub`.`orders`.`order_id` AS `order_id`, `sr_hub`.`orders`.`user_id` AS `user_id`, sum(`sr_hub`.`orders`.`cnt`) AS `total_cnt`, sum(`sr_hub`.`orders`.`revenue`) AS `total_revenue`, count(`sr_hub`.`orders`.`state`) AS `state_count` FROM `sr_hub`.`orders` GROUP BY `sr_hub`.`orders`.`dt`, `sr_hub`.`orders`.`order_id`, `sr_hub`.`orders`.`user_id`
rows: 0
1 rows in set (0.00 sec)
  1. Drop the materialized view order_mv1.
DROP MATERIALIZED VIEW order_mv1;
  1. Check if the dropped materialized view exists.
MySQL > SHOW MATERIALIZED VIEWS;
Empty set (0.01 sec)
Example 2: Drop a non-existing materialized view
  • If the parameter IF EXISTS is specified, StarRocks will not throw an exception when deleting a materialized view that does not exist.
MySQL > DROP MATERIALIZED VIEW IF EXISTS k1_k2;
Query OK, 0 rows affected (0.00 sec)
  • If the parameter IF EXISTS is not specified, the system will throw an exception when deleting a materialized view that does not exist.
MySQL > DROP MATERIALIZED VIEW k1_k2;
ERROR 1064 (HY000): Materialized view k1_k2 is not find
