ANALYZE TABLE
ANALYZE TABLE creates a manual collection task for collecting CBO statistics. By default, manual collection is a synchronous operation. You can also set it to an asynchronous operation. In asynchronous mode, after you run ANALYZE TABLE, the system immediately returns whether this statement is successful. However, the collection task will be running in the background and you do not have to wait for the result. You can check the status of the task by running SHOW ANALYZE STATUS. Asynchronous collection is suitable for tables with large data volume, whereas synchronous collection is suitable for tables with small data volume.
Manual collection tasks are run only once after creation. You do not need to delete manual collection tasks.
This statement is supported from v2.4.
Manually collect basic statistics​
For more information about basic statistics, see Gather statistics for CBO.
[WITH SYNC | ASYNC MODE]
PROPERTIES (property [,property])
Parameter description​
  • Collection type
    • FULL: indicates full collection.
    • SAMPLE: indicates sampled collection.
    • If no collection type is specified, full collection is used by default.
  • col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected.
  • [WITH SYNC | ASYNC MODE]: whether to run the manual collection task in synchronous or asynchronous mode. Synchronous collection is used by default if you do not specify this parameter.
  • PROPERTIES: custom parameters. If PROPERTIES is not specified, the default settings in the fe.conf file are used. The properties that are actually used can be viewed via the Properties column in the output of SHOW ANALYZE STATUS.
PROPERTIESTypeDefault valueDescription
statistic_sample_collect_rowsINT200000The minimum number of rows to collect for sampled collection.If the parameter value exceeds the actual number of rows in your table, full collection is performed.
Example 1: Manual full collection
ANALYZE TABLE tbl_name;
ANALYZE FULL TABLE tbl_name;
Example 2: Manual sampled collection
Manually collect histograms​
For more information about histograms, see Gather statistics for CBO.
[WITH N BUCKETS]
PROPERTIES (property [,property]);
  • col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected. This parameter is required for histograms.
  • WITH N BUCKETS: N is the number of buckets for histogram collection. If not specified, the default value in fe.conf is used.
  • PROPERTIES: custom parameters. If PROPERTIES is not specified, the default settings in fe.conf are used. The properties that are actually used can be viewed via the Properties column in the output of SHOW ANALYZE STATUS.
statistic_sample_collect_rowsINT200000The minimum number of rows to collect. If the parameter value exceeds the actual number of rows in your table, full collection is performed.
histogram_buckets_sizeLONG64The default bucket number for a histogram.
histogram_mcv_sizeINT100The number of most common values (MCV) for a histogram.
histogram_sample_ratioFLOAT0.1The sampling ratio for a histogram.
histogram_max_sample_row_countLONG10000000The maximum number of rows to collect for a histogram.
PROPERTIES(
"histogram_mcv_size" = "32",
References​
SHOW ANALYZE STATUS: view the status of a manual collection task.
KILL ANALYZE: cancel a manual collection task that is running.
For more information about collecting statistics for CBO, see Gather statistics for CBO.
