char_length
This function returns the length of a string. For multi-byte characters, it returns the number of characters. It currently only supports utf8 coding. Note: This function is also named as character_length.
INT char_length(VARCHAR str)
MySQL > select char_length("abc");
| char_length('abc') |
| 3 |
keyword​
CHAR_LENGTH, CHARACTER_LENGTH
StarRocks Assistant
