Version: 3.2
Troubleshooting asynchronous materialized views
This topic describes how to examine your asynchronous materialized views and solve the problems you have encountered while working with them.
CAUTION
Some of the features shown below are only supported from StarRocks v3.1 onwards.
Examine an asynchronous materialized view
To get a whole picture of asynchronous materialized views that you are working with, you can first check their working state, refresh history, and resource consumption.
Check the working state of an asynchronous materialized view
You can check the working state of an asynchronous materialized view using SHOW MATERIALIZED VIEWS. Among all the information returned, you can focus on the following fields:
  • is_active: Whether the state of the materialized view is active. Only an active materialized view can be used for query acceleration and rewrite.
  • last_refresh_state: The state of the last refresh, including PENDING, RUNNING, FAILED, and SUCCESS.
  • last_refresh_error_message: The reason why the last refresh failed (if the materialized view state is not active).
  • rows: The number of data rows in the materialized view. Please note that this value can be different from the actual row count of the materialized view because the updates can be deferred.
For detailed information on other fields returned, see SHOW MATERIALIZED VIEWS - Returns.
Example:
id | 112517
database_name | ssb_1g
name | mv_pred_2
refresh_type | ASYNC
is_active | true
inactive_reason | <null>
task_id | 457930
task_name | mv-112517
last_refresh_duration | 3.996
last_refresh_state | SUCCESS
last_refresh_end_partition |
last_refresh_error_code | 0
last_refresh_error_message |
rows | 0
REFRESH ASYNC
"storage_medium" = "HDD"
FROM `ssb_1g`.`lineorder`
GROUP BY 1, 2;
1 row in set
Time: 0.003s
View the refresh history of an asynchronous materialized view
You can view the refresh history of an asynchronous materialized view by querying the table task_runs in the database information_schema. Among all the information returned, you can focus on the following fields:
  • CREATE_TIME and FINISH_TIME: The start and end time of the refresh task.
  • STATE: The state of the refresh task, including PENDING, RUNNING, FAILED, and SUCCESS.
  • ERROR_MESSAGE: The reason why the refresh task failed.
Example:
TASK_NAME | mv-112517
STATE | SUCCESS
DATABASE | ssb_1g
ERROR_CODE | 0
ERROR_MESSAGE | <null>
PROGRESS | 100%
STATE | SUCCESS
DATABASE | ssb_1g
ERROR_CODE | 0
PROGRESS | 100%
PROPERTIES | {"FORCE":"true"}
Monitor the resource consumption of an asynchronous materialized view
You can monitor and analyze the resource consumed by an asynchronous materialized view during and after the refresh.
Monitor resource consumption during refresh
During a refresh task, you can monitor its real-time resource consumption using SHOW PROC '/current_queries'.
  • ScanBytes: The size of data that is scanned.
  • ScanRows: The number of data rows that are scanned.
  • MemoryUsage: The size of memory that is used.
  • CPUTime: CPU time cost.
  • ExecTime: The execution time of the query.
Example:
ConnectionId | 0
Database | ssb_1g
User | root
ScanBytes | 70.981 MB
ScanRows | 6001215 rows
MemoryUsage | 73.748 MB
DiskSpillSize | 0.000
CPUTime | 2.515 s
ExecTime | 2.583 s
Analyze resource consumption after refresh
After a refresh task, you can analyze its resource consumption via query profiles.
While an asynchronous materialized view refreshes itself, an INSERT OVERWRITE statement is executed. You can check the corresponding query profile to analyze the time and resources consumed by the refresh task.
Among all the information returned, you can focus on the following metrics:
  • Total: Total time consumed by the query.
  • QueryCpuCost: Total CPU time cost of the query. CPU time costs are aggregated for concurrent processes. As a result, the value of this metric may be greater than the actual execution time of the query.
  • QueryMemCost: Total memory cost of the query.
  • Other metrics for individual operators, such as join operators and aggregate operators.
For detailed information on how to check the query profile and understand other metrics, see Analyze query profile.
Verify whether queries are rewritten by an asynchronous materialized view
You can check whether a query can be rewritten with an asynchronous materialized view from its query plan using EXPLAIN.
If the metric SCAN in the query plan shows the name of the corresponding materialized view, the query has been rewritten by the materialized view.
Example 1:
Materialized View | mv_agg
DISTRIBUTED BY RANDOM
REFRESH ASYNC
FROM `ssb_1g`.`customer`
-> FROM `ssb_1g`.`customer`
| Explain String |
| - Output => [1:c_custkey] |
If you disable the query rewrite feature, StarRocks adopts the regular query plan.
Example 2:
| Explain String |
Diagnose and solve problems
Here we list some common problems you might encounter while working with an asynchronous materialized view, and the corresponding solutions.
Materialized view building failure
If you failed to create an asynchronous materialized view, that is, the CREATE MATERIALIZED VIEW statement cannot be executed, you can look into the following aspects:
  • Check whether you have mistakenly used the SQL statement for synchronous materialized views.
    StarRocks provides two different materialized views: the synchronous materialized view and the asynchronous materialized view.
    The basic SQL statement used to create a synchronous materialized view is as follows:
    AS <query>
    However, the SQL statement used to create an asynchronous materialized view contains more parameters:
    REFRESH ASYNC -- The refresh strategy of the asynchronous materialized view.
    DISTRIBUTED BY HASH(<column>) -- The data distribution strategy of the asynchronous materialized view.
    AS <query>
    In addition to the SQL statement, the main difference between the two materialized views is that asynchronous materialized views support all query syntax that StarRocks provides, but synchronous materialized views only support limited choices of aggregate functions.
  • Check whether you have specified a correct partition column.
    When creating an asynchronous materialized view, you can specify a partitioning strategy, which allows you to refresh the materialized view on a finer granularity level.
    Currently, StarRocks only supports range partitioning, and only supports referencing a single column from the SELECT expression in the query statement that is used to build the materialized view. You can use the date_trunc() function to truncate the column to change the granularity level of the partitioning strategy. Please note that any other expressions are not supported.
  • Check whether you have the necessary privileges to create the materialized view.
    When creating an asynchronous materialized view, you need the SELECT privileges of all objects (tables, views, materialized views) that are queried. When UDFs are used in the query, you also need the USAGE privileges of the functions.
Materialized view refresh failure
If the materialized view fails to refresh, that is, the state of the refresh task is not SUCCESS, you can look into the following aspects:
  • Check whether you have adopted an inappropriate refresh strategy.
    By default, the materialized view refreshes immediately after it is created. However, in v2.5 and early versions, materialized views that adopt the MANUAL refresh strategy do not refresh after being created. You must refresh it manually using REFRESH MATERIALIZED VIEW.
  • Check whether the refresh task exceeds the memory limit.
    Usually, when an asynchronous materialized view involves large-scale aggregation or join calculations that exhaust the memory resources. To solve this problem, you can:
    • Specify a partitioning strategy for the materialized view to refresh one partition each time.
    • Enable the Spill to Disk feature for the refresh task. From v3.1 onwards, StarRocks supports spilling the intermediate results to disks when refreshing a materialized view. Execute the following statement to enable Spill to Disk:
    -- Define the properties when creating the materialized view.
    CREATE MATERIALIZED VIEW mv1
    REFRESH ASYNC
    AS <query>;
    -- Add the properties to an existing materialized view.
Materialized view refresh timeout
Large materialized views may fail to refresh because the refresh task exceeds the timeout period. You can consider the following solutions to solve this problem:
  • Specify a partitioning strategy for the materialized view to achieve fine-grained refresh
    As described in Create partitioned materialized views, by partitioning the materialized view you can achieve incremental building and refresh, thus avoiding the issue of excessive resource consumption during the initial refresh.
  • Set a longer timeout period
    The default timeout for materialized view refresh tasks is 5 minutes in versions earlier than v3.2 and 1 hour in v3.2 and later. If you encounter timeout exceptions, you can adjust the timeout period by using the following statement:
    ALTER MATERIALIZED VIEW mv2 SET ('session.query_timeout' = '4000');
  • Analyze performance bottlenecks of the materialized view refresh
    Refreshing materialized views with complex computation is time-consuming. You can analyze its performance bottlenecks by analyzing the query profile of the refresh task:
    • Obtain the query_id corresponding to the refresh task by querying information_schema.task_runs.
    • Analyze the query profile of the refresh task using the following statements:
      • GET_QUERY_PROFILE: Retrive the original query profile based on query_id.
      • ANALYZE PROFILE: Analyze the query profile on a per-fragment basis, and display it in a tree structure.
Materialized view state is not active
If the materialized view cannot rewrite queries or refresh, and the state of the materialized view is_active is false, it could be a result of the schema change on the base tables. To solve this problem, you can manually set the materialized view state to active by executing the following statement:
If setting the materialized view state to active does not take effect, you need to drop the materialized view and create it again.
Materialized view refresh task uses excessive resources
If you find that the refresh tasks are using excessive system resources, you can look into the following aspects:
  • Check whether you have created a materialized view too large.
    If you have joined too many tables that cause a significant amount of calculation, the refresh task will occupy many resources. To solve this problem, you need to assess the size of the materialized view and re-plan it.
  • Check whether you have set an unnecessarily frequent refresh interval.
    If you adopt the fixed-interval refresh strategy, you can set a lower refresh frequency to solve the problem. If the refresh tasks are triggered by data changes in the base tables, loading data too frequently can also cause this problem. To solve this problem, you need to define a proper refresh strategy for your materialized view.
  • Check whether the materialized view is partitioned.
    An unpartitioned materialized view can be costly to refresh because StarRocks refreshes the whole materialized view each time. To solve this problem, you need to specify a partitioning strategy for the materialized view to refresh one partition each time.
To stop a refresh task that occupies too many resources, you can:
  • Set the materialized view state to inactive so that all of its refresh tasks are stopped:
  • Terminate the running refresh task using CANCEL REFRESH MATERIALIZED VIEW:
Materialized view query rewrite failure
If your materialized view fails to rewrite relevant queries, you can look into the following aspects:
  • Diagnose rewrite failure using TRACE
    StarRocks provides the TRACE statement for you to diagnose materialized view rewrite failure:
    • TRACE LOGS MV <query>: Available in v3.2 and later, this command analyzes the detailed rewrite process and the reasons of the failure.
    • TRACE REASON MV <query>: Available in v3.2.8 and later, this command provides concise reasons for rewrite failure.
    MySQL > TRACE REASON MV SELECT sum(c1) FROM `glue_ice`.`iceberg_test`.`ice_test3`;
    | Explain String |
  • Check whether the materialized view and the query match.
    • StarRocks matches the materialized view and the query with a structure-based matching technique rather than text-based matching. Therefore, it's not guaranteed that a query can be rewritten just because it appears similar to that of a materialized view.
    • Materialized views can only rewrite SPJG (Select/Projection/Join/Aggregation) type of queries. Queries involving window functions, nested aggregation, or join plus aggregation are not supported.
    • Materialized views cannot rewrite queries that involve complex Join predicates in Outer Joins. For example, in cases like A LEFT JOIN B ON A.dt > '2023-01-01' AND A.id = B.id, we recommend you specify the predicate from the JOIN ON clause in a WHERE clause.
    For more information on the limitations of the materialized view query rewrite, see Query rewrite with materialized views - Limitations.
  • Check whether the materialized view state is active.
    StarRocks checks the status of the materialized view before rewriting queries. Queries can be rewritten only when the materialized view state is active. To solve this problem, you can manually set the materialized view state to active by executing the following statement:
  • Check whether the materialized view meets the data consistency requirements.
    StarRocks checks the consistency of data in the materialized view and in the base table data. By default, queries can be rewritten only when the data in the materialized view is up-to-date. To solve this problem, you can:
    • Add PROPERTIES('query_rewrite_consistency'='LOOSE') to the materialized view to disable consistency checks.
    • Add PROPERTIES('mv_rewrite_staleness_second'='5') to tolerate a certain degree of data inconsistency. Queries can be rewritten if the last refresh is before this time interval, regardless of whether the data in the base tables changes.
  • Check whether the query statement of the materialized view lacks output columns.
    To rewrite range and point queries, you must specify the columns used as the filtering predicates in the SELECT expression of the materialized view's query statement. You need to check the SELECT statement of the materialized view to ensure it includes columns referenced in the WHERE and ORDER BY clauses of the query.
Example 1: The materialized view mv1 uses nested aggregation. Thus, it cannot be used to rewrite queries.
select count(distinct cnt)
from (
select c_city, count(*) cnt
from customer
group by c_city
) t;
Example 2: The materialized view mv2 uses join plus aggregation. Thus, it cannot be used to rewrite queries. To solve this problem, you can create a materialized view with aggregation, and then a nested materialized view with join based on the previous one.
select *
from (
from lineorder
) lo
join (
select c_custkey
from customer
group by c_custkey
) cust
Example 3: The materialized view mv3 cannot rewrite queries in the pattern of SELECT c_city, sum(tax) FROM tbl WHERE dt='2023-01-01' AND c_city = 'xxx' because the column that the predicate referenced is not in the SELECT expression.
To solve this problem, you can create the materialized view as follows:
