Version: Candidate-4.0
CREATE TABLE AS SELECT
Use the CREATE TABLE AS SELECT (CTAS) statement to synchronously or asynchronously query a table and create a new table based on the query result, and then insert the query result into the new table.
You can submit an asynchronous CTAS task using SUBMIT TASK.
  • Synchronously query a table and create a new table based on the query result, and then insert the query result into the new table.
    CREATE [TEMPORARY] TABLE [IF NOT EXISTS] [database.]table_name
    [column_name1 [, column_name2, ...]]
    [index_definition1 [, index_definition2, ...]]
    [key_desc]
    [COMMENT "table comment"]
    [partition_desc]
    [distribution_desc]
    [ORDER BY (column_name1 [, column_name2, ...])]
    AS SELECT query
  • Asynchronously query a table and create a new table based on the query result, and then insert the query result into the new table.
    SUBMIT [/*+ SET_VAR(key=value) */] TASK [[database.]<task_name>]AS
    [key_desc]
    [partition_desc]
    [distribution_desc]
    [PROPERTIES ("key"="value", ...)] AS SELECT query
ParameterRequiredDescription
TEMPORARYNoCreates a temporary table. From v3.3.1, StarRocks supports creating temporary tables in the Default Catalog. For more information, see Temporary Table. Currently, StarRocks does not support creating temporary tables with asynchronous tasks by using SUBMIT TASK.
column_nameNoThe name of a column in the new table. You do not need to specify the data type for the column. StarRocks automatically specifies an appropriate data type for the column. StarRocks converts FLOAT and DOUBLE data into DECIMAL(38,9) data. StarRocks also converts CHAR, VARCHAR, and STRING data into VARCHAR(65533) data.
index_definitionNoSince v3.1.8, a bitmap index can be created for the new table. The syntax is INDEX index_name (col_name[, col_name, ...]) [USING BITMAP] COMMENT 'xxxxxx'. For more information about parameter descriptions and usage notes, see Bitmap indexes.
key_descNoThe syntax is key_type ( <col_name1> [, <col_name2> , ...]).
Parameters:
  • key_type: the key type of the new table. Valid values: DUPLICATE KEY and PRIMARY KEY. Default value: DUPLICATE KEY.
  • col_name: the column to form the key.
COMMENTNoThe comment of the new table.
partition_descNoThe partitioning method of the new table. By default, if you do not specify this parameter, the new table has no partition. For more information about partitioning, see CREATE TABLE.
distribution_descNoThe bucketing method of the new table. If you do not specify this parameter, the bucket column defaults to the column with the highest cardinality collected by the cost-based optimizer (CBO). The number of buckets defaults to 10. If the CBO does not collect information about the cardinality, the bucket column defaults to the first column in the new table. For more information about bucketing, see CREATE TABLE.
ORDER BYNoSince v3.1.8, a sort key can be specified for the new table if the new table is a Primary Key table. The sort key can be a combination of any columns. A Primary Key table is a table for which PRIMARY KEY (xxx) is specified at table creation.
PropertiesNoThe properties of the new table.
AS SELECT queryYesThe query result. You can specify columns in ... AS SELECT query, for example, ... AS SELECT a, b, c FROM table_a;. In this example, a, b, and c indicates the column names of the table that is queried. If you do not specify the column names of the new table, the column names of the new table are also a, b, and c. You can specify expressions in ... AS SELECT query, for example, ... AS SELECT a+1 AS x, b+2 AS y, c*c AS z FROM table_a;. In this example, a+1, b+2, and c*c indicates the column names of the table that is queried, and x, y, and z indicates the column names of the new table. Note: The number of columns in the new table need to be the same as the number of the columns specified in the SELECT statement . We recommend that you use column names that are easy to identify.
Usage notes​
  • The CTAS statement can only create a new table that meets the following requirements:
    • ENGINE is OLAP.
    • The table is a Duplicate Key table by default. You can also specify it as a Primary Key table in key_desc.
    • The sort keys are the first three columns, and the storage space of the data types of these three columns does not exceed 36 bytes.
  • If the CTAS statement fails to execute due to reasons, such as an FE restart, one of the following issues may occur:
    • A new table is created successfully but does not contain data.
    • A new table fails to be created.
  • After a new table is created, if multiple methods (such as INSERT INTO) are used to insert data into the new table, the method that completes the INSERT operation first will insert its data into the new table.
  • After a new table is created, you need to manually grant permissions on this table to users.
  • If you do not specify a name for a Task when you asynchronously query a table and create a new table based on the query result, StarRocks automatically generates a name for the Task.
Example 1: Synchronously query a table order and create a new table order_new based on the query result, and then insert the query result into the new table.
CREATE TABLE order_new
AS SELECT * FROM order;
Example 2: Synchronously query the k1, k2, and k3 columns in the table order and create a new table order_new based on the query result, and then insert the query result into the new table. Additionally, set the column names of the new table to a, b, and c.
CREATE TABLE order_new (a, b, c)
AS SELECT k1, k2, k3 FROM order;
or
AS SELECT k1 AS a, k2 AS b, k3 AS c FROM order;
Example 3: Synchronously query the largest value of the salary column in the table employee and create a new table employee_new based on the query result, and then insert the query result into the new table. Additionally, set the column name of the new table to salary_max.
CREATE TABLE employee_new
AS SELECT MAX(salary) AS salary_max FROM employee;
After data is inserted, query the new table.
SELECT * FROM employee_new;
| salary_max |
| 10000 |
Example 4: Synchronously query the customer_id and first_name columns in the table customers and create a new table customers_new based on the query result, and then insert the query result into the new table. Additionally, set the column names of the new table to customer_id_new and first_name_new. Also, build a bitmap index for the column customer_id_new in the new table.
CREATE TABLE customers_new
( customer_id_new,
first_name_new,
INDEX idx_bitmap_customer_id (customer_id_new) USING BITMAP
AS SELECT customer_id,first_name FROM customers;
Example 5: Synchronously query a table customers and create a new table customers_new based on the query result, and then insert the query result into the new table. Additionally, specify the new table as a Primary Key table, and specify its sort key as first_name and last_name.
CREATE TABLE customers_pk
PRIMARY KEY (customer_id)
ORDER BY (first_name,last_name)
AS SELECT * FROM customers;
Example 6: Use CTAS to create a Primary Key table. Note that the number of data rows in the Primary Key table may be less than that in the query result. It is because the Primary Key table only stores the most recent data row among a group of rows that have the same primary key.
PRIMARY KEY(order_id)
AS SELECT
order_list.order_id,
sum(goods.price) as total
GROUP BY order_id;
Example 7: Synchronously query four tables, including lineorder, customer, supplier, and part and create a new table lineorder_flat based on the query result, and then insert the query result to the new table. Additionally, specify the partitioning method and bucketing method for the new table.
CREATE TABLE lineorder_flat
PARTITION BY RANGE(`LO_ORDERDATE`)
START ("1993-01-01") END ("1999-01-01") EVERY (INTERVAL 1 YEAR)
DISTRIBUTED BY HASH(`LO_ORDERKEY`) AS SELECT
l.LO_ORDERKEY AS LO_ORDERKEY,
l.LO_CUSTKEY AS LO_CUSTKEY,
l.LO_PARTKEY AS LO_PARTKEY,
l.LO_SUPPKEY AS LO_SUPPKEY,
l.LO_QUANTITY AS LO_QUANTITY,
l.LO_DISCOUNT AS LO_DISCOUNT,
l.LO_REVENUE AS LO_REVENUE,
l.LO_TAX AS LO_TAX,
l.LO_SHIPMODE AS LO_SHIPMODE,
c.C_NAME AS C_NAME,
c.C_ADDRESS AS C_ADDRESS,
c.C_CITY AS C_CITY,
c.C_NATION AS C_NATION,
c.C_REGION AS C_REGION,
c.C_PHONE AS C_PHONE,
s.S_NAME AS S_NAME,
s.S_ADDRESS AS S_ADDRESS,
s.S_CITY AS S_CITY,
s.S_NATION AS S_NATION,
s.S_REGION AS S_REGION,
s.S_PHONE AS S_PHONE,
p.P_NAME AS P_NAME,
p.P_MFGR AS P_MFGR,
p.P_CATEGORY AS P_CATEGORY,
p.P_BRAND AS P_BRAND,
p.P_COLOR AS P_COLOR,
p.P_TYPE AS P_TYPE,
p.P_SIZE AS P_SIZE,
Example 8: Asynchronously query the table order_detail and create a new table order_statistics based on the query result, and then insert the query result into the new table.
SUBMIT TASK AS CREATE TABLE order_statistics AS SELECT COUNT(*) as count FROM order_detail;
| TaskName | Status |
| ctas-df6f7930-e7c9-11ec-abac-bab8ee315bf2 | SUBMITTED |
Check information of the Task.
-- Information of the Task
TASK_NAME: ctas-df6f7930-e7c9-11ec-abac-bab8ee315bf2
CREATE_TIME: 2022-06-14 14:07:06
SCHEDULE: MANUAL
DATABASE: default_cluster:test
DEFINITION: CREATE TABLE order_statistics AS SELECT COUNT(*) as cnt FROM order_detail
EXPIRE_TIME: 2022-06-17 14:07:06
Check the state of the TaskRun.
SELECT * FROM INFORMATION_SCHEMA.task_runs;
-- State of the TaskRun
QUERY_ID: 37bd2b63-eba8-11ec-8d41-bab8ee315bf2
FINISH_TIME: 2022-06-14 14:07:07
STATE: SUCCESS
DATABASE:
ERROR_CODE: 0
ERROR_MESSAGE: NULL
Query the new table when the state of the TaskRun is SUCCESS.
SELECT * FROM order_statistics;
