STREAM LOAD
StarRocks provides the loading method HTTP-based STREAM LOAD to help you load data from a local file system or a streaming data source. After you submit a load job, StarRocks synchronously runs the job, and returns the result of the job after the job finishes. You can determine whether the job is successful based on the job result. For information about the application scenarios, limits, principles, and supported data file formats of Stream Load, see Loading from a local file system via Stream Load.
tip
This example uses the Local Climatological Data(LCD) dataset featured in the StarRocks Basics Quick Start. You can load the data and try the example yourself.
Since v3.2.7, Stream Load supports compressing JSON data during transmission, reducing network bandwidth overhead. Users can specify different compression algorithms using parameters compression and Content-Encoding. Supported compression algorithms including GZIP, BZIP2, LZ4_FRAME, and ZSTD. For more information, see data_desc.
From v3.4.0, the system supports merging multiple Stream Load requests. For more information, see Merge Commit parameters.
NOTICE
  • After you load data into a StarRocks table by using Stream Load, the data of the materialized views that are created on that table is also updated.
  • You can load data into StarRocks tables only as a user who has the INSERT privilege on those StarRocks tables. If you do not have the INSERT privilege, follow the instructions provided in GRANT to grant the INSERT privilege to the user that you use to connect to your StarRocks cluster.
curl --location-trusted -u <username>:<password> -XPUT <url>
data_desc
[opt_properties]
This topic uses curl as an example to describe how to load data by using Stream Load. In addition to curl, you can also use other HTTP-compatible tools or languages to perform Stream Load. Load-related parameters are included in HTTP request header fields. When you input these parameters, take note of the following points:
  • You can use chunked transfer encoding, as demonstrated in this topic. If you do not choose chunked transfer encoding, you must input a Content-Length header field to indicate the length of content to be transferred, thereby ensuring data integrity.
    If you use curl to perform Stream Load, StarRocks automatically adds a Content-Length header field and you do not need manually input it.
  • You must add an Expect header field and specify its value as 100-continue, as in "Expect:100-continue". This helps prevent unnecessary data transfers and reduce resource overheads in case your job request is denied.
Note that in StarRocks some literals are used as reserved keywords by the SQL language. Do not directly use these keywords in SQL statements. If you want to use such a keyword in an SQL statement, enclose it in a pair of backticks (`). See Keywords.
username and password​
Specify the username and password of the account that you use to connect to your StarRocks cluster. This is a required parameter. If you use an account for which no password is set, you need to input only <username>:.
XPUT​
Specifies the HTTP request method. This is a required parameter. Stream Load supports only the PUT method.
url​
Specifies the URL of the StarRocks table. Syntax:
The following table describes the parameters in the URL.
ParameterRequiredDescription
fe_hostYesThe IP address of the FE node in your StarRocks cluster.
If you submit the load job to a specific BE or CN node, you must input the IP address of the BE or CN node.
fe_http_portYesThe HTTP port number of the FE node in your StarRocks cluster. The default port number is 8030.
If you submit the load job to a specific BE or CN node, you must input the HTTP port number of the BE or CN node. The default port number is 8030.
database_nameYesThe name of the database to which the StarRocks table belongs.
table_nameYesThe name of the StarRocks table.
You can use SHOW FRONTENDS to view the IP address and HTTP port of the FE node.
data_desc​
Describes the data file that you want to load. The data_desc descriptor can include the data file's name, format, column separator, row separator, destination partitions, and column mapping against the StarRocks table. Syntax:
-T <file_path>
-H "format: CSV | JSON"
-H "column_separator: <column_separator>"
-H "row_delimiter: <row_delimiter>"
-H "columns: <column1_name>[, <column2_name>, ... ]"
-H "partitions: <partition1_name>[, <partition2_name>, ...]"
-H "temporary_partitions: <temporary_partition1_name>[, <temporary_partition2_name>, ...]"
-H "jsonpaths: [ \"<json_path1>\"[, \"<json_path2>\", ...] ]"
-H "strip_outer_array: true | false"
-H "json_root: <json_path>"
-H "ignore_json_size: true | false"
-H "compression: <compression_algorithm> | Content-Encoding: <compression_algorithm>"
The parameters in the data_desc descriptor can be divided into three types: common parameters, CSV parameters, and JSON parameters.
Common parameters​
file_pathYesThe save path of the data file. You can optionally include the extension of the file name.
formatNoThe format of the data file. Valid values: CSV and JSON. Default value: CSV.
partitionsNoThe partitions into which you want to load the data file. By default, if you do not specify this parameter, StarRocks loads the data file into all partitions of the StarRocks table.
temporary_partitionsNoThe name of the temporary partition into which you want to load data file. You can specify multiple temporary partitions, which must be separated by commas (,).
columnsNoThe column mapping between the data file and the StarRocks table.
If the fields in the data file can be mapped in sequence onto the columns in the StarRocks table, you do not need to specify this parameter. Instead, you can use this parameter to implement data conversions. For example, if you load a CSV data file and the file consists of two columns that can be mapped in sequence onto the two columns, id and city, of the StarRocks table, you can specify "columns: city,tmp_id, id = tmp_id * 100". For more information, see the "Column mapping" section in this topic.
CSV parameters​
column_separatorNoThe characters that are used in the data file to separate fields. If you do not specify this parameter, this parameter defaults to \t, which indicates tab.
Make sure that the column separator you specify by using this parameter is the same as the column separator used in the data file.
- For CSV data, you can use a UTF-8 string, such as a comma (,), tab, or pipe (|), whose length does not exceed 50 bytes as a text delimiter.
- If the data file uses consecutive non-printable characters (for example, \r\n) as the column separator, you must set this parameter as \\x0D0A.
row_delimiterNoThe characters that are used in the data file to separate rows. If you do not specify this parameter, this parameter defaults to \n.
If the data file uses consecutive non-printable characters (for example, \r\n) as the row delimiter, you must set this parameter as \\x0D0A.
skip_headerNoSpecifies whether to skip the first few rows of the data file when the data file is in CSV format. Type: INTEGER. Default value: 0.
In some CSV-formatted data files, the first few rows at the beginning are used to define metadata such as column names and column data types. By setting the skip_header parameter, you can enable StarRocks to skip the first few rows of the data file during data loading. For example, if you set this parameter to 1, StarRocks skips the first row of the data file during data loading.
The first few rows at the beginning in the data file must be separated by using the row separator that you specify in the load command.
trim_spaceNoSpecifies whether to remove spaces preceding and following column separators from the data file when the data file is in CSV format. Type: BOOLEAN. Default value: false.
For some databases, spaces are added to column separators when you export data as a CSV-formatted data file. Such spaces are called leading spaces or trailing spaces depending on their locations. By setting the trim_space parameter, you can enable StarRocks to remove such unnecessary spaces during data loading.
Note that StarRocks does not remove the spaces (including leading spaces and trailing spaces) within a field wrapped in a pair of enclose-specified characters. For example, the following field values use pipe (|) as the column separator and double quotation marks (") as the enclose-specified character:
|"Love StarRocks"|
|" Love StarRocks "|
| "Love StarRocks" |
If you set trim_space to true, StarRocks processes the preceding field values as follows:
|"Love StarRocks"|
|" Love StarRocks "|
|"Love StarRocks"|
encloseNoSpecifies the character that is used to wrap the field values in the data file according to RFC4180 when the data file is in CSV format. Type: single-byte character. Default value: NONE. The most prevalent characters are single quotation mark (') and double quotation mark (").
All special characters (including row separators and column separators) wrapped by using the enclose-specified character are considered normal symbols. StarRocks can do more than RFC4180 as it allows you to specify any single-byte character as the enclose-specified character.
If a field value contains an enclose-specified character, you can use the same character to escape that enclose-specified character. For example, you set enclose to ", and a field value is a "quoted" c. In this case, you can enter the field value as "a ""quoted"" c" into the data file.
escapeNoSpecifies the character that is used to escape various special characters, such as row separators, column separators, escape characters, and enclose-specified characters, which are then considered by StarRocks to be common characters and are parsed as part of the field values in which they reside. Type: single-byte character. Default value: NONE. The most prevalent character is slash (\), which must be written as double slashes (\\) in SQL statements.
The character specified by escape is applied to both inside and outside of each pair of enclose-specified characters.
Two examples are as follows:
  • When you set enclose to " and escape to \, StarRocks parses "say \"Hello world\"" into say "Hello world".
  • Assume that the column separator is comma (,). When you set escape to \, StarRocks parses a, b\, c into two separate field values: a and b, c.
  • For CSV data, you can use a UTF-8 string, such as a comma (,), tab, or pipe (|), whose length does not exceed 50 bytes as a text delimiter.
  • Null values are denoted by using \N. For example, a data file consists of three columns, and a record from that data file holds data in the first and third columns but no data in the second column. In this situation, you need to use \N in the second column to denote a null value. This means the record must be compiled as a,\N,b instead of a,,b. a,,b denotes that the second column of the record holds an empty string.
  • The format options, including skip_header, trim_space, enclose, and escape, are supported in v3.0 and later.
JSON parameters​
jsonpathsNoThe names of the keys that you want to load from the JSON data file. You need to specify this parameter only when you load JSON data by using the matched mode. The value of this parameter is in JSON format. See Configure column mapping for JSON data loading.
strip_outer_arrayNoSpecifies whether to strip the outermost array structure. Valid values: true and false. Default value: false.
In real-world business scenarios, the JSON data may have an outermost array structure as indicated by a pair of square brackets []. In this situation, we recommend that you set this parameter to true, so StarRocks removes the outermost square brackets [] and loads each inner array as a separate data record. If you set this parameter to false, StarRocks parses the entire JSON data file into one array and loads the array as a single data record.
For example, the JSON data is [ {"category" : 1, "author" : 2}, {"category" : 3, "author" : 4} ]. If you set this parameter to true, {"category" : 1, "author" : 2} and {"category" : 3, "author" : 4} are parsed into separate data records that are loaded into separate StarRocks table rows.
json_rootNoThe root element of the JSON data that you want to load from the JSON data file. You need to specify this parameter only when you load JSON data by using the matched mode. The value of this parameter is a valid JsonPath string. By default, the value of this parameter is empty, indicating that all data of the JSON data file will be loaded. For more information, see the "Load JSON data using matched mode with root element specified" section of this topic.
ignore_json_sizeNoSpecifies whether to check the size of the JSON body in the HTTP request.
By default, the size of the JSON body in an HTTP request cannot exceed 100 MB. If the JSON body exceeds 100 MB in size, an error "The size of this batch exceed the max size [104857600] of json type data data [8617627793]. Set ignore_json_size to skip check, although it may lead huge memory consuming." is reported. To prevent this error, you can add "ignore_json_size:true" in the HTTP request header to instruct StarRocks not to check the JSON body size.
compression, Content-EncodingNOThe encoding algorithm that is applied to the data during transmission. Supported algorithms include GZIP, BZIP2, LZ4_FRAME, and ZSTD. Example: curl --location-trusted -u root: -v 'http://127.0.0.1:18030/api/db0/tbl_simple/_stream_load' \-X PUT -H "expect:100-continue" \-H 'format: json' -H 'compression: lz4_frame' -T ./b.json.lz4.
When you load JSON data, also note that the size per JSON object cannot exceed 4 GB. If an individual JSON object in the JSON data file exceeds 4 GB in size, an error "This parser can't support a document that big." is reported.
Merge Commit parameters​
Enables Merge Commit for multiple concurrent Stream Load requests within a specified time window and to merge them into a single transaction.
warning
Note that the Merge Commit optimization is suitable for the scenario with concurrent Stream Load jobs on a single table. It is not recommended if the concurrency is one. Meanwhile, think twice before setting merge_commit_async to false and merge_commit_interval_ms to a large value because they may cause load performance degradation.
enable_merge_commitNoWhether to enable the Merge Commit for the loading request. Valid values: true and false (Default).
merge_commit_asyncNoThe server's return mode. Valid values:
  • true: Enables asynchronous mode, where the server returns immediately after receiving the data. This mode does not ensure the loading is successful.
  • false(Default): Enables synchronous mode, where the server returns only after the merged transaction is committed, ensuring the loading is successful and visible.
merge_commit_interval_msYesThe size of the merging time window. Unit: milliseconds. Merge Commit attempts to merge loading requests received within this window into a single transaction. A larger window improves merging efficiency but increases latency.
merge_commit_parallelYesThe degree of parallelism for the loading plan created for each merging window. Parallelism can be adjusted based on the load of ingestion. Increase this value if there are many requests and/or a large amount of data to load. The parallelism is limited to the number of BE nodes, calculated as min(merge_commit_parallel, number of BE nodes).
note
  • Merge Commit only supports merging homogeneous loading requests into a single database and table. "Homogeneous" indicates that the Stream Load parameters are identical, including: common parameters, JSON format parameters, CSV format parameters, opt_properties, and Merge Commit parameters.
  • For loading CSV-formatted data, you must ensure that each row ends with a line separator. skip_header is not supported.
  • The server automatically generates labels for transactions. They will be ignored if specified.
  • Merge Commit merges multiple loading requests into a single transaction. If one request contains data quality issues, all requests in the transaction will fail.
opt_properties​
Specifies some optional parameters, which are applied to the entire load job. Syntax:
-H "label: <label_name>"
-H "where: <condition1>[, <condition2>, ...]"
-H "max_filter_ratio: <num>"
-H "timeout: <num>"
-H "strict_mode: true | false"
-H "timezone: <string>"
-H "load_mem_limit: <num>"
-H "partial_update: true | false"
-H "partial_update_mode: row | column"
-H "merge_condition: <column_name>"
The following table describes the optional parameters.
labelNoThe label of the load job. If you do not specify this parameter, StarRocks automatically generates a label for the load job.
StarRocks does not allow you to use one label to load a data batch multiple times. As such, StarRocks prevents the same data from being repeatedly loaded. For label naming conventions, see System limits.
By default, StarRocks retains the labels of load jobs that were successfully completed over the most recent three days. You can use the FE parameter label_keep_max_second to change the label retention period.
whereNoThe conditions based on which StarRocks filters the pre-processed data. StarRocks loads only the pre-processed data that meets the filter conditions specified in the WHERE clause.
max_filter_ratioNoThe maximum error tolerance of the load job. The error tolerance is the maximum percentage of data records that can be filtered out due to inadequate data quality in all data records requested by the load job. Valid values: 0 to 1. Default value: 0.
We recommend that you retain the default value 0. This way, if unqualified data records are detected, the load job fails, thereby ensuring data correctness.
If you want to ignore unqualified data records, you can set this parameter to a value greater than 0. This way, the load job can succeed even if the data file contains unqualified data records.
Unqualified data records do not include data records that are filtered out by the WHERE clause.
log_rejected_record_numNoSpecifies the maximum number of unqualified data rows that can be logged. This parameter is supported from v3.1 onwards. Valid values: 0, -1, and any non-zero positive integer. Default value: 0.
  • The value 0 specifies that data rows that are filtered out will not be logged.
  • The value -1 specifies that all data rows that are filtered out will be logged.
  • A non-zero positive integer such as n specifies that up to n data rows that are filtered out can be logged on each BE or CN.
timeoutNoThe timeout period of the load job. Valid values: 1 to 259200. Unit: second. Default value: 600.
NOTEIn addition to the timeout parameter, you can also use the FE parameter stream_load_default_timeout_second to centrally control the timeout period for all Stream Load jobs in your StarRocks cluster. If you specify the timeout parameter, the timeout period specified by the timeout parameter prevails. If you do not specify the timeout parameter, the timeout period specified by the stream_load_default_timeout_second parameter prevails.
strict_modeNoSpecifies whether to enable the strict mode. Valid values: true and false. Default value: false. The value true specifies to enable the strict mode, and the value false specifies to disable the strict mode.
timezoneNoThe time zone used by the load job. Default value: Asia/Shanghai. The value of this parameter affects the results returned by functions such as strftime, alignment_timestamp, and from_unixtime. The time zone specified by this parameter is a session-level time zone. For more information, see Configure a time zone.
load_mem_limitNoThe maximum amount of memory that can be provisioned to the load job. Unit: bytes. By default, the maximum memory size for a load job is 2 GB. The value of this parameter cannot exceed the maximum amount of memory that can be provisioned to each BE or CN.
partial_updateNoWhether to use partial updates. Valid values: TRUE and FALSE. Default value: FALSE, indicating to disable this feature.
partial_update_modeNoSpecifies the mode for partial updates. Valid values: row and column.
  • The value row (default) means partial updates in row mode, which is more suitable for real-time updates with many columns and small batches.
  • The value column means partial updates in column mode, which is more suitable for batch updates with few columns and many rows. In such scenarios, enabling the column mode offers faster update speeds. For example, in a table with 100 columns, if only 10 columns (10% of the total) are updated for all rows, the update speed of the column mode is 10 times faster.
merge_conditionNoSpecifies the name of the column you want to use as the condition to determine whether updates can take effect. The update from a source record to a destination record takes effect only when the source data record has a greater or equal value than the destination data record in the specified column. StarRocks supports conditional updates since v2.5.
The column that you specify cannot be a primary key column. Additionally, only tables that use the Primary Key table support conditional updates.
Column mapping​
Configure column mapping for CSV data loading​
If the columns of the data file can be mapped one on one in sequence to the columns of the StarRocks table, you do not need to configure the column mapping between the data file and the StarRocks table.
If the columns of the data file cannot be mapped one on one in sequence to the columns of the StarRocks table, you need to use the columns parameter to configure the column mapping between the data file and the StarRocks table. This includes the following two use cases:
  • Same number of columns but different column sequence. Also, the data from the data file does not need to be computed by functions before it is loaded into the matching StarRocks table columns.
    In the columns parameter, you need to specify the names of the StarRocks table columns in the same sequence as how the data file columns are arranged.
    For example, the StarRocks table consists of three columns, which are col1, col2, and col3 in sequence, and the data file also consists of three columns, which can be mapped to the StarRocks table columns col3, col2, and col1 in sequence. In this case, you need to specify "columns: col3, col2, col1".
  • Different number of columns and different column sequence. Also, the data from the data file needs to be computed by functions before it is loaded into the matching StarRocks table columns.
    In the columns parameter, you need to specify the names of the StarRocks table columns in the same sequence as how the data file columns are arranged and specify the functions you want to use to compute the data. Two examples are as follows:
    • The StarRocks table consists of three columns, which are col1, col2, and col3 in sequence. The data file consists of four columns, among which the first three columns can be mapped in sequence to the StarRocks table columns col1, col2, and col3 and the fourth column cannot be mapped to any of the StarRocks table columns. In this case, you need to temporarily specify a name for the fourth column of the data file, and the temporary name must be different from any of the StarRocks table column names. For example, you can specify "columns: col1, col2, col3, temp", in which the fourth column of the data file is temporarily named temp.
    • The StarRocks table consists of three columns, which are year, month, and day in sequence. The data file consists of only one column that accommodates date and time values in yyyy-mm-dd hh:mm:ss format. In this case, you can specify "columns: col, year = year(col), month=month(col), day=day(col)", in which col is the temporary name of the data file column and the functions year = year(col), month=month(col), and day=day(col) are used to extract data from the data file column col and loads the data into the mapping StarRocks table columns. For example, year = year(col) is used to extract the yyyy data from the data file column col and loads the data into the StarRocks table column year.
For detailed examples, see Configure column mapping.
Configure column mapping for JSON data loading​
If the keys of the JSON document have the same names as the columns of the StarRocks table, you can load the JSON-formatted data by using the simple mode. In simple mode, you do not need to specify the jsonpaths parameter. This mode requires that the JSON-formatted data must be an object as indicated by curly brackets {}, such as {"category": 1, "author": 2, "price": "3"}. In this example, category, author, and price are key names, and these keys can be mapped one on one by name to the columns category, author, and price of the StarRocks table.
If the keys of the JSON document have different names than the columns of the StarRocks table, you can load the JSON-formatted data by using the matched mode. In matched mode, you need to use the jsonpaths and COLUMNS parameters to specify the column mapping between the JSON document and the StarRocks table:
  • In the jsonpaths parameter, specify the JSON keys in the sequence as how they are arranged in the JSON document.
  • In the COLUMNS parameter, specify the mapping between the JSON keys and the StarRocks table columns:
    • The column names specified in the COLUMNS parameter are mapped one on one in sequence to the JSON keys.
    • The column names specified in the COLUMNS parameter are mapped one on one by name to the StarRocks table columns.
For examples about loading JSON-formatted data by using the matched mode, see Load JSON data using matched mode.
After the load job finishes, StarRocks returns the job result in JSON format. Example:
"TxnId": 1003,
"Label": "label123",
"Status": "Success",
"Message": "OK",
"NumberTotalRows": 1000000,
"NumberLoadedRows": 999999,
"NumberFilteredRows": 1,
"NumberUnselectedRows": 0,
"LoadBytes": 40888898,
"LoadTimeMs": 2144,
"BeginTxnTimeMs": 0,
"StreamLoadPlanTimeMs": 1,
"ReadDataTimeMs": 0,
"WriteDataTimeMs": 11,
"CommitAndPublishTimeMs": 16,
The following table describes the parameters in the returned job result.
ParameterDescription
TxnIdThe transaction ID of the load job.
LabelThe label of the load job.
StatusThe final status of the data loaded.
  • Success: The data is successfully loaded and can be queried.
  • Publish Timeout: The load job is successfully submitted, but the data still cannot be queried. You do not need to retry to load the data.
  • Label Already Exists: The label of the load job has been used for another load job. The data may have been successfully loaded or is being loaded.
  • Fail: The data failed to be loaded. You can retry the load job.
MessageThe status of the load job. If the load job fails, the detailed failure cause is returned.
NumberTotalRowsThe total number of data records that are read.
NumberLoadedRowsThe total number of data records that are successfully loaded. This parameter is valid only when the value returned for Status is Success.
NumberFilteredRowsThe number of data records that are filtered out due to inadequate data quality.
NumberUnselectedRowsThe number of data records that are filtered out by the WHERE clause.
LoadBytesThe amount of data that is loaded. Unit: bytes.
LoadTimeMsThe amount of time that is taken by the load job. Unit: ms.
BeginTxnTimeMsThe amount of time that is taken to run a transaction for the load job.
StreamLoadPlanTimeMsThe amount of time that is taken to generate a execution plan for the load job.
ReadDataTimeMsThe amount of time that is taken to read data for the load job.
WriteDataTimeMsThe amount of time that is taken to write data for the load job.
CommitAndPublishTimeMsThe amount of time that is taken to commit and publish data for the load job.
If the load job fails, StarRocks also returns ErrorURL. Example:
{"ErrorURL": "http://172.26.195.68:8045/api/_load_error_log?file=error_log_3a4eb8421f0878a6_9a54df29fd9206be"}
ErrorURL provides a URL from which you can obtain details about unqualified data records that have been filtered out. You can specify the maximum number of unqualified data rows that can be logged by using the optional parameter log_rejected_record_num, which is set when you submit a load job.
You can run curl "url" to directly view details about the filtered-out, unqualified data records. You can also run wget "url" to export the details about these data records:
wget http://172.26.195.68:8045/api/_load_error_log?file=error_log_3a4eb8421f0878a6_9a54df29fd9206be
The exported data record details are saved to a local file with a name similar to _load_error_log?file=error_log_3a4eb8421f0878a6_9a54df29fd9206be. You can use the cat command to view the file.
Then, you can adjust the configuration of the load job, and submit the load job again.
Load CSV data​
This section CSV data as an example to describe how you can employ various parameter settings and combinations to meet your diverse loading requirements.
Set timeout period​
Your StarRocks database test_db contains a table named table1. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example1.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table1.
If you want to load all data from example1.csv into table1 within up to 100 seconds, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label1" \
-H "Expect:100-continue" \
-H "timeout:100" \
-H "max_filter_ratio:0.2" \
-T example1.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table1/_stream_load
Set error tolerance​
Your StarRocks database test_db contains a table named table2. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example2.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table2.
If you want to load all data from example2.csv into table2 with a maximum error tolerance of 0.2, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label2" \
-T example2.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table2/_stream_load
Configure column mapping​
Your StarRocks database test_db contains a table named table3. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example3.csv also consists of three columns, which can be mapped in sequence onto col2, col1, and col3 of table3.
If you want to load all data from example3.csv into table3, run the following command:
curl --location-trusted -u <username>:<password>  -H "label:label3" \
-H "columns: col2, col1, col3" \
-T example3.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table3/_stream_load
In the preceding example, the columns of example3.csv cannot be mapped onto the columns of table3 in the same sequence as how these columns are arranged in table3. Therefore, you need to use the columns parameter to configure the column mapping between example3.csv and table3.
Set filter conditions​
Your StarRocks database test_db contains a table named table4. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example4.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table4.
If you want to load only the data records whose values in the first column of example4.csv are equal to 20180601 into table4, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label4" \
-H "columns: col1, col2, col3"\
-H "where: col1 = 20180601" \
-T example4.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table4/_stream_load
In the preceding example, example4.csv and table4 have the same number of columns that can be mapped in sequence, but you need to use the WHERE clause to specify column-based filter conditions. Therefore, you need to use the columns parameter to define temporary names for the columns of example4.csv.
Set destination partitions​
Your StarRocks database test_db contains a table named table5. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example5.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table5.
If you want to load all data from example5.csv into partitions p1 and p2 of table5, run the following command:
curl --location-trusted -u <username>:<password>  -H "label:label5" \
-H "partitions: p1, p2" \
-T example5.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table5/_stream_load
Set strict mode and time zone​
Your StarRocks database test_db contains a table named table6. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example6.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table6.
If you want to load all data from example6.csv into table6 by using the strict mode and the time zone Africa/Abidjan, run the following command:
-H "strict_mode: true" \
-H "timezone: Africa/Abidjan" \
-T example6.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table6/_stream_load
Load data into tables containing HLL-type columns​
Your StarRocks database test_db contains a table named table7. The table consists of two HLL-type columns, which are col1 and col2 in sequence.
Your data file example7.csv also consists of two columns, among which the first column can be mapped onto col1 of table7 and the second column cannot be mapped onto any column of table7. The values in the first column of example7.csv can be converted into HLL-type data by using functions before they are loaded into col1 of table7.
If you want to load data from example7.csv into table7, run the following command:
-T example7.csv -XPUT \
In the preceding example, the two columns of example7.csv are named temp1 and temp2 in sequence by using the columns parameter. Then, functions are used to convert data as follows:
  • The hll_hash function is used to convert the values in temp1 of example7.csv into HLL-type data and map temp1 of example7.csv onto col1 of table7.
  • The hll_empty function is used to fill the specified default value into col2 of table7.
For usage of the functions hll_hash and hll_empty, see hll_hash and hll_empty.
Load data into tables containing BITMAP-type columns​
Your StarRocks database test_db contains a table named table8. The table consists of two BITMAP-type columns, which are col1 and col2, in sequence.
Your data file example8.csv also consists of two columns, among which the first column can be mapped onto col1 of table8 and the second column cannot be mapped onto any column of table8. The values in the first column of example8.csv can be converted by using functions before they are loaded into col1 of table8.
If you want to load data from example8.csv into table8, run the following command:
-H "columns: temp1, temp2, col1=to_bitmap(temp1), col2=bitmap_empty()" \
-T example8.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table8/_stream_load
In the preceding example, the two columns of example8.csv are named temp1 and temp2 in sequence by using the columns parameter. Then, functions are used to convert data as follows:
  • The to_bitmap function is used to convert the values in temp1 of example8.csv into BITMAP-type data and map temp1 of example8.csv onto col1 of table8.
  • The bitmap_empty function is used to fill the specified default value into col2 of table8.
For usage of the functions to_bitmap and bitmap_empty, see to_bitmap and bitmap_empty.
Setting skip_header, trim_space, enclose, and escape​
Your StarRocks database test_db contains a table named table9. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example9.csv also consists of three columns, which are mapped in sequence onto col2, col1, and col3 of table13.
If you want to load all data from example9.csv into table9, with the intention of skipping the first five rows of example9.csv, removing the spaces preceding and following column separators, and setting enclose to \ and escape to \, run the following command:
curl --location-trusted -u <username>:<password> -H "label:3875" \
-H "trim_space: true" -H "skip_header: 5" \
-H "column_separator:," -H "enclose:\"" -H "escape:\\" \
-T example9.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/tbl9/_stream_load
Set column_separator and row_delimiter​
Your StarRocks database test_db contains a table named table10. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example10.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table10. The columns in a data row are separated by commas (,), and data rows are separated by two consecutive non-printable characters \r\n.
If you want to load all data from example10.csv into table10, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label10" \
-H "column_separator:," \
-H "row_delimiter:\\x0D0A" \
-T example10.csv -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/table10/_stream_load
Load JSON data​
This section describes the parameter settings that you need to take note of when you load JSON data.
Your StarRocks database test_db contains a table named tbl1, whose schema is as follows:
`category` varchar(512) NULL COMMENT "",`author` varchar(512) NULL COMMENT "",`title` varchar(512) NULL COMMENT "",`price` double NULL COMMENT ""
Load JSON data using simple mode​
Suppose that your data file example1.json consists of the following data:
To load all data from example1.json into tbl1, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label6" \
-H "format: json" \
-T example1.json -XPUT \
http://<fe_host>:<fe_http_port>/api/test_db/tbl1/_stream_load
In the preceding example, the parameters columns and jsonpaths are not specified. Therefore, the keys in example1.json are mapped by name onto the columns of tbl1.
To increase throughput, Stream Load supports loading multiple data records all at once. Example:
[{"category":"C++","author":"avc","title":"C++ primer","price":89.5},{"category":"Java","author":"avc","title":"Effective Java","price":95},{"category":"Linux","author":"avc","title":"Linux kernel","price":195}]
Load JSON data using matched mode​
StarRocks performs the following steps to match and process JSON data:
  1. (Optional) Strips the outermost array structure as instructed by the strip_outer_array parameter setting.
    This step is performed only when the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets []. You need to set strip_outer_array to true.
  2. (Optional) Matches the root element of the JSON data as instructed by the json_root parameter setting.
    This step is performed only when the JSON data has a root element. You need to specify the root element by using the json_root parameter.
  3. Extracts the specified JSON data as instructed by the jsonpaths parameter setting.
Load JSON data using matched mode without root element specified​
Suppose that your data file example2.json consists of the following data:
[{"category":"xuxb111","author":"1avc","title":"SayingsoftheCentury","price":895},{"category":"xuxb222","author":"2avc","title":"SayingsoftheCentury","price":895},{"category":"xuxb333","author":"3avc","title":"SayingsoftheCentury","price":895}]
To load only category, author, and price from example2.json, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label7" \
-H "format: json" \
-H "strip_outer_array: true" \
-H "jsonpaths: [\"$.category\",\"$.price\",\"$.author\"]" \
-H "columns: category, price, author" \
-T example2.json -XPUT \
In the preceding example, the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets []. The array structure consists of multiple JSON objects that each represent a data record. Therefore, you need to set strip_outer_array to true to strip the outermost array structure. The key title that you do not want to load is ignored during loading.
Load JSON data using matched mode with root element specified​
Suppose your data file example3.json consists of the following data:
{"id": 10001,"RECORDS":[{"category":"11","title":"SayingsoftheCentury","price":895,"timestamp":1589191587},{"category":"22","author":"2avc","price":895,"timestamp":1589191487},{"category":"33","author":"3avc","title":"SayingsoftheCentury","timestamp":1589191387}],"comments": ["3 records", "there will be 3 rows"]}
To load only category, author, and price from example3.json, run the following command:
-H "format: json" \
-H "json_root: $.RECORDS" \
-H "columns: category, price, author" -H "label:label8" \
-T example3.json -XPUT \
In the preceding example, the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets []. The array structure consists of multiple JSON objects that each represent a data record. Therefore, you need to set strip_outer_array to true to strip the outermost array structure. The keys title and timestamp that you do not want to load are ignored during loading. Additionally, the json_root parameter is used to specify the root element, which is an array, of the JSON data.
Merge Stream Load requests​
  • Run the following command to start a Stream Load job with Merge Commit enabled in synchronous mode, and set the merging window to 5000 milliseconds and degree of parallelism to 2:
    -H "columns: id, name, score" \
    -H "enable_merge_commit:true" \
    -H "merge_commit_interval_ms:5000" \
    -H "merge_commit_parallel:2" \
    http://<fe_host>:<fe_http_port>/api/mydatabase/table1/_stream_load
  • Run the following command to start a Stream Load job with Merge Commit enabled in asynchronous mode, and set the merging window to 60000 milliseconds and degree of parallelism to 2:
    -H "merge_commit_async:true" \
    -H "merge_commit_interval_ms:60000" \
