CANCEL ALTER TABLE
CANCEL ALTER TABLE cancels the execution of the ongoing ALTER TABLE operation, including:
  • Modify columns.
  • Optimize table schema (from v3.2), including modifying the bucketing method and the number of buckets.
  • Create and delete the rollup index.
note
  • This statement is a synchronous operation.
  • This statement requires you to have the ALTER_PRIV privilege on the table.
  • This statement only supports canceling asynchronous operations using ALTER TABLE (as mentioned above) and does not support canceling synchronous operations using ALTER TABLE, such as rename.
CANCEL ALTER TABLE { COLUMN | OPTIMIZE | ROLLUP } FROM [db_name.]table_name [ (rollup_job_id [, rollup_job_id]) ]
  • {COLUMN | OPTIMIZE | ROLLUP}
    • If COLUMN is specified, this statement cancels operations of modifying columns.
    • If OPTIMIZE is specified, this statement cancels operations of optimizing table schema.
    • If ROLLUP is specified, this statement cancels operations of adding or deleting the rollup index. You can further specify rollup_job_id to cancel specific rollup jobs.
  • db_name: optional. The name of the database to which the table belongs. If this parameter is not specified, your current database is used by default.
  • table_name: required. The table name.
  • rollup_job_id: optional. The ID of the rollup job. You can get the rollup job ID using SHOW ALTER MATERIALIZED VIEW.
  1. Cancel the operation of modifying columns for example_table in the database example_db.
    CANCEL ALTER TABLE COLUMN FROM example_db.example_table;
  2. Cancel the operation of optimizing table schema for example_table in the database example_db.
    CANCEL ALTER TABLE OPTIMIZE FROM example_db.example_table;
  3. Cancel the operation of adding or deleting the rollup index for example_table in the current database.
    CANCEL ALTER TABLE ROLLUP FROM example_table;
  4. Cancel specific rollup alterations for example_table in the current database using their job IDs.
    CANCEL ALTER TABLE ROLLUP FROM example_table (12345, 12346);
