Version: Candidate-4.1
ALTER LOAD
ALTER LOAD changes the priority of a Broker Load job that is in the QUEUEING or LOADING state. This statement is supported since v2.5.
Changing the priority of a Broker Load job that is in the LOADING state does not affect the execution of the job.
ALTER LOAD FOR <label_name>
PROPERTIES
'priority'='{LOWEST | LOW | NORMAL | HIGH | HIGHEST}'
ParameterRequiredDescription
label_nameYesThe label of the load job. Format: [<database_name>.]<label_name>. See BROKER LOAD.
priorityYesThe new priority that you want to specify for the load job. Valid values: LOWEST, LOW, NORMAL, HIGH, and HIGHEST. See BROKER LOAD.
Suppose that you have a Broker Load job whose label is test_db.label1 and the job is in the QUEUEING state. If you want to run the job at the soonest, you can run the following command to change the priority of the job to HIGHEST:
ALTER LOAD FOR test_db.label1
PROPERTIES
'priority'='HIGHEST'
