array_join
Concatenates the elements of an array into a string.
array_join(array, sep[, null_replace_str])
Parametersβ
array: the array whose elements you want to concatenate. Only the ARRAY data type is supported. -
sep: the delimiter that is used to separate the concatenated array elements. Only the VARCHAR data type is supported. -
null_replace_str: the string that is used to substituteNULLvalues. Only the VARCHAR data type is supported.
Return valueβ
Returns a value of the VARCHAR data type.
Usage notesβ
The value of the
arrayparameter must be a one-dimensional array. -
The
arrayparameter does not support DECIMAL values. -
If you set the
sepparameter toNULL, the return value isNULL. -
If you do not specify the
null_replace_strparameter,NULLvalues are discarded. -
If you set the
null_replace_strparameter toNULL, the return value isNULL.
