SHOW TABLET
SHOW TABLET displays tablet related information.
For v3.0 and later, this operation requires the SYSTEM-level OPERATE privilege and TABLE-level SELECT privilege. For v2.5 and earlier, this operation requires the ADMIN_PRIV privilege.
Query information of tablets in a table or a partition​
SHOW TABLET
FROM [<db_name>.]<table_name>
[PARTITION(<partition_name>, ...)]
WHERE [version = <version_number>]
[[AND] backendid = <backend_id>]
[[AND] STATE = "NORMAL"|"ALTER"|"CLONE"|"DECOMMISSION"]
[ORDER BY <field_name> [ASC | DESC]]
[LIMIT [<offset>,]<limit>]
ParameterRequiredDescription
db_nameNoThe database name. If you do not specify this parameter, the current database is used by default.
table_nameYesThe name of the table from which you want to query tablet information. You must specify this parameter. Otherwise, an error is returned.
partition_nameNoThe name of the partition from which you want to query tablet information.
version_numberNoThe data version number.
backend_idNoThe ID of the BE where the replica of the tablet is located.
STATENoThe status of tablet replicas.
  • NORMAL: The replica is normal.
  • ALTER: A Rollup or schema change is being performed on the replica.
  • CLONE: The replica is being cloned. (Replicas in this state are not available for use).
  • DECOMMISSION: The replica is being decommissioned.
field_nameNoThe field by which the results are sorted. All the fields returned by SHOW TABLET FROM <table_name> are sortable.
  • If you want to display results in ascending order, use ORDER BY field_name ASC.
  • If you want to display results in descending order, use ORDER BY field_name DESC.
offsetNoThe number of tablets to skip from the results. For example, OFFSET 5 means to skip the first five tablets. Default value: 0.
limitNoThe number of tablets to return. For example, LIMIT 10 means to return only 10 tablets. If this parameter is not specified, all the tablets that meet the filter conditions are returned.
Query information of a single tablet​
After obtaining all tablet IDs using SHOW TABLET FROM <table_name>, you can query the information of a single tablet.
SHOW TABLET <tablet_id>
tablet_idYesTablet ID
Description of return fields​
-- In shared-nothing cluster
| TabletId | ReplicaId | BackendId | SchemaHash | Version | VersionHash | LstSuccessVersion | LstSuccessVersionHash | LstFailedVersion | LstFailedVersionHash | LstFailedTime | DataSize | RowCount | State | LstConsistencyCheckTime | CheckVersion | CheckVersionHash | VersionCount | PathHash | MetaUrl | CompactionStatus | DiskRootPath |
-- In shared-data cluster
| TabletId | BackendId | DataSize | RowCount | MinVersion |
FieldDescription
TabletIdTable ID.
ReplicaIdReplica ID.
BackendIdThe ID of the BE where the replica is located.
SchemaHashSchema hash (randomly generated).
VersionData version number.
VersionHashHash of data version number.
LstSuccessVersionThe last successfully loaded version.
LstSuccessVersionHashThe hash of the last successfully loaded version.
LstFailedVersionThe version of the last failed loading. -1 indicates no version failed to be loaded.
LstFailedVersionHashThe hash of the last failed version.
LstFailedTimeThe time of the last failed loading. NULL indicates there is no load failure.
DataSizeData size of the tablet.
RowCountThe number of data rows of the tablet.
StateReplica status of the tablet.
LstConsistencyCheckTimeThe time of the last consistency check. NULL indicates no consistency check was performed.
CheckVersionThe data version on which consistency check was performed. -1 indicates no version was checked.
CheckVersionHashThe hash of the version on which consistency check was performed.
VersionCountThe total number of data versions.
PathHashThe hash of the directory in which the tablet is stored.
MetaUrlThe URL used to query more meta information.
CompactionStatusThe URL used to query data version compaction status.
DiskRootPathThe disk where the replica is located.
MinVersionThe minimum data version retained for the tablet. For shared-data clusters only.
Query information of a specific tablet​
FieldDescription
DbNameThe name of the database to which the tablet belongs.
TableNameThe name of the table to which the tablet belongs.
PartitionNameThe name of the partition to which the tablet belongs.
IndexNameThe index name.
DbIdThe database ID.
TableIdThe table ID.
PartitionIdThe partition ID.
IndexIdThe index ID.
IsSyncWhether data on the tablet is consistent with table meta. true indicates data is consistent and the tablet is normal. false indicates data is missing on the tablet.
DetailCmdThe URL used to query more information.
Create table test_show_tablet in the database example_db.
CREATE TABLE `test_show_tablet` (
`k1` date NULL COMMENT "",
`k2` datetime NULL COMMENT "",
`k3` char(20) NULL COMMENT "",
`k4` varchar(20) NULL COMMENT "",
`k5` boolean NULL COMMENT "",
`k6` tinyint(4) NULL COMMENT "",
`k7` smallint(6) NULL COMMENT "",
`k8` int(11) NULL COMMENT "",
`k9` bigint(20) NULL COMMENT "",
`k10` largeint(40) NULL COMMENT "",
`k11` float NULL COMMENT "",
`k12` double NULL COMMENT "",
`k13` decimal128(27, 9) NULL COMMENT ""
DUPLICATE KEY(`k1`, `k2`, `k3`, `k4`, `k5`)
PARTITION BY RANGE(`k1`)
(PARTITION p20210101 VALUES [("2021-01-01"), ("2021-01-02")),
PARTITION p20210102 VALUES [("2021-01-02"), ("2021-01-03")),
PARTITION p20210103 VALUES [("2021-01-03"), ("2021-01-04")),
PARTITION p20210104 VALUES [("2021-01-04"), ("2021-01-05")),
PARTITION p20210105 VALUES [("2021-01-05"), ("2021-01-06")),
PARTITION p20210106 VALUES [("2021-01-06"), ("2021-01-07")),
PARTITION p20210107 VALUES [("2021-01-07"), ("2021-01-08")),
PARTITION p20210108 VALUES [("2021-01-08"), ("2021-01-09")),
PARTITION p20210109 VALUES [("2021-01-09"), ("2021-01-10")))
DISTRIBUTED BY HASH(`k1`, `k2`, `k3`);
  • Example 1: Query information of all the tablets in the specified table. The following example excerpts information of only one tablet from the return information.
        mysql> show tablet from example_db.test_show_tablet\G
    TabletId: 9588955
    ReplicaId: 9588956
    BackendId: 10004
    SchemaHash: 0
    Version: 1
    VersionHash: 0
    LstSuccessVersion: 1
    LstSuccessVersionHash: 0
    LstFailedVersion: -1
    LstFailedVersionHash: 0
    LstFailedTime: NULL
    DataSize: 0B
    RowCount: 0
    State: NORMAL
    LstConsistencyCheckTime: NULL
    CheckVersion: -1
    CheckVersionHash: 0
    VersionCount: 1
    PathHash: 0
    MetaUrl: http://172.26.92.141:8038/api/meta/header/9588955
    CompactionStatus: http://172.26.92.141:8038/api/compaction/show?tablet_id=9588955
    DiskRootPath: /storage/disk
  • Example 2: Query information of tablet 9588955.
        mysql> show tablet 9588955\G
    DbName: example_db
    TableName: test_show_tablet
    PartitionName: p20210103
    IndexName: test_show_tablet
    DbId: 11145
    TableId: 9588953
    PartitionId: 9588946
    IndexId: 9588954
    IsSync: true
    DetailCmd: SHOW PROC '/dbs/11145/9588953/partitions/9588946/9588954/9588955';
  • Example 3: Query information of tablets in partition p20210103.
    SHOW TABLET FROM test_show_tablet partition(p20210103);
  • Example 4: Return information of 10 tablets.
        SHOW TABLET FROM test_show_tablet limit 10;
  • Example 5: Return information of 10 tablets with an offset 5.
    SHOW TABLET FROM test_show_tablet limit 5,10;
  • Example 6: Filter tablets by backendid, version, and state.
    WHERE backendid = 10004 and version = 1 and state = "NORMAL";
  • Example 7: Sort tablets by version.
        SHOW TABLET FROM table_name where backendid = 10004 order by version;
  • Example 8: Return information of tablets whose index name is test_show_tablet.
    SHOW TABLET FROM test_show_tablet where indexname = "test_show_tablet";
