Version: Latest-3.3
[Preview] Flat JSON
This topic introduces the basic concepts of the Flat JSON feature and how to use this feature.
Since v2.2.0, StarRocks supports storing JSON data, which allows for more flexible data storage. However, in most query scenarios, users access only the JSON data in the specified path, instead of complete JSON data. The following example stores mandatory fields as fixed fields and packages fields that frequently change with business as JSON data.
time,
event,
user,
FROM logs;
However, during queries, the performance of JSON data is not as good as standard data types such as INT and STRING due to the following reasons:
  • JSON is a semi-structured data type for which the structure of each row of data must be stored. This occupies a lot of storage and has low compression efficiency.
  • When querying JSON data, the data structure must be detected based on runtime data, which makes it difficult to achieve vectorized optimization.
  • When querying JSON data, the complete JSON data must be read, including a large number of redundant fields.
StarRocks introduces the Flat JSON feature in v3.3 to optimize the query performance of JSON data and reduce the cost of using JSON.
What is Flat JSON?
The core principle of Flat JSON is to detect JSON data during data loading and extract common fields from the JSON data as standard data types for storage. During querying, these common fields can be directly queried to accelerate the query speed of JSON. Example data:
2, {"a": 2, "b": 22, "d": 4}
6, {"c": 6, "d": 1}
The a and b fields exist in most rows and their data types are similar (both INT). Therefore, the data of the a and b fields can be read from the JSON data and stored separately as two INT columns. If a query is destined for these two columns, the data can be directly read without the need to read other columns, reducing the processing overhead of JSON structure during computation.
Usage notes
  • Shared-nothing clusters support Flat JSON from v3.3.0 onwards. Shared-data clusters support Flat JSON from v3.3.3 onwards.
  • All table types in StarRocks support Flat JSON.
  • Flat JSON is compatible with historical JSON data. Historical data that have been loaded before will not be overwritten after Flat JSON is enabled. It will coexist with the flattened JSON data.
  • When new data is written, the Flat JSON operation is automatically completed through Compaction.
In v3.3.0, v3.3.1, and v3.3.2:
  • During data loading, Flat JSON supports extracting common fields and storing them as a JSON type, but type inference is not supported.
  • Both the extracted columns and the original JSON data will be stored. The extracted data is removed when the original data is deleted.
From v3.3.3 onwards
  • The results extracted from Flat JSON are divided into common fields and reserved fields. When all JSON schemas are consistent, no reserved field will be generated.
  • During data loading, common fields will be automatically inferred as BIGINT/LARGEINT/DOUBLE/STRING types. Unrecognized types will be inferred as a JSON type. Reserved fields will be stored as a JSON type.
  • Flat JSON only stores common fields and reserved fields, and does not store the original JSON data.
How to use Flat JSON
  • To use Flat JSON, you need to enable the BE dynamic parameter enable_json_flat (Default: false). Once enabled, newly loaded JSON data will be automatically flattened.
    curl -XPOST http://<be_host>:<be_http_port>/api/update_config?enable_json_flat=true
  • Before querying JSON data, enable the session variable cbo_prune_json_subfield (Default: false).
    SET cbo_prune_json_subfield = true;
Verify whether Flat JSON takes effect
  • After loading the data, you can run the following SQL command to query the sub-fields extracted from the corresponding field.
    SELECT flat_json_meta(json_column), count(1)
    FROM tableA[_META];
  • During data query, you can view related metrics through the Query Profile:
    • PushdownAccessPaths: the number of paths to which the sub-fields are pushed down.
    • AccessPathHits: the number of Flat JSON hits, whose sub-metrics print the hit JSON data.
    • AccessPathUnhits: the number of Flat JSON misses, whose sub-metrics print the missed JSON data.
    • JsonFlattern: the time used to extract JSON sub-fields when there are Flat JSON misses.
Usage example
  1. Turn on enable_json_flat.
  2. Create a table containing JSON columns. This example uses INSERT INTO to load JSON data into the table.
    CREATE TABLE `t1` (
    `k1` int,
    `k2` JSON,
    `k3` VARCHAR(20),
    `k4` JSON
    DUPLICATE KEY(`k1`)
    INSERT INTO t1 (k1,k2) VALUES
    (20,parse_json('{"str":"test_str6","Integer":444,"Double":3.14,"Object":{"a":"b"},"arr":[1,2,3],"Bool":true,"null":null}'));
  3. Query sub-fields extracted from k2.
    SELECT flat_json_meta(k2) FROM t1[_META_];
    | flat_json_meta(k2) |
  4. Enable the session variable cbo_prune_json_subfield.
  5. Enable the Query Profile feature.
    SET enable_profile = true;
  6. Run data queries.
    SELECT * FROM t1;
    SELECT get_json_string(k2,'\$.Bool') FROM t1 WHERE k2->'arr' = '[10,20,30]';
  7. Obtain the ID of the most recent query.
    SELECT last_query_id();
    | last_query_id() |
    | a5d0d795-037c-11ef-93ca-00163e13a1ba |
  8. View the Query Profile to check metrics related to Flat JSON.
    You can view the profile of this query using either of the following methods:
    1. Get the profile using the get_query_profile function.
       SELECT get_query_profile('a5d0d795-037c-11ef-93ca-00163e13a1ba')\G
    2. View the metrics of the profile through the web page.
    The complete profile is long and the following figure shows only Flat JSON-related metrics.
    flat_json_profile
Other optional BE configurations
Cautions
  • Enabling Flat JSON will increase the time consumption of JSON data loading. The more JSON sub-fields are extracted, the longer the time consumption.
  • The system variable cbo_prune_json_subfield only works when Flat JSON is hit. Otherwise, there may be negative performance gains.
