Version: Candidate-4.1
BROKER LOAD
StarRocks provides the MySQL-based loading method Broker Load. After you submit a load job, StarRocks asynchronously runs the job. You can use SELECT * FROM information_schema.loads to query the job result. This feature is supported from v3.1 onwards. For more information about the background information, principles, supported data file formats, how to perform single-table loads and multi-table loads, and how to view job results, see loading overview.
You can load data into StarRocks tables only as a user who has the INSERT privilege on those StarRocks tables. If you do not have the INSERT privilege, follow the instructions provided in GRANT to grant the INSERT privilege to the user that you use to connect to your StarRocks cluster. The syntax is GRANT INSERT ON TABLE <table_name> IN DATABASE <database_name> TO { ROLE <role_name> | USER <user_identity>}.
data_desc[, data_desc ...]
WITH BROKER
StorageCredentialParams
[PROPERTIES
opt_properties
Note that in StarRocks some literals are used as reserved keywords by the SQL language. Do not directly use these keywords in SQL statements. If you want to use such a keyword in an SQL statement, enclose it in a pair of backticks (`). See Keywords.
database_name and label_name​
label_name specifies the label of the load job. For the naming conventions, see System limits.
database_name optionally specifies the name of the database to which the destination table belongs.
Each load job has a label that is unique across the entire database. You can use the label of a load job to view the execution status of the load job and prevent repeatedly loading the same data. When a load job enters the FINISHED state, its label cannot be reused. Only the label of a load job that has entered the CANCELLED state can be reused. In most cases, the label of a load job is reused to retry that load job and load the same data, thereby implementing Exactly-Once semantics.
For label naming conventions, see System limits.
data_desc​
The description of a batch of data to be loaded. Each data_desc descriptor declares information such as the data source, ETL functions, destination StarRocks table, and destination partitions.
Broker Load supports loading multiple data files at a time. In one load job, you can use multiple data_desc descriptors to declare multiple data files you want to load, or use one data_desc descriptor to declare one file path from which you want to load all data files in it. Broker Load can also ensure the transactional atomicity of each load job that is run to load multiple data files. Atomicity means that the loading of multiple data files in one load job must all succeed or fail. It never happens that the loading of some data files succeeds while the loading of the other files fails.
data_desc supports the following syntax:
[NEGATIVE]
INTO TABLE <table_name>
[(format_type_options)]
[(column_list)]
[WHERE predicate]
data_desc must include the following parameters:
  • file_path
    Specifies the save path of one or more data files you want to load.
    You can specify this parameter as the save path of one data file. For example, you can specify this parameter as "hdfs://<hdfs_host>:<hdfs_port>/user/data/tablename/20210411" to load a data file named 20210411 from the path /user/data/tablename on the HDFS server.
    You can also specify this parameter as the save path of multiple data files by using wildcards ?, *, [], {}, or ^. See Wildcard reference. For example, you can specify this parameter as "hdfs://<hdfs_host>:<hdfs_port>/user/data/tablename/*/*" or "hdfs://<hdfs_host>:<hdfs_port>/user/data/tablename/dt=202104*/*" to load the data files from all partitions or only 202104 partitions in the path /user/data/tablename on the HDFS server.
    Wildcards can also be used to specify intermediate paths.
    In the preceding examples, the hdfs_host and hdfs_port parameters are described as follows:
    • hdfs_host: the IP address of the NameNode host in the HDFS cluster.
    • hdfs_host: the FS port of the NameNode host in the HDFS cluster. The default port number is 9000.
    NOTICE
    • Broker Load supports accessing AWS S3 according to the S3 or S3A protocol. Therefore, when you load data from AWS S3, you can include s3:// or s3a:// as the prefix in the S3 URI that you pass as the file path.
    • Broker Load supports accessing Google GCS only according to the gs protocol. Therefore, when you load data from Google GCS, you must include gs:// as the prefix in the GCS URI that you pass as the file path.
    • When you load data from Blob Storage, you must use the wasb or wasbs protocol to access your data:
      • If your storage account allows access over HTTP, use the wasb protocol and write the file path as wasb://<container_name>@<storage_account_name>.blob.core.windows.net/<path>/<file_name>/*.
      • If your storage account allows access over HTTPS, use the wasbs protocol and write the file path as wasbs://<container_name>@<storage_account_name>.blob.core.windows.net/<path>/<file_name>/*.
    • When you load data from Data Lake Storage Gen2, you must use the abfs or abfss protocol to access your data:
      • If your storage account allows access over HTTP, use the abfs protocol and write the file path as abfs://<container_name>@<storage_account_name>.dfs.core.windows.net/<file_name>.
      • If your storage account allows access over HTTPS, use the abfss protocol and write the file path as abfss://<container_name>@<storage_account_name>.dfs.core.windows.net/<file_name>.
    • When you load data from Data Lake Storage Gen1, you must use the adl protocol to access your data and write the file path as adl://<data_lake_storage_gen1_name>.azuredatalakestore.net/<path>/<file_name>.
  • INTO TABLE
    Specifies the name of the destination StarRocks table.
data_desc can also optionally include the following parameters:
  • NEGATIVE
    Revokes the loading of a specific batch of data. To achieve this, you need to load the same batch of data with the NEGATIVE keyword specified.
    This parameter is valid only when the StarRocks table is an Aggregate table and all its value columns are computed by the sum function.
  • PARTITION
    Specifies the partitions into which you want to load data. By default, if you do not specify this parameter, the source data will be loaded into all partitions of the StarRocks table.
  • TEMPORARY PARTITION
    Specifies the name of the temporary partition into which you want to load data. You can specify multiple temporary partitions, which must be separated by commas (,).
  • COLUMNS TERMINATED BY
    Specifies the column separator used in the data file. By default, if you do not specify this parameter, this parameter defaults to \t, indicating tab. The column separator you specify using this parameter must be the same as the column separator that is actually used in the data file. Otherwise, the load job will fail due to inadequate data quality, and its State will be CANCELLED.
    Broker Load jobs are submitted according to the MySQL protocol. StarRocks and MySQL both escape characters in the load requests. Therefore, if the column separator is an invisible character such as tab, you must add a backslash () preceding the column separator. For example, you must input \\t if the column separator is \t, and you must input \\n if the column separator is \n. Apache Hiveβ„’ files use \x01 as their column separator, so you must input \\x01 if the data file is from Hive.
    • For CSV data, you can use a UTF-8 string, such as a comma (,), tab, or pipe (|), whose length does not exceed 50 bytes as a text delimiter.
    • Null values are denoted by using \N. For example, a data file consists of three columns, and a record from that data file holds data in the first and third columns but no data in the second column. In this situation, you need to use \N in the second column to denote a null value. This means the record must be compiled as a,\N,b instead of a,,b. a,,b denotes that the second column of the record holds an empty string.
  • ROWS TERMINATED BY
    Specifies the row separator used in the data file. By default, if you do not specify this parameter, this parameter defaults to \n, indicating line break. The row separator you specify using this parameter must be the same as the row separator that is actually used in the data file. Otherwise, the load job will fail due to inadequate data quality, and its State will be CANCELLED. This parameter is supported from v2.5.4 onwards.
    For the usage notes about the row separator, see the usage notes for the preceding COLUMNS TERMINATED BY parameter.
  • FORMAT AS
    Specifies the format of the data file. Valid values: CSV, Parquet, and ORC. By default, if you do not specify this parameter, StarRocks determines the data file format based on the filename extension .csv, .parquet, or .orc specified in the file_path parameter.
  • format_type_options
    Specifies CSV format options when FORMAT AS is set to CSV. Syntax:
    key = value
    key = value
    format_type_options is supported in v3.0 and later.
    The following table describes the options.
    ParameterDescription
    skip_headerSpecifies whether to skip the first rows of the data file when the data file is in CSV format. Type: INTEGER. Default value: 0.
    In some CSV-formatted data files, the first rows at the beginning are used to define metadata such as column names and column data types. By setting the skip_header parameter, you can enable StarRocks to skip the first rows of the data file during data loading. For example, if you set this parameter to 1, StarRocks skips the first row of the data file during data loading.
    The first rows at the beginning in the data file must be separated by using the row separator that you specify in the load statement.
    trim_spaceSpecifies whether to remove spaces preceding and following column separators from the data file when the data file is in CSV format. Type: BOOLEAN. Default value: false.
    For some databases, spaces are added to column separators when you export data as a CSV-formatted data file. Such spaces are called leading spaces or trailing spaces depending on their locations. By setting the trim_space parameter, you can enable StarRocks to remove such unnecessary spaces during data loading.
    Note that StarRocks does not remove the spaces (including leading spaces and trailing spaces) within a field wrapped in a pair of enclose-specified characters. For example, the following field values use pipe (|) as the column separator and double quotation marks (") as the enclose-specified character:
    |"Love StarRocks"|
    |" Love StarRocks "|
    | "Love StarRocks" |
    If you set trim_space to true, StarRocks processes the preceding field values as follows:
    |"Love StarRocks"|
    |" Love StarRocks "|
    |"Love StarRocks"|
    encloseSpecifies the character that is used to wrap the field values in the data file according to RFC4180 when the data file is in CSV format. Type: single-byte character. Default value: NONE. The most prevalent characters are single quotation mark (') and double quotation mark (").
    All special characters (including row separators and column separators) wrapped by using the enclose-specified character are considered normal symbols. StarRocks can do more than RFC4180 as it allows you to specify any single-byte character as the enclose-specified character.
    If a field value contains an enclose-specified character, you can use the same character to escape that enclose-specified character. For example, you set enclose to ", and a field value is a "quoted" c. In this case, you can enter the field value as "a ""quoted"" c" into the data file.
    escapeSpecifies the character that is used to escape various special characters, such as row separators, column separators, escape characters, and enclose-specified characters, which are then considered by StarRocks to be common characters and are parsed as part of the field values in which they reside. Type: single-byte character. Default value: NONE. The most prevalent character is slash (\), which must be written as double slashes (\\) in SQL statements.
    The character specified by escape is applied to both inside and outside of each pair of enclose-specified characters.
    Two examples are as follows:
    • When you set enclose to " and escape to \, StarRocks parses "say \"Hello world\"" into say "Hello world".
    • Assume that the column separator is comma (,). When you set escape to \, StarRocks parses a, b\, c into two separate field values: a and b, c.
  • column_list
    Specifies the column mapping between the data file and the StarRocks table. Syntax: (<column_name>[, <column_name> ...]). The columns declared in column_list are mapped by name onto the StarRocks table columns.
    If the columns of the data file are mapped in sequence onto the columns of the StarRocks table, you do not need to specify column_list.
    If you want to skip a specific column of the data file, you only need to temporarily name that column as different from any of the StarRocks table columns. For more information, see loading overview.
  • COLUMNS FROM PATH AS
    Extracts the information about one or more partition fields from the file path you specify. This parameter is valid only when the file path contains partition fields.
    For example, if the data file is stored in the path /path/col_name=col_value/file1 in which col_name is a partition field and can be mapped onto a column of the StarRocks table, you can specify this parameter as col_name. As such, StarRocks extracts col_value values from the path and loads them into the StarRocks table column onto which col_name is mapped.
    This parameter is available only when you load data from HDFS.
  • SET
    Specifies one or more functions that you want to use to convert a column of the data file. Examples:
    • The StarRocks table consists of three columns, which are col1, col2, and col3 in sequence. The data file consists of four columns, among which the first two columns are mapped in sequence onto col1 and col2 of the StarRocks table and the sum of the last two columns is mapped onto col3 of the StarRocks table. In this case, you need to specify column_list as (col1,col2,tmp_col3,tmp_col4) and specify (col3=tmp_col3+tmp_col4) in the SET clause to implement data conversion.
    • The StarRocks table consists of three columns, which are year, month, and day in sequence. The data file consists of only one column that accommodates date and time values in yyyy-mm-dd hh:mm:ss format. In this case, you need to specify column_list as (tmp_time) and specify (year = year(tmp_time), month=month(tmp_time), day=day(tmp_time)) in the SET clause to implement data conversion.
  • WHERE
    Specifies the conditions based on which you want to filter the source data. StarRocks loads only the source data that meets the filter conditions specified in the WHERE clause.
WITH BROKER​
In v2.3 and earlier, input WITH BROKER "<broker_name>" to specify the broker you want to use. From v2.5 onwards, you no longer need to specify a broker, but you still need to retain the WITH BROKER keyword.
StorageCredentialParams​
The authentication information used by StarRocks to access your storage system.
HDFS​
Open-source HDFS supports two authentication methods: simple authentication and Kerberos authentication. Broker Load uses simple authentication by default. Open-source HDFS also supports configuring an HA mechanism for the NameNode. If you choose open-source HDFS as your storage system, you can specify the authentication configuration and HA configuration as follows:
  • Authentication configuration
    • If you use simple authentication, configure StorageCredentialParams as follows:
      The following table describes the parameters in StorageCredentialParams.
      hadoop.security.authenticationThe authentication method. Valid values: simple and kerberos. Default value: simple. simple represents simple authentication, meaning no authentication, and kerberos represents Kerberos authentication.
      usernameThe username of the account that you want to use to access the NameNode of the HDFS cluster.
      passwordThe password of the account that you want to use to access the NameNode of the HDFS cluster.
    • If you use Kerberos authentication, configure StorageCredentialParams as follows:
      "hadoop.security.authentication" = "kerberos",
      "kerberos_keytab_content" = "YWFhYWFh"
      kerberos_principalThe Kerberos principal to be authenticated. Each principal consists of the following three parts to ensure that it is unique across the HDFS cluster:
      • username or servicename: The name of the principal.
      • instance: the name of the server that hosts the node to be authenticated in the HDFS cluster. The server name helps ensure that the principal is unique, for example, when the HDFS cluster consists of multiple DataNodes that each are independently authenticated.
      • realm: The name of the realm. The realm name must be capitalized.
      Example: nn/zelda1@ZELDA.COM.
      kerberos_keytabThe save path of the Kerberos keytab file.
      kerberos_keytab_contentThe Base64-encoded content of the the Kerberos keytab file. You can choose to specify either kerberos_keytab or kerberos_keytab_content.
  • HA configuration
    You can configure an HA mechanism for the NameNode of the HDFS cluster. This way, if the NameNode is switched over to another node, StarRocks can automatically identify the new node that serves as the NameNode. This includes the following scenarios:
    • If you load data from a single HDFS cluster that has one Kerberos user configured, both broker-based loading and broker-free loading are supported.
      • To perform broker-based loading, make sure that at least one independent broker group is deployed, and place the hdfs-site.xml file to the {deploy}/conf path on the broker node that serves the HDFS cluster. StarRocks will add the {deploy}/conf path to the environment variable CLASSPATH upon broker startup, allowing the brokers to read information about the HDFS cluster nodes.
      • To perform broker-free loading, you only need to set hadoop.security.authentication = kerberos in conf/core-site.xml under the deployment directories of all FE, BE, and CN nodes in your cluster, and use the kinit command to configure the Kerberos account.
    • If you load data from a single HDFS cluster that has multiple Kerberos users configured, only broker-based loading is supported. Make sure that at least one independent broker group is deployed, and place the hdfs-site.xml file to the {deploy}/conf path on the broker node that serves the HDFS cluster. StarRocks will add the {deploy}/conf path to the environment variable CLASSPATH upon broker startup, allowing the brokers to read information about the HDFS cluster nodes.
    • If you load data from multiple HDFS clusters (regardless of whether one or multiple Kerberos users are configured), only broker-based loading is supported. Make sure that at least one independent broker group is deployed for each of these HDFS clusters, and take one of the following actions to enable the brokers to read information about the HDFS cluster nodes:
      • Place the hdfs-site.xml file to the {deploy}/conf path on the broker node that serves each HDFS cluster. StarRocks will add the {deploy}/conf path to the environment variable CLASSPATH upon broker startup, allowing the brokers to read information about the nodes in that HDFS cluster.
      • Add the following HA configuration at job creation:
        "dfs.nameservices" = "ha_cluster",
        "dfs.client.failover.proxy.provider" = "org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider"
        The following table describes the parameters in the HA configuration.
        dfs.nameservicesThe name of the HDFS cluster.
        dfs.ha.namenodes.XXXThe name of the NameNode in the HDFS cluster. If you specify multiple NameNode names, separate them with commas (,). xxx is the HDFS cluster name that you have specified in dfs.nameservices.
        dfs.namenode.rpc-address.XXX.NNThe RPC address of the NameNode in the HDFS cluster. NN is the NameNode name that you have specified in dfs.ha.namenodes.XXX.
        dfs.client.failover.proxy.providerThe provider of the NameNode to which the client will connect. Default value: org.apache.hadoop.hdfs.server.namenode.ha.ConfiguredFailoverProxyProvider.
    You can use the SHOW BROKER statement to check for brokers that are deployed in your StarRocks cluster.
AWS S3​
If you choose AWS S3 as your storage system, take one of the following actions:
  • To choose the instance profile-based authentication method, configure StorageCredentialParams as follows:
  • To choose the assumed role-based authentication method, configure StorageCredentialParams as follows:
  • To choose the IAM user-based authentication method, configure StorageCredentialParams as follows:
The following table describes the parameters you need to configure in StorageCredentialParams.
ParameterRequiredDescription
aws.s3.use_instance_profileYesSpecifies whether to enable the credential methods instance profile and assumed role. Valid values: true and false. Default value: false.
aws.s3.iam_role_arnNoThe ARN of the IAM role that has privileges on your AWS S3 bucket. If you choose assumed role as the credential method for accessing AWS S3, you must specify this parameter.
aws.s3.regionYesThe region in which your AWS S3 bucket resides. Example: us-west-1.
aws.s3.access_keyNoThe access key of your IAM user. If you choose IAM user as the credential method for accessing AWS S3, you must specify this parameter.
aws.s3.secret_keyNoThe secret key of your IAM user. If you choose IAM user as the credential method for accessing AWS S3, you must specify this parameter.
For information about how to choose an authentication method for accessing AWS S3 and how to configure an access control policy in AWS IAM Console, see Authentication parameters for accessing AWS S3.
Google GCS​
If you choose Google GCS as your storage system, take one of the following actions:
  • To choose the VM-based authentication method, configure StorageCredentialParams as follows:
    ParameterDefault valueValue exampleDescription
    gcp.gcs.use_compute_engine_service_accountfalsetrueSpecifies whether to directly use the service account that is bound to your Compute Engine.
  • To choose the service account-based authentication method, configure StorageCredentialParams as follows:
    gcp.gcs.service_account_email"""user@hello.iam.gserviceaccount.com"The email address in the JSON file generated at the creation of the service account.
    gcp.gcs.service_account_private_key_id"""61d257bd8479547cb3e04f0b9b6b9ca07af3b7ea"The private key ID in the JSON file generated at the creation of the service account.
    gcp.gcs.service_account_private_key"""-----BEGIN PRIVATE KEY----xxxx-----END PRIVATE KEY-----\n"The private key in the JSON file generated at the creation of the service account.
  • To choose the impersonation-based authentication method, configure StorageCredentialParams as follows:
    • Make a VM instance impersonate a service account:
      gcp.gcs.impersonation_service_account"""hello"The service account that you want to impersonate.
    • Make a service account (named as meta service account) impersonate another service account (named as data service account):
      gcp.gcs.service_account_email"""user@hello.iam.gserviceaccount.com"The email address in the JSON file generated at the creation of the meta service account.
      gcp.gcs.service_account_private_key_id"""61d257bd8479547cb3e04f0b9b6b9ca07af3b7ea"The private key ID in the JSON file generated at the creation of the meta service account.
      gcp.gcs.service_account_private_key"""-----BEGIN PRIVATE KEY----xxxx-----END PRIVATE KEY-----\n"The private key in the JSON file generated at the creation of the meta service account.
      gcp.gcs.impersonation_service_account"""hello"The data service account that you want to impersonate.
Other S3-compatible storage system​
If you choose other S3-compatible storage system, such as MinIO, configure StorageCredentialParams as follows:
aws.s3.enable_sslYesSpecifies whether to enable SSL connection. Valid values: true and false. Default value: true.
aws.s3.enable_path_style_accessYesSpecifies whether to enable path-style URL access. Valid values: true and false. Default value: false. For MinIO, you must set the value to true.
aws.s3.endpointYesThe endpoint that is used to connect to your S3-compatible storage system instead of AWS S3.
aws.s3.access_keyYesThe access key of your IAM user.
aws.s3.secret_keyYesThe secret key of your IAM user.
Microsoft Azure Storage​
Azure Blob Storage​
If you choose Blob Storage as your storage system, take one of the following actions:
  • To choose the Shared Key authentication method, configure StorageCredentialParams as follows:
    "azure.blob.storage_account" = "<storage_account_name>",
    "azure.blob.shared_key" = "<storage_account_shared_key>"
    azure.blob.storage_accountYesThe username of your Blob Storage account.
    azure.blob.shared_keyYesThe shared key of your Blob Storage account.
  • To choose the SAS Token authentication method, configure StorageCredentialParams as follows:
    azure.blob.containerYesThe name of the blob container that stores your data.
    azure.blob.sas_tokenYesThe SAS token that is used to access your Blob Storage account.
Azure Data Lake Storage Gen2​
If you choose Data Lake Storage Gen2 as your storage system, take one of the following actions:
  • To choose the Managed Identity authentication method, configure StorageCredentialParams as follows:
    azure.adls2.oauth2_use_managed_identityYesSpecifies whether to enable the Managed Identity authentication method. Set the value to true.
    azure.adls2.oauth2_tenant_idYesThe ID of the tenant whose data you want to access.
    azure.adls2.oauth2_client_idYesThe client (application) ID of the managed identity.
    "azure.adls2.shared_key" = "<storage_account_shared_key>"
    azure.adls2.storage_accountYesThe username of your Data Lake Storage Gen2 storage account.
    azure.adls2.shared_keyYesThe shared key of your Data Lake Storage Gen2 storage account.
  • To choose the Service Principal authentication method, configure StorageCredentialParams as follows:
    azure.adls2.oauth2_client_idYesThe client (application) ID of the service principal.
    azure.adls2.oauth2_client_secretYesThe value of the new client (application) secret created.
    azure.adls2.oauth2_client_endpointYesThe OAuth 2.0 token endpoint (v1) of the service principal or application.
Azure Data Lake Storage Gen1​
If you choose Data Lake Storage Gen1 as your storage system, take one of the following actions:
  • To choose the Managed Service Identity authentication method, configure StorageCredentialParams as follows:
    azure.adls1.use_managed_service_identityYesSpecifies whether to enable the Managed Service Identity authentication method. Set the value to true.
    azure.adls1.oauth2_client_idYesThe client (application) ID of the .
    azure.adls1.oauth2_credentialYesThe value of the new client (application) secret created.
    azure.adls1.oauth2_endpointYesThe OAuth 2.0 token endpoint (v1) of the service principal or application.
opt_properties​
Specifies some optional parameters whose settings are applied to the entire load job. Syntax:
The following parameters are supported:
  • timeout
    Specifies the timeout period of the load job. Unit: second. The default timeout period is 4 hours. We recommend that you specify a timeout period shorter than 6 hours. If the load job does not finish within the timeout period, StarRocks cancels the load job and the status of the load job becomes CANCELLED.
    In most cases, you do not need to set the timeout period. We recommend that you set the timeout period only when the load job cannot finish within the default timeout period.
    Use the following formula to infer the timeout period:
    Timeout period > (Total size of the data files to be loaded x Total number of the data files to be loaded and the materialized views created on the data files)/Average load speed
    "Average load speed" is the average load speed for your entire StarRocks cluster. The average load speed varies for each cluster depending on the server configuration and the maximum number of concurrent query tasks allowed for the cluster. You can infer the average load speed based on the load speeds of historical load jobs.
    Suppose that you want to load a 1-GB data file on which two materialized views are created into a StarRocks cluster whose average load speed is 10 MB/s. The amount of time required for the data load is approximately 102 seconds.
    (1 x 1024 x 3)/10 = 307.2 (second)
    For this example, we recommend that you set the timeout period to a value greater than 308 seconds.
  • max_filter_ratio
    Specifies the maximum error tolerance of the load job. The maximum error tolerance is the maximum percentage of rows that can be filtered out as a result of inadequate data quality. Valid values: 0~1. Default value: 0.
    • If you set this parameter to 0, StarRocks does not ignore unqualified rows during loading. As such, if the source data contains unqualified rows, the load job fails. This helps ensure the correctness of the data loaded into StarRocks.
    • If you set this parameter to a value greater than 0, StarRocks can ignore unqualified rows during loading. As such, the load job can succeed even if the source data contains unqualified rows.
      Rows that are filtered out due to inadequate data quality do not include rows that are filtered out by the WHERE clause.
    If the load job fails because the maximum error tolerance is set to 0, you can use SHOW LOAD to view the job result. Then, determine whether unqualified rows can be filtered out. If unqualified rows can be filtered out, calculate the maximum error tolerance based on the values returned for dpp.abnorm.ALL and dpp.norm.ALL in the job result, adjust the maximum error tolerance, and submit the load job again. The formula for calculating the maximum error tolerance is as follows:
    max_filter_ratio = [dpp.abnorm.ALL/(dpp.abnorm.ALL + dpp.norm.ALL)]
    The sum of the values returned for dpp.abnorm.ALL and dpp.norm.ALL is the total number of rows to be loaded.
  • log_rejected_record_num
    Specifies the maximum number of unqualified data rows that can be logged. This parameter is supported from v3.1 onwards. Valid values: 0, -1, and any non-zero positive integer. Default value: 0.
    • The value 0 specifies that data rows that are filtered out will not be logged.
    • The value -1 specifies that all data rows that are filtered out will be logged.
    • A non-zero positive integer such as n specifies that up to n data rows that are filtered out can be logged on each BE.
  • load_mem_limit
    Specifies the maximum amount of memory that can be provided to the load job. The value of this parameter cannot exceed the upper memory limit supported by each BE or CN node. Unit: bytes: The default memory limit is 2 GB.
  • strict_mode
    Specifies whether to enable the strict mode. Valid values: true and false. Default value: false. true specifies to enable the strict mode, and false specifies to disable the strict mode.
  • timezone
    Specifies the time zone of the load job. Default value: Asia/Shanghai. The time zone setting affects the results returned by functions such as strftime, alignment_timestamp, and from_unixtime. For more information, see Configure a time zone. The time zone specified in the timezone parameter is a session-level time zone.
  • priority
    Specifies the priority of the load job. Valid values: LOWEST, LOW, NORMAL, HIGH, and HIGHEST. Default value: NORMAL. Broker Load provides the FE parameter max_broker_load_job_concurrency, determines the maximum number of Broker Load jobs that can be concurrently run within your StarRocks cluster. If the number of Broker Load jobs that are submitted within the specified time period exceeds the maximum number, excessive jobs will be waiting to be scheduled based on their priorities.
    You can use the ALTER LOAD statement to change the priority of an existing load job that is in the QUEUEING or LOADING state.
    StarRocks allows setting the priority parameter for a Broker Load job since v2.5.
  • partial_update
    Whether to use partial updates. Valid values: TRUE and FALSE. Default value: FALSE, indicating to disable this feature.
  • partial_update_mode
    Specifies the mode for partial updates. Valid values: row and column.
    • The value row (default) means partial updates in row mode, which is more suitable for real-time updates with many columns and small batches.
    • The value column means partial updates in column mode, which is more suitable for batch updates with few columns and many rows. In such scenarios, enabling the column mode offers faster update speeds. For example, in a table with 100 columns, if only 10 columns (10% of the total) are updated for all rows, the update speed of the column mode is 10 times faster.
  • merge_condition
    Specifies the name of the column you want to use as the condition to determine whether updates can take effect. The update from a source record to a destination record takes effect only when the source data record has a greater or equal value than the destination data record in the specified column.
    The column that you specify cannot be a primary key column. Additionally, only tables that use the Primary Key table support conditional updates.
StarRocks supports loading JSON data from v3.2.3 onwards. The parameters are as follows:
  • jsonpaths
    The names of the keys that you want to load from the JSON data file. You need to specify this parameter only when you load JSON data by using the matched mode. The value of this parameter is in JSON format. See Configure column mapping for JSON data loading.
  • strip_outer_array
    Specifies whether to strip the outermost array structure. Valid values: true and false. Default value: false.
    In real-world business scenarios, the JSON data may have an outermost array structure as indicated by a pair of square brackets []. In this situation, we recommend that you set this parameter to true, so StarRocks removes the outermost square brackets [] and loads each inner array as a separate data record. If you set this parameter to false, StarRocks parses the entire JSON data file into one array and loads the array as a single data record. For example, the JSON data is [ {"category" : 1, "author" : 2}, {"category" : 3, "author" : 4} ]. If you set this parameter to true, {"category" : 1, "author" : 2} and {"category" : 3, "author" : 4} are parsed into separate data records that are loaded into separate StarRocks table rows.
  • json_root
    The root element of the JSON data that you want to load from the JSON data file. You need to specify this parameter only when you load JSON data by using the matched mode. The value of this parameter is a valid JsonPath string. By default, the value of this parameter is empty, indicating that all data of the JSON data file will be loaded. For more information, see the "Load JSON data using matched mode with root element specified" section of this topic.
When you load JSON data, also note that the size per JSON object cannot exceed 4 GB. If an individual JSON object in the JSON data file exceeds 4 GB in size, an error "This parser can't support a document that big." is reported.
Column mapping​
Configure column mapping for CSV data loading​
If the columns of the data file can be mapped one on one in sequence to the columns of the StarRocks table, you do not need to configure the column mapping between the data file and the StarRocks table.
If the columns of the data file cannot be mapped one on one in sequence to the columns of the StarRocks table, you need to use the columns parameter to configure the column mapping between the data file and the StarRocks table. This includes the following two use cases:
  • Same number of columns but different column sequence. Also, the data from the data file does not need to be computed by functions before it is loaded into the matching StarRocks table columns.
    In the columns parameter, you need to specify the names of the StarRocks table columns in the same sequence as how the data file columns are arranged.
    For example, the StarRocks table consists of three columns, which are col1, col2, and col3 in sequence, and the data file also consists of three columns, which can be mapped to the StarRocks table columns col3, col2, and col1 in sequence. In this case, you need to specify "columns: col3, col2, col1".
  • Different number of columns and different column sequence. Also, the data from the data file needs to be computed by functions before it is loaded into the matching StarRocks table columns.
    In the columns parameter, you need to specify the names of the StarRocks table columns in the same sequence as how the data file columns are arranged and specify the functions you want to use to compute the data. Two examples are as follows:
    • The StarRocks table consists of three columns, which are col1, col2, and col3 in sequence. The data file consists of four columns, among which the first three columns can be mapped in sequence to the StarRocks table columns col1, col2, and col3 and the fourth column cannot be mapped to any of the StarRocks table columns. In this case, you need to temporarily specify a name for the fourth column of the data file, and the temporary name must be different from any of the StarRocks table column names. For example, you can specify "columns: col1, col2, col3, temp", in which the fourth column of the data file is temporarily named temp.
    • The StarRocks table consists of three columns, which are year, month, and day in sequence. The data file consists of only one column that accommodates date and time values in yyyy-mm-dd hh:mm:ss format. In this case, you can specify "columns: col, year = year(col), month=month(col), day=day(col)", in which col is the temporary name of the data file column and the functions year = year(col), month=month(col), and day=day(col) are used to extract data from the data file column col and loads the data into the mapping StarRocks table columns. For example, year = year(col) is used to extract the yyyy data from the data file column col and loads the data into the StarRocks table column year.
For detailed examples, see Configure column mapping.
Configure column mapping for JSON data loading​
If the keys of the JSON document have the same names as the columns of the StarRocks table, you can load the JSON-formatted data by using the simple mode. In simple mode, you do not need to specify the jsonpaths parameter. This mode requires that the JSON-formatted data must be an object as indicated by curly brackets {}, such as {"category": 1, "author": 2, "price": "3"}. In this example, category, author, and price are key names, and these keys can be mapped one on one by name to the columns category, author, and price of the StarRocks table.
If the keys of the JSON document have different names than the columns of the StarRocks table, you can load the JSON-formatted data by using the matched mode. In matched mode, you need to use the jsonpaths and COLUMNS parameters to specify the column mapping between the JSON document and the StarRocks table:
  • In the jsonpaths parameter, specify the JSON keys in the sequence as how they are arranged in the JSON document.
  • In the COLUMNS parameter, specify the mapping between the JSON keys and the StarRocks table columns:
    • The column names specified in the COLUMNS parameter are mapped one on one in sequence to the JSON keys.
    • The column names specified in the COLUMNS parameter are mapped one on one by name to the StarRocks table columns.
For examples about loading JSON-formatted data by using the matched mode, see Load JSON data using matched mode.
The FE configuration item max_broker_load_job_concurrency specifies the maximum number of Broker Load jobs that can be concurrently run within your StarRocks cluster.
In StarRocks v2.4 and earlier, if the total number of Broker Load jobs that are submitted within a specific period of time exceeds the maximum number, excessive jobs will be queued and scheduled based on their submission time.
Since StarRocks v2.5, if the total number of Broker Load jobs that are submitted within a specific period of time exceeds the maximum number, excessive jobs are queued and scheduled based on their priorities. You can specify a priority for a job by using the priority parameter described above. You can use ALTER LOAD to modify the priority of an existing job that is in the QUEUEING or LOADING state.
Job splitting and concurrent running​
A Broker Load job can be split into one or more tasks that concurrently run. The tasks within a load job are run within a single transaction. They must all succeed or fail. StarRocks splits each load job based on how you declare data_desc in the LOAD statement:
  • If you declare multiple data_desc parameters, each of which specifies a distinct table, a task is generated to load the data of each table.
  • If you declare multiple data_desc parameters, each of which specifies a distinct partition for the same table, a task is generated to load the data of each partition.
Additionally, each task can be further split into one or more instances, which are evenly distributed to and concurrently run on the BEs or CNs of your StarRocks cluster. StarRocks splits each task based on the FE parameter min_bytes_per_broker_scanner and the number of BE or CN nodes. You can use the following formula to calculate the number of instances in an individual task:
Number of instances in an individual task = min(Amount of data to be loaded by an individual task/min_bytes_per_broker_scanner, Number of BE/CN nodes)
In most cases, only one data_desc is declared for each load job, each load job is split into only one task, and the task is split into the same number of instances as the number of BE or CN nodes.
This section uses HDFS as an example to describe various load configurations.
Load CSV data​
This section uses CSV as an example to explain the various parameter configurations that you can use to meet your diverse load requirements.
Set timeout period​
Your StarRocks database test_db contains a table named table1. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example1.csv also consists of three columns, which are mapped in sequence onto col1, col2, and col3 of table1.
If you want to load all data from example1.csv into table1 within up to 3600 seconds, run the following command:
LOAD LABEL test_db.label1
INTO TABLE table1
WITH BROKER
PROPERTIES
"timeout" = "3600"
Set maximum error tolerance​
Your StarRocks database test_db contains a table named table2. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example2.csv also consists of three columns, which are mapped in sequence onto col1, col2, and col3 of table2.
If you want to load all data from example2.csv into table2 with a maximum error tolerance of 0.1, run the following command:
LOAD LABEL test_db.label2
INTO TABLE table2
WITH BROKER
PROPERTIES
"max_filter_ratio" = "0.1"
Load all data files from a file path​
Your StarRocks database test_db contains a table named table3. The table consists of three columns, which are col1, col2, and col3 in sequence.
All data files stored in the /user/starrocks/data/input/ path of your HDFS cluster also each consist of three columns, which are mapped in sequence onto col1, col2, and col3 of table3. The column separator used in these data files is \x01.
If you want to load data from all these data files stored in the hdfs://<hdfs_host>:<hdfs_port>/user/starrocks/data/input/ path into table3, run the following command:
LOAD LABEL test_db.label3
INTO TABLE table3
COLUMNS TERMINATED BY "\\x01"
WITH BROKER
Set NameNode HA mechanism​
Your StarRocks database test_db contains a table named table4. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example4.csv also consists of three columns, which are mapped onto col1, col2, and col3 of table4.
If you want to load all data from example4.csv into table4 with an HA mechanism configured for the NameNode, run the following command:
LOAD LABEL test_db.label4
INTO TABLE table4
WITH BROKER
"dfs.nameservices" = "my_ha",
"dfs.ha.namenodes.my_ha" = "my_namenode1, my_namenode2","dfs.namenode.rpc-address.my_ha.my_namenode1" = "nn1_host:rpc_port",
Set Kerberos authentication​
Your StarRocks database test_db contains a table named table5. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example5.csv also consists of three columns, which are mapped in sequence onto col1, col2, and col3 of table5.
If you want to load all data from example5.csv into table5 with Kerberos authentication configured and the keytab file path specified, run the following command:
LOAD LABEL test_db.label5
INTO TABLE table5
COLUMNS TERMINATED BY "\t"
WITH BROKER
Revoke data loading​
Your StarRocks database test_db contains a table named table6. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example6.csv also consists of three columns, which are mapped in sequence onto col1, col2, and col3 of table6.
You have loaded all data from example6.csv into table6 by running a Broker Load job.
If you want to revoke the data you have loaded, run the following command:
LOAD LABEL test_db.label6
NEGATIVE
INTO TABLE table6
WITH BROKER
Specify destination partitions​
Your StarRocks database test_db contains a table named table7. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example7.csv also consists of three columns, which are mapped in sequence onto col1, col2, and col3 of table7.
If you want to load all data from example7.csv into two partitions, p1 and p2, of table7, run the following command:
LOAD LABEL test_db.label7
INTO TABLE table7
PARTITION (p1, p2)
COLUMNS TERMINATED BY ","
WITH BROKER
Configure column mapping​
Your StarRocks database test_db contains a table named table8. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example8.csv also consists of three columns, which are mapped in sequence onto col2, col1, and col3 of table8.
If you want to load all data from example8.csv into table8, run the following command:
LOAD LABEL test_db.label8
INTO TABLE table8
(col2, col1, col3)
WITH BROKER
In the preceding example, the columns of example8.csv cannot be mapped onto the columns of table8 in the same sequence as how these columns are arranged in table8. Therefore, you need to use column_list to configure the column mapping between example8.csv and table8.
Set filter conditions​
Your StarRocks database test_db contains a table named table9. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example9.csv also consists of three columns, which are mapped in sequence onto col1, col2, and col3 of table9.
If you want to load only the data records whose values in the first column are greater than 20180601 from example9.csv into table9, run the following command:
LOAD LABEL test_db.label9
INTO TABLE table9
(col1, col2, col3)
where col1 > 20180601
WITH BROKER
In the preceding example, the columns of example9.csv can be mapped onto the columns of table9 in the same sequence as how these columns are arranged in table9, but you need to use the WHERE clause to specify column-based filter conditions. Therefore, you need to use column_list to configure the column mapping between example9.csv and table9.
Load data into tables containing HLL-type columns​
Your StarRocks database test_db contains a table named table10. The table consists of four columns, which are id, col1, col2, and col3 in sequence. col1 and col2 are defined as HLL-type columns.
Your data file example10.csv consists of three columns, among which the first column is mapped onto id of table10 and the second and third columns are mapped in sequence onto col1 and col2 of table10. The values in the second and third columns of example10.csv can be converted into HLL-type data by using functions before they are loaded into col1 and col2 of table10.
If you want to load all data from example10.csv into table10, run the following command:
LOAD LABEL test_db.label10
INTO TABLE table10
(id, temp1, temp2)
SET
col1 = hll_hash(temp1),
col2 = hll_hash(temp2),
col3 = empty_hll()
WITH BROKER
In the preceding example, the three columns of example10.csv are named id, temp1, and temp2 in sequence by using column_list. Then, functions are used to convert data as follows:
  • The hll_hash function is used to convert the values in temp1 and temp2 of example10.csv into HLL-type data and map temp1 and temp2 of example10.csv onto col1 and col2 of table10.
  • The hll_empty function is used to fill the specified default value into col3 of table10.
For usage of the functions hll_hash and hll_empty, see hll_hash and hll_empty.
Extract partition field values from file path​
Broker Load supports parsing the values of specific partition fields contained in a file path based on the column definitions of the destination StarRocks table. This feature of StarRocks is similar to the Partition Discovery feature of Apache Sparkβ„’.
Your StarRocks database test_db contains a table named table11. The table consists of five columns, which are col1, col2, col3, city, and utc_date in sequence.
The file path /user/starrocks/data/input/dir/city=beijing of your HDFS cluster contains the following data files:
  • /user/starrocks/data/input/dir/city=beijing/utc_date=2019-06-26/0000.csv
  • /user/starrocks/data/input/dir/city=beijing/utc_date=2019-06-26/0001.csv
These data files each consist of three columns, which are mapped in sequence onto col1, col2, and col3 of table11.
If you want to load data from all data files from the file path /user/starrocks/data/input/dir/city=beijing/utc_date=*/* into table11 and, at the same time, you want to extract the values of the partition fields city and utc_date contained in the file path and load the extracted values into city and utc_date of table11, run the following command:
LOAD LABEL test_db.label11
INTO TABLE table11
FORMAT AS "csv"
(col1, col2, col3)
WITH BROKER
Extract partition field values from %3A-included file path​
In HDFS, file paths cannot contain colons (:). All colons (:) will be converted into %3A.
Your StarRocks database test_db contains a table named table12. The table consists of three columns, which are data_time, col1, and col2 in sequence. The table schema is as follows:
data_time DATETIME,
col1 INT,
col2 INT
The file path /user/starrocks/data of your HDFS cluster contains the following data files:
  • /user/starrocks/data/data_time=2020-02-17 00%3A00%3A00/example12.csv
  • /user/starrocks/data/data_time=2020-02-18 00%3A00%3A00/example12.csv
If you want to load all data from example12.csv into table12 and, at the same time, you want to extract the values of the partition field data_time from the file path and load the extracted values into data_time of table12, run the following command:
LOAD LABEL test_db.label12
INTO TABLE table12
FORMAT AS "csv"
(col1,col2)
WITH BROKER
In the preceding example, the values extracted from the partition field data_time are strings that contain %3A, such as 2020-02-17 00%3A00%3A00. Therefore, you need to use the str_to_date function to convert the strings into DATETIME-type data before they are loaded into data_time of table8.
Setting format_type_options​
Your StarRocks database test_db contains a table named table13. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example13.csv also consists of three columns, which are mapped in sequence onto col2, col1, and col3 of table13.
If you want to load all data from example13.csv into table13, with the intention of skipping the first two rows of example13.csv, removing the spaces preceding and following column separators, and setting enclose to \ and escape to \, run the following command:
LOAD LABEL test_db.label13
INTO TABLE table13
FORMAT AS "CSV"
skip_header = 2
trim_space = TRUE
enclose = "\""
escape = "\\"
(col2, col1, col3)
WITH BROKER
"username" = "hdfs_username",
"password" = "hdfs_password"
PROPERTIES
"timeout" = "3600"
Load Parquet data​
This section describes some parameters settings you need to take note of when you load Parquet data.
Your data file example13.parquet also consists of three columns, which are mapped in sequence onto col1, col2, and col3 of table13.
If you want to load all data from example13.parquet into table13, run the following command:
INTO TABLE table13
FORMAT AS "parquet"
(col1, col2, col3)
WITH BROKER
By default, when you load Parquet data, StarRocks determines the data file format based on whether the filename contains the extension .parquet. If the filename does not contain the extension .parquet, you must use FORMAT AS to specify the data file format as Parquet.
Load ORC data​
This section describes some parameters settings you need to take note of when you load ORC data.
Your StarRocks database test_db contains a table named table14. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example14.orc also contains three columns, which are mapped in sequence onto col1, col2, and col3 of table14.
If you want to load all data from example14.orc into table14, run the following command:
LOAD LABEL test_db.label14
INTO TABLE table14
FORMAT AS "orc"
(col1, col2, col3)
WITH BROKER
  • By default, when you load ORC data, StarRocks determines the data file format based on whether the filename contains the extension .orc. If the filename does not contain the extension .orc, you must use FORMAT AS to specify the data file format as ORC.
  • In StarRocks v2.3 and earlier, if the data file contains ARRAY-type columns, you must make sure that the columns of the ORC data file have the same names as their mapping columns in the StarRocks table and the columns cannot be specified in the SET clause.
Load JSON data​
This section describes the parameter settings that you need to take note of when you load JSON data.
Your StarRocks database test_db contains a table named tbl1, whose schema is as follows:
Load JSON data using simple mode​
Suppose that your data file example1.json consists of the following data:
To load all data from example1.json into tbl1, run the following command:
LOAD LABEL test_db.label15
INTO TABLE tbl1
FORMAT AS "json"
WITH BROKER
In the preceding example, the parameters columns and jsonpaths are not specified. Therefore, the keys in example1.json are mapped by name onto the columns of tbl1.
Load JSON data using matched mode​
StarRocks performs the following steps to match and process JSON data:
  1. (Optional) Strips the outermost array structure as instructed by the strip_outer_array parameter setting.
    This step is performed only when the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets []. You need to set strip_outer_array to true.
  2. (Optional) Matches the root element of the JSON data as instructed by the json_root parameter setting.
    This step is performed only when the JSON data has a root element. You need to specify the root element by using the json_root parameter.
  3. Extracts the specified JSON data as instructed by the jsonpaths parameter setting.
Load JSON data using matched mode without root element specified​
Suppose that your data file example2.json consists of the following data:
To load only category, author, and price from example2.json, run the following command:
LOAD LABEL test_db.label16
INTO TABLE tbl1
FORMAT AS "json"
(category, price, author)
WITH BROKER
PROPERTIES
"strip_outer_array" = "true",
In the preceding example, the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets []. The array structure consists of multiple JSON objects that each represent a data record. Therefore, you need to set strip_outer_array to true to strip the outermost array structure. The key title that you do not want to load is ignored during loading.
Load JSON data using matched mode with root element specified​
Suppose your data file example3.json consists of the following data:
"id": 10001,
"RECORDS":[
To load only category, author, and price from example3.json, run the following command:
LOAD LABEL test_db.label17
INTO TABLE tbl1
FORMAT AS "json"
WITH BROKER
PROPERTIES
"json_root"="$.RECORDS",
In the preceding example, the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets []. The array structure consists of multiple JSON objects that each represent a data record. Therefore, you need to set strip_outer_array to true to strip the outermost array structure. The keys title and timestamp that you do not want to load are ignored during loading. Additionally, the json_root parameter is used to specify the root element, which is an array, of the JSON data.
