regexp_split
Split string str by regexp expression pattern, return maximum max_split elements in ARRAY<VARCHAR> type.
regexp_split(str, pattern[, max_split])
Parametersβ
str: required, the string to split, which must evaluate to a VARCHAR value.
pattern: required, the regexp expression pattern used to split, which must evaluate to a VARCHAR value.
max_split: optional, the number of maximum elements in the output value, which must evaluate to an INT value.
Return valueβ
Returns an ARRAY<VARCHAR> value.
mysql> select regexp_split('StarRocks', '');
| regexp_split('StarRocks', '')         |
| ["S","t","a","r","R","o","c","k","s"] |
mysql> select regexp_split('StarRocks', '[SR]');
| regexp_split('StarRocks', '[SR]') |
| ["","tar","ocks"]                 |
mysql> select regexp_split('StarRocks', '[SR]', 1);
| regexp_split('StarRocks', '[SR]', 1) |
| ["StarRocks"]                        |
mysql> select regexp_split('StarRocks', '[SR]', 2);
| ["","tarRocks"]                      |
