Version: Stable-3.5
Manage replica
Manage data replicas in your StarRocks cluster.
This topic includes two sections - shared-nothing and shared-data.
Shared-nothing​
Overview​
For native tables in shared-nothing clusters, StarRocks adopts a multi-replica strategy to guarantee the high availability of data. When you create a table, you must specify the replica count of the table using the table property replication_num (Default value: 3). When a loading transaction starts, data is simultaneously loaded into the specified number of replicas. The transaction is returned with success only after the data is stored in the majority of replicas. For detailed information, see Write quorum. Nonetheless, StarRocks allows you to specify a lower write quorum for a table to achieve better loading performance.
StarRocks stores multiple replicas across different BE nodes. For example, if you want to store three replicas for a table, you must deploy at least three BE nodes in your StarRocks cluster. If any of the replicas fail, StarRocks clones a healthy replica, partially or wholly, from another BE node to repair the failed replica. By using the Multi-Version Concurrency Control (MVCC) technique, StarRocks accelerates the repairing of the replica by duplicating the physical copies of these multi-version data.
Loading data into a multi-replica table​
Replica-1
The routine of a loading transaction is as follows:
  1. The client submits a loading request to FE.
  2. FE chooses a BE node as the Coordinator BE node of this loading transaction, and generates an execution plan for the transaction.
  3. The Coordinator BE node reads the data to be loaded from the client.
  4. The Coordinator BE node dispatches the data to all the replicas of tablets.
    A tablet is a logical slice of a table. A table has multiple tablets, and each tablet has replication_num replicas. The number of tablets in a table is determined by the bucket_size property of the table.
  5. After the data is loaded and stored in all the tablets, FE makes the loaded data visible.
  6. FE returns loading success to the client.
Such a routine guarantees service availability even under extreme scenarios.
Write quorum​
Loading data into a multi-replica table can be very time-consuming. If you want to improve the loading performance and you can tolerate relatively lower data availability, you can set a lower write quorum for tables. A write quorum refers to the minimum number of replicas that need to acknowledge a write operation before it is considered successful. You can specify write quorum by adding the property write_quorum when you CREATE TABLE, or add this property to an existing table using ALTER TABLE. This property is supported from v2.5.
write_quorum supports the following values:
  • MAJORITY: Default value. When the majority of data replicas return loading success, StarRocks returns loading task success. Otherwise, StarRocks returns loading task failed.
  • ONE: When one of the data replicas returns loading success, StarRocks returns loading task success. Otherwise, StarRocks returns loading task failed.
  • ALL: When all of the data replicas return loading success, StarRocks returns loading task success. Otherwise, StarRocks returns loading task failed.
Automatic replica repair​
Replicas can fail because certain BE nodes crash or some loading tasks fail. StarRocks automatically repairs these failed replicas.
Every tablet_sched_checker_interval_seconds, default 20 seconds, Tablet Checker in FE scans all tablet replicas of all tables in your StarRocks cluster, and judges if a replica is healthy by checking the version number of the currently visible data and the health status of the BE node. If the visible version of a replica lags behind those of the other replicas, StarRocks performs an incremental clone to repair the failed replica. If a BE node fails to receive heartbeats or is dropped from the cluster, or the replica is too lagged to be repaired by an incremental clone, StarRocks performs a full clone to repair the lost replica.
After detecting tablet replicas that need repair, FE generates a tablet scheduling task, and adds the task to the scheduling task queue. Tablet Scheduler in the FE receives the scheduling task from the queue, creates clone tasks for each failed replica in accordance with the clone type they need, and assigns the tasks to the executor BE nodes.
A clone task is essentially copying data from a source BE node (which has a healthy replica), and loading the data into the destination BE node (which has a failed replica). For a replica with a lagged data version, FE assigns an incremental clone task to the BE executor that stores the failed replica, and informs the executor BE node from which peer BE node it can find a healthy replica and clone the new data. If a replica is lost, FE chooses a surviving BE node as the executor BE node, creates an empty replica in the BE node, and assigns a full clone task to the BE node.
For each clone task, regardless of its type, the executor BE node duplicates the physical data files from a healthy replica, and then updates its metadata accordingly. After the clone task is completed, the executor BE node reports task success to Tablet Scheduler in FE. After removing the redundant tablet replicas, FE updates its metadata, marking the completion of the replica repair.
Replica-2
During tablet repair, StarRocks can still execute queries. StarRocks can load data into the table as long as the number of healthy replicas satisfies write_quorum.
Repair replica manually​
The manual replica repair consists of two steps:
  1. Check the replica status.
  2. Set the replica priority level.
Check replica status​
Follow these steps to check the replica status of tablets to identify the unhealthy (failed) tablets.
  1. Check the status of all tablets in the cluster.
    SHOW PROC '/statistic';
    Example:
    • UnhealthyTabletNum: indicates the number of unhealthy tablets in the corresponding database.
    • InconsistentTabletNum: indicates the number of tablets whose replicas are inconsistent.
    If the value of UnhealthyTabletNum or InconsistentTabletNum is not 0 in a specific database, you can check the unhealthy tablets in the database with its DbId.
    SHOW PROC '/statistic/<DbId>'
    Example:
    | [40467980] | [] |
    The ID of the unhealthy tablet is returned in the field UnhealthyTablets.
  2. Check the tablet status in a specific table or partition.
    You can use the WHERE clause in ADMIN SHOW REPLICA STATUS to filter the tablets with a certain STATUS.
    Example:
    If the field IsBad is true, this tablet is corrupted.
    For detailed information provided in the field Status, see ADMIN SHOW REPLICA STATUS.
    You can further explore the details of tablets in the table using SHOW TABLET.
    SHOW TABLET FROM <table_name>
    Example:
    mysql> SHOW TABLET FROM tbl1;
    The returned results show the size, row count, version, and URL of the tablets.
    The field State returned by SHOW TABLET indicates the task state of the tablet, including CLONE, SCHEMA_CHANGE, and ROLLUP.
    You can also check the replica distribution of a specific table or partition to see if these replicas are distributed evenly using ADMIN SHOW REPLICA DISTRIBUTION.
    Example:
    | 10000 | 7 | | 7.29 % |
    | 10001 | 9 | | 9.38 % |
    | 10002 | 7 | | 7.29 % |
    | 10003 | 7 | | 7.29 % |
    | 10004 | 9 | | 9.38 % |
    | 10005 | 11 | > | 11.46 % |
    | 10006 | 18 | > | 18.75 % |
    | 10007 | 15 | > | 15.62 % |
    | 10008 | 13 | > | 13.54 % |
    The returned results show the number of tablet replicas on each BE node, and their corresponding percentages.
  3. Check the replica status of a specific tablet.
    With the TabletId of the unhealthy tablets you obtained in the preceding procedures, you can examine the replica statues of them.
    SHOW TABLET <TabletId>
    Example:
    mysql> SHOW TABLET 29502553;
    The returned results show detailed information about the database, table, partition, and index (Rollup) of the tablet.
    You can copy the SQL statement in the field DetailCmd to further examine the replica status of the tablet.
    Example:
    The returned results show all the replicas of the tablet.
Set replica priority level​
Tablet Scheduler automatically assigns a different priority level to each different type of clone task.
If you want the tablets from a certain table or certain partitions to be repaired at the earliest opportunity, you can manually assign a VERY_HIGH priority level to them using ADMIN REPAIR TABLE.
  • Executing this SQL statement only submits a hint to modify the priority level of the tablets to be repaired. It does not guarantee that these tablets can be successfully repaired.
  • Tablet Scheduler might still assign different priority levels to these tablets after you execute this SQL statement.
  • When the Leader FE node is changed or restarted, the hint this SQL statement submitted expires.
You can cancel this operation using ADMIN CANCEL REPAIR TABLE.
Replica balancing​
StarRocks automatically balances the tablets across BE nodes.
To move a tablet from a high-load node to a low-load node, StarRocks first creates a replica of the tablet in the low-load node, and then drops the corresponding replica on the high-load node. If different types of storage mediums are used in the cluster, StarRocks categorizes all the BE nodes in accordance with the storage medium types. StarRocks moves the tablet across the BE nodes of the same storage medium type whenever possible. Replicas of the same tablet are stored on different BE nodes.
BE load​
StarRocks shows the load statistics of each BE node in the cluster using ClusterLoadStatistics (CLS). Tablet Scheduler triggers the replica balancing based on ClusterLoadStatistics. StarRocks evaluates the disk utilization and the replica count of each BE node and calculates a loadScore accordingly. The higher the loadScore of a BE node, the higher the load the node has. Tablet Scheduler updates ClusterLoadStatistics every one minute.
capacityCoefficient and replicaNumCoefficientare the weighting factors for the disk utilization and the replica count respectively. The sum of capacityCoefficient and replicaNumCoefficient is one. capacityCoefficient is dynamically adjusted according to the actual disk usage. When the overall disk utilization of a BE node is below 50%, the capacityCoefficient value is 0.5. When the disk utilization is above 75%, the value is 1. You can configure this limit via the FE configuration item capacity_used_percent_high_water. If the utilization is between 50% and 75%, capacityCoefficient increases smoothly based on this formula:
capacityCoefficient ensures that when the disk usage is exceedingly high, the loadScore of this BE node gets higher, forcing the system to reduce the load on this BE node at the earliest opportunity.
Balancing policy​
Each time Tablet Scheduler schedules tablets, it selects a certain number of healthy tablets as the candidate tablets to be balanced through Load Balancer. Next time when scheduling tablets, Tablet Scheduler balances these healthy tablets.
View System Balance Status​
You can view the current overall balance status of the system and the details of different balance types.
  • View the current overall balance status of the system:
    SHOW PROC '/cluster_balance/balance_stat';
    Example:
    | StorageMedium | BalanceType | Balanced | PendingTablets | RunningTablets |
    | HDD | inter-node disk usage | true | 0 | 0 |
    | HDD | inter-node tablet distribution | true | 0 | 0 |
    | HDD | intra-node disk usage | true | 0 | 0 |
    | HDD | intra-node tablet distribution | true | 0 | 0 |
    | HDD | colocation group | true | 0 | 0 |
    | HDD | label-aware location | true | 0 | 0 |
    • StorageMedium: Storage medium.
    • BalanceType: Type of balance.
    • Balanced: Whether the balanced state is achieved.
    • PendingTablets: Number of tablets with task status Pending.
    • RunningTablets: Number of tablets with task status Running.
  • View the balance of disk utilization by node:
    SHOW PROC '/cluster_balance/cluster_load_stat';
    Example:
    | StorageMedium | ClusterDiskBalanceStat |
    | HDD | {"balanced":false,"maxBeId":1,"minBeId":2,"maxUsedPercent":0.9,"minUsedPercent":0.1,"type":"INTER_NODE_DISK_USAGE"} |
    | SSD | {"balanced":true} |
    • ClusterDiskBalanceStat: Balance status across nodes based on disk usage. If not balanced, displays the maximum and minimum disk utilization and the corresponding BEs.
  • View the balance of disk usage within node:
    SHOW PROC '/cluster_balance/cluster_load_stat/HDD';
    Example:
    | BeId | Cluster | Available | UsedCapacity | Capacity | UsedPercent | ReplicaNum | CapCoeff | ReplCoeff | Score | Class | BackendDiskBalanceStat |
    | 10004 | default_cluster | true | 651509602 | 243695955810 | 0.267 | 339 | 0.5 | 0.5 | 1.0 | MID | {"maxUsedPercent":0.9,"minUsedPercent":0.1,"beId":1,"maxPath":"/disk1","minPath":"/disk2","type":"INTRA_NODE_DISK_USAGE","balanced":false} |
    | 10005 | default_cluster | true | 651509602 | 243695955810 | 0.267 | 339 | 0.5 | 0.5 | 1.0 | MID | {"balanced":true} |
    • BeId: ID of the BE node.
    • BackendDiskBalanceStat: Balance status between disks within the node based on disk utilization. If not balanced, displays the maximum and minimum disk usage and the corresponding disk paths.
  • View balanced distribution by tablet:
    SHOW PROC '/dbs/ssb/lineorder/partitions/lineorder';
    Example:
    | IndexId | IndexName | State | LastConsistencyCheckTime | TabletBalanceStat |
    | 11129 | lineorder | NORMAL | NULL | {"maxTabletNum":23,"minTabletNum":21,"maxBeId":10012,"minBeId":10013,"type":"INTER_NODE_TABLET_DISTRIBUTION","balanced":false} |
    | 11230 | lineorder | NORMAL | NULL | {"maxTabletNum":23,"minTabletNum":21,"beId":10012,"maxPath":"/disk1","minPath":"/disk2","type":"INTRA_NODE_TABLET_DISTRIBUTION","balanced":false} |
    | 10432 | lineorder | NORMAL | NULL | {"tabletId":10435,"currentBes":[10002,10004],"expectedBes":[10003,10004],"type":"COLOCATION_GROUP","balanced":false} |
    | 10436 | lineorder | NORMAL | NULL | {"tabletId":10438,"currentBes":[10005,10006],"expectedLocations":{"rack":["rack1","rack2"]},"type":"LABEL_AWARE_LOCATION","balanced":false} |
    • IndexId: ID of the Materialized Index within the partition.
    • TabletBalanceStat: Balance status of tablet distribution between nodes or within nodes. If not balanced, displays the details of the imbalance, including Colocation Group, Label-aware Location.
  • View partitions with imbalanced tablet distribution:
    SELECT DB_NAME, TABLE_NAME, PARTITION_NAME, TABLET_BALANCED FROM information_schema.partitions_meta WHERE TABLET_BALANCED = 0;
    Example:
    | DB_NAME | TABLE_NAME | PARTITION_NAME | TABLET_BALANCED |
    | ssb | lineorder | lineorder | 0 |
    • TABLET_BALANCED: whether the tablet distribution is balanced.
Check tablet scheduling tasks​
You can check tablet scheduling tasks that are pending, running, and finished.
  • Check pending tablet scheduling tasks
    Example:
    • TabletId: the ID of the tablet pending to be scheduled. A scheduled task is only for one tablet.
    • Type: the task type. Valid values: REPAIR and BALANCE.
    • Status: the current status of the tablet, such as REPLICA_MISSING.
    • State: the state of the scheduling task. Valid values: PENDING, RUNNING, FINISHED, CANCELLED, TIMEOUT, and UNEXPECTED.
    • OrigPrio: the original priority of the task.
    • DynmPrio: the current priority of the task after the dynamic adjustment.
    • SrcBe: the ID of the source BE node.
    • SrcPath: the hash value of the path to the source BE node.
    • DestBe: the ID of the destination BE node.
    • DestPath: the hash value of the path to the destination BE node.
    • Timeout: the timeout of the task when the task is scheduled successfully. Unit: second.
    • Create: the time when the task was created.
    • LstSched: the time when the task was scheduled most recently.
    • LstVisit: the time when the task was visited most recently. To visit the task here means to schedule the task or to report its execution.
    • Finished: the time when the task is finished.
    • Rate: the rate at which the data is cloned.
    • FailedSched: the number of task scheduling failures.
    • FailedRunning: the number of task execution failures.
    • LstAdjPrio: the time when the task priority was adjusted most recently.
    • CmtVer, CmtVerHash, VisibleVer, and VisibleVerHash: the version information used to execute the clone task.
    • ErrMsg: the error message that occurs when the task is scheduled and running.
  • Check running tablet scheduling tasks
    The returned results are identical to those of the pending tasks.
  • Check finished tablet scheduling tasks
    The returned results are identical to those of the pending tasks. If the State of the task is FINISHED, the task is completed successfully. If not, please check the ErrMsg field for the cause of the task failure.
Resource control​
Because StarRocks repairs and balances tablets by cloning tablets from one BE node to another, the I/O load of a BE node can increase dramatically if the node executes such tasks too frequently in a short time. To avoid this situation, StarRocks sets a concurrency limit on clone tasks for each BE node. The minimum unit of resource control is a disk, which is a data storage path (storage_root_path) you have specified in the BE configuration file. By default, StarRocks allocates two slots for each disk to process tablet repair tasks. A clone task occupies one slot on the source BE node and one on the destination BE node. If all the slots on a BE node are occupied, StarRocks stops scheduling tasks to the node. You can increase the number of slots on a BE node by increasing the value of the FE dynamic parameter tablet_sched_slot_num_per_path.
StarRocks allocates two slots specifically for tablet balancing tasks to avoid the situation that a high-load BE node fails to release the disk space by balancing tablets because tablet repair tasks constantly occupy the slots.
Shared-data​
From v4.1 onwards, StarRocks supports repairing the data replica of cloud-native tables in shared-data clusters.
Overview​
In a shared-data architecture, data is stored in single-replica mode on remote storage systems such as object storage or HDFS in order to reduce storage costs. Unlike traditional shared-nothing architectures, this design cannot rely on multiple replicas to automatically recover data when files are lost.
As a result, if the effective metadata version maintained by FE references metadata or data files that no longer exist in remote storage, data ingestion and query operations will fail with "File not found" errors, potentially rendering the service unavailable.
Such file loss may occur under the following circumstances:
  • Accidental deletion: Object storage files are mistakenly removed due to operational errors.
  • Consistency issues: In extreme cases, the storage system experiences delayed consistency or metadata loss.
  • Software defects: System bugs cause files to be cleaned up prematurely.
Traditional snapshot-based restore mechanisms are often time-consuming and costly, making them unsuitable for fast recovery in production environments.
To address this issue, StarRocks provides a low-cost, second-level recovery mechanism. By scanning historical metadata versions, the system identifies the most recent healthy version in which all required files are present, and rolls back the Tablet metadata to that version. This approach sacrifices a small amount of recent data in exchange for rapid restoration of table availability.
Mechanism​
This feature is an extension of the ADMIN REPAIR TABLE statement for cloud-native tables in shared-data clusters.
It operates through the following mechanisms:
  1. Automated Detection
    The FE coordinates Compute Nodes (CNs) to probe historical Tablet metadata versions in reverse chronological order and in batches.
  2. Deterministic Path Derivation
    Metadata file paths are derived deterministically, allowing direct probing without performing expensive and inefficient object storage List Objects operations.
  3. Multi-Strategy Recovery Decisions
    Two recovery strategies are supportedβ€”Strict Consistency and Maximum Availabilityβ€”to accommodate different business requirements.
  4. Metadata Reset Capability
    When metadata is completely unavailable, the system can create empty Tablets (Empty Tablet Recovery) to prevent a small number of corrupted Tablets from blocking the availability of the entire table.
Key Benefits​
  • Ultra-fast recovery
    Only metadata (KB/MB scale) is modified. No data movement is required, enabling second-level recovery even for PB-scale tables.
  • Low operational cost
    No additional replicas or expensive object storage API calls are needed.
Check Tablet Status​
Before executing a repair, you can use the ADMIN SHOW TABLET STATUS statement to check the file integrity of each Tablet in a cloud-native table or cloud-native materialized view, and identify whether metadata or data files are missing.
Only cloud-native tables and cloud-native materialized views in shared-data clusters support this statement.
ADMIN SHOW TABLET STATUS FROM [<db_name>.]<table_name>
[PARTITION (<partition_name> [, <partition_name>, ...])]
[WHERE STATUS [=|!=] {'NORMAL'|'MISSING_META'|'MISSING_DATA'}]
[PROPERTIES ("max_missing_data_files_to_show" = "<num>")]
Tablet status values:
StatusDescription
NORMALMetadata and data files are all intact.
MISSING_METAMetadata file is missing.
MISSING_DATAData file(s) are missing.
Return columns:
ColumnDescription
TabletIdTablet ID.
PartitionIdPhysical partition ID of the partition the Tablet belongs to.
VersionCurrent visible version of the Tablet.
StatusTablet status. See status values above.
MissingDataFileCountNumber of missing data files. Populated when Status is MISSING_DATA.
MissingDataFilesList of missing data file paths. Limited by max_missing_data_files_to_show (default: 5). Populated when Status is MISSING_DATA.
Example: Check abnormal tablets in a partition​
ADMIN SHOW TABLET STATUS FROM my_cloud_table PARTITION (p20250101)
WHERE STATUS != "NORMAL";
Usage​
Use the ADMIN REPAIR TABLE statement with PROPERTIES to control recovery behavior.
[PARTITION (<partition_name>, ...)]
'enforce_consistent_version' = 'true',
'allow_empty_tablet_recovery' = 'false'
Properties
PropertyTypeDefaultDescription
enforce_consistent_versionBooleanTrueWhether to enforce all tablets in a partition to roll back to a consistent version. If this item is set to true, the system will search for a consistent version in the history that is valid for all tablets to perform the rollback, ensuring data version alignment across the partition. If it is set to false, each tablet in the partition is allowed to rollback to its latest available valid version. The versions of different tablets may be inconsistent, but this maximizes data preservation.
allow_empty_tablet_recoveryBooleanFalseWhether to allow recovery by creating empty tablets. This item takes effect only when enforce_consistent_version is false. If this item is set to true, when metadata is missing for all versions of some tablets but valid metadata exists for at least one tablet, the system attempts to create empty tablets to fill the missing versions. If metadata for all versions of all tablets is lost, recovery is impossible.
dry_runBooleanFalseWhether to return the repair plan without actually executing the repair. If set to true, the system evaluates the recoverability of each partition and returns the repair plan without performing any actual metadata rollback. Useful for previewing the repair effect before execution. See Preview the Repair Plan (Dry Run).
Restore all Tablets in partition p20250101 to the most recent uniform and complete version.
ADMIN REPAIR TABLE my_cloud_table PARTITION (p20250101);
Example 2: Maximum Availability Recovery​
Restore each Tablet in partition p20250101 to its own most recent valid version, allowing version divergence.
'enforce_consistent_version' = 'false'
Example 3: Allow Empty Tablet Recovery​
Allow Tablets with completely missing metadata to be recovered as empty Tablets.
'enforce_consistent_version' = 'false',
'allow_empty_tablet_recovery' = 'true'
Preview the Repair Plan (Dry Run)​
Before executing the repair, you can use dry_run mode to preview the repair plan. This lets you check the recoverability of each partition and the version each tablet would roll back to, without actually modifying any metadata.
dry_run mode is only supported for cloud-native tables in shared-data clusters.
'dry_run' = 'true'
Return Columns​
ColumnDescription
PartitionIdPartition ID.
VisibleVersionCurrent visible version.
RepairStatusRepair status: NORMAL (all tablets healthy, no repair needed), RECOVERABLE (missing files but recoverable), UNRECOVERABLE (missing files and unrecoverable), UNKNOWN (exception during probing).
TabletRecoverInfoJSON array listing the version each tablet will roll back to. Only populated when RepairStatus is RECOVERABLE.
ErrorMsgError message. Only populated when RepairStatus is UNRECOVERABLE or UNKNOWN.
Example: Preview the repair plan for partition p1​
ADMIN REPAIR TABLE my_cloud_table PARTITION (p1) PROPERTIES ("dry_run" = "true");
Example output:
| PartitionId | VisibleVersion | RepairStatus | TabletRecoverInfo | ErrorMsg|
| 10001 | 100 | RECOVERABLE | [{"tabletId":20001,"version":98},{"tabletId":20002,"version":98}] | |
| 10002 | 100 | NORMAL | [] | |
After confirming the repair plan, remove dry_run (or set it to false) to execute the actual repair.
Limitations and Recommendations​
  • Repairing replicas is supported for shared-data clusters from v3.5 onwards.
  • Currently, setting PROPERTIES is applicable only to shared-data tables.
  • Take the following points into consideration when performing materialized view recovery:
    • Asynchronous materialized views require a manual refresh after recovery.
    • Synchronous materialized views must use Strict Consistency Recovery to ensure consistency between base tables and rollup data.
  • Recovery is best-effort. A small amount of data loss is expected, depending on the available historical versions and the selected recovery strategy.
