📄️ Load data using Spark connector (recommended)
StarRocks provides a self-developed connector named StarRocks Connector for Apache Spark™ (Spark connector for short) to help you load data into a StarRocks table by using Spark. The basic principle is to accumulate the data and then load it all at a time into StarRocks through STREAM LOAD. The Spark connector is implemented based on Spark DataSource V2. A DataSource can be created by using Spark DataFrames or Spark SQL. And both batch and structured streaming modes are supported.
📄️ Load data in bulk using Spark Load
This load uses external Apache Spark™ resources to pre-process imported data, which improves import performance and saves compute resources. It is mainly used for initial migration and large data import into StarRocks (data volume up to TB level).
