Version: 2.5
Gather statistics for CBO
This topic describes the basic concept of StarRocks CBO and how to collect statistics for the CBO. StarRocks 2.4 introduces histograms to gather accurate data distribution statistics.
What is CBO​
Cost-based optimizer (CBO) is critical to query optimization. After an SQL query arrives at StarRocks, it is parsed into a logical execution plan. The CBO rewrites and transforms the logical plan into multiple physical execution plans. The CBO then estimates the execution cost of each operator in the plan (such as CPU, memory, network, and I/O) and chooses a query path with the lowest cost as the final physical plan.
Types of statistical information​
Basic statistics​
  • row_count: total number of rows in a table
  • data_size: data size of a column
  • ndv: column cardinality, which is the number of distinct values in a column
  • null_count: the amount of data with NULL values in a column
  • min: minimum value in a column
  • max: maximum value in a column
Basic statistics are stored in the _statistics_.table_statistic_v1 table. You can view this table in the _statistics_ database of your StarRocks cluster.
Histogram​
Currently, StarRocks supports only manual collection of histograms. Histograms are stored in the histogram_statistics table of the _statistics_ database.
Collection types and methods​
StarRocks supports full and sampled collection, both can be performed automatically and manually. By default, StarRocks automatically collects full statistics of a table. It checks for any data updates every 5 minutes. If data change is detected, data collection will be automatically triggered. If you do not want to use automatic full collection, you can set the FE configuration item enable_collect_full_statistic to false and customize a collection task.
Collection typeCollection methodDescriptionAdvantage and disadvantage
Full collectionAutomatic/manualScans the full table to gather statistics.Statistics are collected partition. If a partition has no data change, data will not be collected from this partition, reducing resource consumption.Full statistics are stored in the _statistics_.column_statistics table.Advantage: The statistics are accurate, which helps the CBO make accurate estimation.Disadvantage: It consumes system resources and is slow. From 2.5 onwards, StarRocks allows you to specify an automatic collection period, which reduces resource consumption.
Sampled collectionAutomatic/manualEvenly extracts N rows of data from each partition of a table.Statistics are collected by table. Basic statistics of each column are stored as one record. Cardinality information (ndv) of a column is estimated based on the sampled data, which is not accurate. Sampled statistics are stored in the _statistics_.table_statistic_v1 table.Advantage: It consumes less system resources and is fast.Disadvantage: The statistics are not complete, which may affect the accuracy of cost estimation.
Collect statistics​
Automatic collection​
For basic statistics, StarRocks automatically collects full statistics of a table by default, without requiring manual operations. For tables on which no statistics have been collected, StarRocks automatically collects statistics within the scheduling period. For tables on which statistics have been collected, StarRocks updates the total number of rows and modified rows in the tables, and persists this information regularly for judging whether to trigger automatic collection.
From 2.5 onwards, StarRocks allows you to specify a collection period for automatic full collection, which prevents cluster performance jitter caused by automatic full collection. This period is specified by FE parameters statistic_auto_analyze_start_time and statistic_auto_analyze_end_time.
  • Table data has changed since previous statistics collection.
  • The collection time falls within the range of the configured collection period. (The default collection period is all day.)
  • The update time of the previous collecting job is earlier than the latest update time of partitions.
  • The health of table statistics is below the specified threshold (statistic_auto_collect_ratio).
If the number of partitions with data updated is less than 10, the formula is 1 - (Number of updated rows since previous collection/Total number of rows). If the number of partitions with data updated is greater than or equal to 10, the formula is 1 - MIN(Number of updated rows since previous collection/Total number of rows, Number of updated partitions since previous collection/Total number of partitions).
  • For tables with small data volume, **statistics are collected in real time with no restrictions, even though the table data is frequently updated. The statistic_auto_collect_small_table_size parameter can be used to determine whether a table is a small table or a large table. You can also use statistic_auto_collect_small_table_interval to configure collection intervals for small tables.
  • For tables with large data volume, the following restrictions apply:
    • The default collection interval is not less than 12 hours, which can be configured using statistic_auto_collect_large_table_interval.
    • When the collection interval is met and the statistics health is lower than the threshold for automatic sampled collection (statistic_auto_collect_sample_threshold), sampled collection is triggered.
    • When the collection interval is met and the statistics health is higher than the threshold for automatic sampled collection (statistic_auto_collect_sample_threshold) and lower than the automatic collection threshold (statistic_auto_collect_ratio), full collection is triggered.
    • When the size of the largest partition to collect data (statistic_max_full_collect_data_size) is greater than 100 GB, sampled collection is triggered.
    • Only statistics of partitions whose update time is later than the time of the previous collection task are collected. Statistics of partitions with no data change are not collected.
tip
FE configuration itemTypeDefault valueDescription
enable_statistic_collectBOOLEANTRUEWhether to collect statistics. This switch is turned on by default.
enable_collect_full_statisticBOOLEANTRUEWhether to enable automatic full collection. This switch is turned on by default.
statistic_collect_interval_secLONG300The interval for checking data updates during automatic collection. Unit: seconds.
statistic_auto_collect_ratioFLOAT0.8The threshold for determining whether the statistics for automatic collection are healthy. If statistics health is below this threshold, automatic collection is triggered.
statistic_auto_analyze_start_timeSTRING00:00:00The start time of automatic collection. Value range: 00:00:00 - 23:59:59.
statistic_auto_analyze_end_timeSTRING23:59:59The end time of automatic collection. Value range: 00:00:00 - 23:59:59.
statistic_auto_collect_small_table_sizeLONG5368709120The threshold for determining whether a table is a small table for automatic full collection. A table whose size is greater than this value is considered a large table, whereas a table whose size is less than or equal to this value is considered a small table. Unit: Byte. Default value: 5368709120 (5 GB).
statistic_auto_collect_small_table_intervalLONG0The interval for automatically collecting full statistics of small tables. Unit: seconds.
statistic_auto_collect_large_table_intervalLONG43200The interval for automatically collecting full statistics of large tables. Unit: seconds. Default value: 43200 (12 hours).
statistic_auto_collect_sample_thresholdDOUBLE0.3The statistics health threshold for triggering automatic sampled collection. If the health value of statistics is lower than this threshold, automatic sampled collection is triggered.
statistic_max_full_collect_data_sizeLONG107374182400The size of the largest partition for automatic collection to collect data. Unit: Byte. Default value: 107374182400 (100 GB). If a partition exceeds this value, full collection is discarded and sampled collection is performed instead.
statistic_full_collect_bufferLONG20971520The maximum buffer size taken by automatic collection tasks. Unit: Byte. Default value: 20971520 (20 MB).
statistic_collect_max_row_count_per_queryINT5000000000The maximum number of rows to query for a single analyze task. An analyze task will be split into multiple queries if this value is exceeded.
statistic_collect_too_many_version_sleepLONG600000The sleep time of automatic collection tasks if the table on which the collection task runs has too many data versions. Unit: ms. Default value: 600000 (10 minutes).
Manual collection​
You can use ANALYZE TABLE to create a manual collection task. By default, manual collection is a synchronous operation. You can also set it to an asynchronous operation. In asynchronous mode, after you run ANALYZE TABLE, the system immediately returns whether this statement is successful. However, the collection task will be running in the background and you do not have to wait for the result. You can check the status of the task by running SHOW ANALYZE STATUS. Asynchronous collection is suitable for tables with large data volume, whereas synchronous collection is suitable for tables with small data volume. Manual collection tasks are run only once after creation. You do not need to delete manual collection tasks.
Manually collect basic statistics​
[WITH SYNC | ASYNC MODE]
PROPERTIES (property [,property]);
Parameter description:
  • Collection type
    • FULL: indicates full collection.
    • SAMPLE: indicates sampled collection.
    • If no collection type is specified, full collection is used by default.
  • col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected.
  • [WITH SYNC | ASYNC MODE]: whether to run the manual collection task in synchronous or asynchronous mode. Synchronous collection is used by default if you do not specify this parameter.
  • PROPERTIES: custom parameters. If PROPERTIES is not specified, the default settings in the fe.conf file are used. The properties that are actually used can be viewed via the Properties column in the output of SHOW ANALYZE STATUS.
PROPERTIESTypeDefault valueDescription
statistic_sample_collect_rowsINT200000The minimum number of rows to collect for sampled collection.If the parameter value exceeds the actual number of rows in your table, full collection is performed.
Manual full collection
ANALYZE TABLE tbl_name;
ANALYZE FULL TABLE tbl_name;
Manual sampled collection
Manually collect histograms​
[WITH N BUCKETS]
  • col_name: columns from which to collect statistics. Separate multiple columns with commas (,). If this parameter is not specified, the entire table is collected. This parameter is required for histograms.
  • [WITH SYNC | ASYNC MODE]: whether to run the manual collection task in synchronous or asynchronous mode. Synchronous collection is used by default if you not specify this parameter.
  • WITH N BUCKETS: N is the number of buckets for histogram collection. If not specified, the default value in fe.conf is used.
  • PROPERTIES: custom parameters. If PROPERTIES is not specified, the default settings in fe.conf are used.
statistic_sample_collect_rowsINT200000The minimum number of rows to collect. If the parameter value exceeds the actual number of rows in your table, full collection is performed.
histogram_buckets_sizeLONG64The default bucket number for a histogram.
histogram_mcv_sizeINT100The number of most common values (MCV) for a histogram.
histogram_sample_ratioFLOAT0.1The sampling ratio for a histogram.
histogram_max_sample_row_countLONG10000000The maximum number of rows to collect for a histogram.
PROPERTIES(
"histogram_mcv_size" = "32",
Custom collection​
Customize an automatic collection task​
You can use the CREATE ANALYZE statement to customize an automatic collection task.
Before creating a custom automatic collection task, you must disable automatic full collection (enable_collect_full_statistic = false). Otherwise, custom tasks cannot take effect.
CREATE ANALYZE [FULL|SAMPLE] ALL PROPERTIES (property [,property]);
  • Collection type
statistic_auto_collect_ratioFLOAT0.8The threshold for determining whether the statistics for automatic collection are healthy. If the statistics health is below this threshold, automatic collection is triggered.
statistics_max_full_collect_data_sizeINT100The size of the largest partition for automatic collection to collect data. Unit: GB.If a partition exceeds this value, full collection is discarded and sampled collection is performed instead.
statistic_sample_collect_rowsINT200000The minimum number of rows to collect.If the parameter value exceeds the actual number of rows in your table, full collection is performed.
statistic_exclude_patternStringnullThe name of the database or table that needs to be excluded in the job. You can specify the database and table that do not collect statistics in the job. Note that this is a regular expression pattern, and the match content is database.table.
CREATE ANALYZE ALL;
Automatic sampled collection
View custom collection tasks​
ColumnDescription
IdThe ID of the collection task.
DatabaseThe database name.
TableThe table name.
ColumnsThe column names.
TypeThe type of statistics, including FULL and SAMPLE.
ScheduleThe type of scheduling. The type is SCHEDULE for an automatic task.
PropertiesCustom parameters.
StatusThe task status, including PENDING, RUNNING, SUCCESS, and FAILED.
LastWorkTimeThe time of the last collection.
ReasonThe reason why the task failed. NULL is returned if task execution was successful.
SHOW ANALYZE JOB
Delete a custom collection task​
DROP ANALYZE <ID>;
DROP ANALYZE 266030;
View status of collection tasks​
You can use LILE or WHERE to filter the information to return.
List nameDescription
TypeThe type of statistics, including FULL, SAMPLE, and HISTOGRAM.
ScheduleThe type of scheduling. ONCE means manual and SCHEDULE means automatic.
StatusThe status of the task.
StartTimeThe time when the task starts executing.
EndTimeThe time when the task execution ends.
ReasonThe reason why the task failed. NULL is returned if the execution was successful.
View statistics​
View metadata of basic statistics​
SHOW STATS META [WHERE];
ColumnDescription
TypeThe type of statistics. FULL means full collection and SAMPLE means sampled collection.
UpdateTimeThe latest statistics update time for the current table.
HealthyThe health of statistical information.
View metadata of histograms​
SHOW HISTOGRAM META [WHERE];
ColumnDescription
ColumnThe columns.
TypeType of statistics. The value is HISTOGRAM for histograms.
Delete statistics​
Delete basic statistics​
DROP STATS tbl_name
Delete histograms​
ANALYZE TABLE tbl_name DROP HISTOGRAM ON col_name [, col_name];
Cancel a collection task​
KILL ANALYZE <ID>;
FE configuration items​
enable_statistic_collectBOOLEANTRUEWhether to collect statistics. This parameter is turned on by default.
enable_collect_full_statisticBOOLEANTRUEWhether to enable automatic full statistics collection. This parameter is turned on by default.
statistic_max_full_collect_data_sizeLONG107374182400The size of the largest partition for automatic collection to collect data. Unit: Byte. If a partition exceeds this value, full collection is discarded and sampled collection is performed instead.
statistic_sample_collect_rowsLONG200000The minimum number of rows to collect for sampled collection. If the parameter value exceeds the actual number of rows in your table, full collection is performed.
statistic_collect_concurrencyINT3The maximum number of manual collection tasks that can run in parallel. The value defaults to 3, which means you can run a maximum of three manual collections tasks in parallel. If the value is exceeded, incoming tasks will be in the PENDING state, waiting to be scheduled.
histogram_mcv_sizeLONG100The number of most common values (MCV) for a histogram.
statistic_manager_sleep_time_secLONG60The interval at which metadata is scheduled. Unit: seconds. The system performs the following operations based on this interval:Create tables for storing statistics.Delete statistics that have been deleted.Delete expired statistics.
statistic_analyze_status_keep_secondLONG259200The duration to retain the history of collection tasks. The default value is 3 days. Unit: seconds.
References​
