Version: Latest-4.1
url_extract_host
Extracts the host section from a URL.
This function is supported from v3.3 onwards.
VARCHAR url_extract_host(VARCHAR str)
  • str: the string to extract its host string. If str is not a string, this function will try implicit cast first.
Returns the host string.
mysql> select url_extract_host('httpa://starrocks.com/test/api/v1');
| url_extract_host('httpa://starrocks.com/test/api/v1') |
| starrocks.com |
