Version: Candidate-4.1
CREATE ANALYZE
CREATE ANALYZE customizes an automatic collection task for collecting CBO statistics.
By default, StarRocks automatically collects full statistics of a table. It checks for any data updates every 5 minutes. If data change is detected, data collection will be automatically triggered. If you do not want to use automatic full collection, you can set the FE configuration item enable_collect_full_statistic to false and customize a collection task.
Behaviour difference:
  • Before 3.2.12 and 3.3.4, to create a custom automatic collection task, you must disable automatic full collection (enable_collect_full_statistic = false). Otherwise, custom tasks cannot take effect.
  • Since these version, you can create analyze job and keep system tasks. The user-created tasks would overwrite the system tasks if they have conflicts.
This statement is supported from v2.4.
CREATE ANALYZE [FULL|SAMPLE] ALL PROPERTIES (property [,property])
CREATE ANALYZE [FULL|SAMPLE] [IF NOT EXISTS] TABLE tbl_name (col_name [,col_name])
Parameter description​
  • Collection type
    • FULL: indicates full collection.
    • SAMPLE: indicates sampled collection.
    • If no collection type is specified, sampled collection is used by default.
  • col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected.
  • PROPERTIES: custom parameters. If PROPERTIES is not specified, the default settings in fe.conf are used. The properties that are actually used can be viewed via the Properties column in the output of SHOW ANALYZE JOB.
PROPERTIESTypeDefault valueDescription
statistic_auto_collect_ratioFLOAT0.8The threshold for determining whether the statistics for automatic collection are healthy. If the statistics health is below this threshold, automatic collection is triggered.
statistics_max_full_collect_data_sizeINT100The size of the largest partition for automatic collection to collect data. Unit: GB.If a partition exceeds this value, full collection is discarded and sampled collection is performed instead.
statistic_sample_collect_rowsINT200000The minimum number of rows to collect.If the parameter value exceeds the actual number of rows in your table, full collection is performed.
Example 1: Automatic full collection
CREATE ANALYZE ALL;
Example 2: Automatic sampled collection
-- Automatically collect stats of all tables in a database using default settings.
CREATE ANALYZE SAMPLE TABLE tbl_name(c1, c2, c3) PROPERTIES(
References​
SHOW ANALYZE JOB: view the status of a custom collection task.
DROP ANALYZE: delete a custom collection task.
KILL ANALYZE: cancel a custom collection task that is running.
For more information about collecting statistics for CBO, see Gather statistics for CBO.
